Question about Legacy Audio LA770 Car Audio Amplifier
I have the subs hooked up to the amp and the speaker wires from the cd player connected, when i hook up the ground and power nothing happens.. sometimes the protect light comes on..? help..
  • sneeky May 11, 2010
    Are you hooking up the remote turn on wire? I didn't see this in your post.
    Novelist:
  • 92 Answers
LETS SEE IF YOU HAVE A PROBLEM WITH THE AMPLIFIER ITSELF OR IF SOMETHING IN THE INSTALL REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION OR FAILS TO POWER UP AND YOU HAVE VERIFIED THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN THE AMPLIFIER WILL NEED TO BE SERVICED. SOMETIMES THE RADIO CAN HAVE A DEFECTIVE SAGGING BELOW 11 VOLTS REMOTE OUTPUT WHICH WILL CAUSE THE AMPLIFIER TO NOT POWER UP. IF YOU DISCONNECT THE RADIOS REMOTE LEAD AT THE AMPLIFIER AND TEMPORARILY INSTALL A JUMPER FROM THE POSITIVE POWER TERMINAL AND THE REMOTE TERMINAL OF THE AMPLIFIER, THIS WILL NORMALLY FORCE THE AMPLIFIER ON. AT THIS POINT,YOU HAVE TOTALLY BENCHED THE AMPLIFIER AS IT WILL NOT HAVE ANYTHING TO DO WITH THE ACTUAL INSTALLATION AND IF STILL FAULTY IT SIMPLY WILL HAVE TO BE SERVICED. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Posted on Jan 06, 2010
How to hook up an amp to a car
remote turn on wire( blue/white) from stereo to amp. RCAs from stereo ( sub out) to amp. Power wire (fused) from battery to amp. Ground wire from clean, paint free chassis to amp. Speaker wire from amp to speaker. ( simplied version). Do you have an amp kit? All the wires, connectors and the fuse will be included in the amp kit.They are rated for the amps power output; 0,4,8 gauge.
Sep 15, 2010 | JVC KD-G200 CD Player
I wont the speakers hooked to the cd player no the amp
check were the speakers are installed for pre existing wiring they probly left it there.. if not then you will have to run speaker wire from your stereo wiring harness to your speakers. if the speakers were hooked up to the amp then the wire in the harness should be vacant and you can use it if all the wires are connected then that means that you just have to find were that wire leads and hook your speakers up to it.
Jun 03, 2010 | Pioneer DEH-P6400 CD Player
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
Amp burned out but fuses still good?
this is caused by inproper wiring from the speakers/subs to the amplifier.. an amp will still put out power to subs and speakers when it's wired improperly but it won't last for very long doing it... 6 months is longer than usual....
Dec 05, 2009 | MA Audio M1900XE Car Amp
Thumping sound
You either have a bad ground from your amp to the vehicle or a problem with the amp. Where is the amp grounded? Do not ground an amp to a seat bolt or side panel on any vehicle. The weld points on the car itself cause issue with ground. Take the ground wire directly thru the bottom panel (floor) Check befor you drill! don't hit a wire/fuel line, etc. That will give you a solid ground. Keep your ground wire length to a minimum. 18" or less, and use the same gauge wire for ground as you do for power. Hope this helps
Jun 10, 2009 | Pioneer DEH-1600 CD Player
Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
Jan 31, 2009 | Power Acoustik PTID-8960 Car Video Player
Cd player plays, but no sound comes out of speakers.
first off the amp gets power straight from the battery. the amp is used to power the subs. the subs are suppose to be connected to the amp only( never the speakers).
for the second part you mostlikely killed the wires. you should get some one to look at it and check the wires. thee speakers might need to be re-wired
Jan 31, 2009 | Kenwood KDC-MP238 CD Player
Jensen Amp and Sub
If you followed the instructions correctly, then the amp must be defective. This is sort of simple.
My generic suggestions:
You have the power, the ground, the outputs to the speakers, and then the input.
Make sure that none of the speaker wires are somehow being grounded. Make sure that nothing is shorted that feeds the speakers.
Jerry G.
Apr 27, 2008 | Jensen A300HLX Car Audio Amplifier
No sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Sep 02, 2007 | Alpine CDA-9827 CD Player
My deck doesnt not transmit signal to my amp. Is this an rca cable problem
Hi Your problem is almost defenetly that one speaker is hooked up with reversed polarities, making one speaker cancel out some vibrations of the other speaker. So get the wiring phase checked again, its ethier this or a fauly cable. Good luck.
Mar 21, 2006 | Kenwood KDC-MP728 CD Player
Legacy Audio LA770 Car Audio Amplifier Logo
103 people viewed this question
Top Legacy Audio Car Audio & Video Experts
Mark Skinner
SXTechHead
SXTechHead
Professor_V
Professor_V
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
