Question about HP LaserJet 4300tn Printer
The left margin on my HP Laserjet 4300tn is printing about 1/8" off the 1" set that I have from within documents. Both margins are set to 1" from within the document but when printed, the right margin is 1 1/8" and the left is 7/8". Doesn't matter what program I print from, i.e. Word, Wordperfect, Excel, etc. Is there a setting on the printer to shift this?
  • MyToy Nov 14, 2009
    I have the exact same problem and need a solution also.
CompuGuy44
  • 432 Answers
SOURCE: Printer does not print whole document
In 'Print Preview' look at the margins, and see if anything is too close to the edge of the paper. If it is, then set your margins further from the edge, or drag graphics further from the edge, etc.
To correct the margins that are set to close to the edge of the paper, open the document in Microsoft Word and follow these steps:
  1. Make sure that you are using the same printer driver that gave you the error in Microsoft Word Viewer.
  2. In Word, on the File menu, click Page Setup.
  3. Click OK.
    You receive a warning dialog box about the unprintable regions.
  4. Click the Fix button.
  5. Save and close the document.
You can now open and print the document in Word Viewer without receiving the error message.
Posted on Dec 19, 2008
yooperbud
  • 8637 Answers
SOURCE: Always prints more to left than established margin
Check you Page Setup andmargin set. Sounds like the page isn't set up properly. When you typing a document, go to the FILE then PAGE SETUP. Margins and Paper Layout.
Hope this helps. Bud
Posted on Jan 23, 2009
leroyal
  • 2120 Answers
SOURCE: 11 blue dots print out down the left hand side of documents
it sounds like the CYAN toner cartridge is leaking.
  • 77 Answers
SOURCE: Black line at left margin when scanning any document CX3900
Two possibilities that I can see here:
  1. The surface of the scanner needs to be cleaned.
  2. There is a problem with the scanning head. In this case call your warranty on it, they may want to replace it.
Posted on Mar 12, 2009
Nikhil Gedam
  • 87 Answers
SOURCE: Setting margins on printer
Well, by now you may have found the solution, however, make sure that in MS WORD under File > Page Setup > A4 is selected, and if you still this prompt (error), just click on OK and proceed with printing.
The Laserjet Printers are capable to print upto 5mms from the edge of the border.
Regards,
Nikhil
Posted on Sep 16, 2009
Prints out of margin
what are the margins for the document. Most printers will print documents at a margin of 1 inch on all sides
Apr 16, 2014 | HP LaserJet 1018 Printer
P2035 incorrect margin output
The page size its correct?(paper, A4,letter....etc).
Do a test page on windows and see-it.
Check the size of paper!
Apr 10, 2012 | HP P2035N LaserJet Monochrome Printer
On my Laserjet 3015, in Microsoft Word, if I set top, bottom, left, and right margins to 1", on the printed page, the margins print as Top 1", Left 15/16", Right 1-1/8", and Bottom...
The default paper selection/ size in MS Word is 'letter'. you may have designed the document on letter size and while printing you have A4 size paper in the printer.
So, Make sure that you design the document on the same paper size (such as A4, which is commonly used). Secondly, while printing don't print the document directly. From the Print dialogue option choose the exact paper size and un-check (de-select) any option of paper resizing (if available). You will have the documents printed exactly as designed.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 12, 2011 | HP LaserJet 3015 All-In-One Printer
How do I change the left margin on the printer? I have an internet app that sends the document and I'm unable to change the margins in the internet app.
That's why they are called margins.
You can't print to the edge of the page. The printer physically can't.
Have you tried printing landscape? The other thing to do is set "scaling". That will cause the printer to shrink the page slightly to fit your paper size.
Dec 21, 2010 | HP LaserJet 3050 All-In-One Printer
Our company has a LaserJet 4000 and a LaserJet 4050, and both are printing the margins unevenly, in all applications. For instance, in Word the margins are set to 1 inch each side, but when it prints the...
It could be the rollers, try updating the firmware firstly, Sometimes the firmware will cause alignment and print quality issues. If that doesn't fix the problem, contact hp for a list of ASP's. 1800-334-5144
Al
Apr 20, 2010 | HP LaserJet 4050 Printer
My hp laserjet 2420 printer won't print out my bottom text of my legal size document. when i preview my print it cuts off all text at 9.5'' . what's wrong? my margin's are all set to 1'' and i customized...
Do NOT use customized paper. Set your paper tray to LEGAL paper. Set the tray as LEGAL in the printers setup-menu. Make sure you choose LEGAL in the printout-dialog-properties. Then it should work. Good Luck.
Aug 14, 2009 | HP Hewlett Packard LaserJet 2420 Printer
On HP K5400 printer the Left margin for #10
See an online manual with instructions to change the print settings here., then open the document program that has the addresses in it and use the print preview and page setup to adjust the margins for the printing to 1/4', if they'll go down that low.
Jul 10, 2009 | HP Officejet Pro K5400dtn Printer
Change margins
You should set the margin from the application your printing from. C.-a.-d. if you print from a Microsoft Word document, you should set the margins in this application
Apr 21, 2009 | Office Equipment & Supplies
Print en enveolppe with hp color laser jet 2600n
Envelopes can be printed from tray 1 or 2. Select the type of envelope you are using from the PRINT dialog box or the driver. In your program, set the margins. Typical margins for a commercial #10 or DL envelope would be: Return Address Top margin 15mm(0.6 Inch) Left margin 15mm(0.6 Inch), Delivery Address Top margin 51mm(2 Inches) Left margin 89mm(3.5 Inches). For the best print quality, position margins no closer than 15mm (0.6 Inch) from the edges of the envelope. Avoid printing on the seams of the envelope. Envelopes with a peel-off adhesive strip or more than one flap that folds over to seal must use adhesives that are compatible with the heat and pressure of the printer fuser. the extra flaps and seals can cause wrinkling, creasing and feed jams, could even damage the fuser.
Apr 15, 2009 | HP Color LaserJet 2600n Printer
Regards,
Nikhil
Mar 17, 2009 | HP LaserJet 4250n Printer
HP LaserJet 4300tn Printer Logo
108 people viewed this question
Seeker5211
Seeker5211
