Question about Husky Wet Tile/Stone Saw with with Laser and Stand
Switch wont shut saw off - Husky Wet Tile/Stone Saw with with Laser and Stand
  • 57 Answers
Replace the switch.
Posted on Nov 20, 2009
Dewalt Model D304-04 reciprocating saw wont run. I plug it in, pull the trigger and it wont start. What am I doing wrong or what could the cause be?
Hi Fred:
Hmmmmm.
- Confirm there is power in the plug.
- use continuity meter to check that there is a complete circuit through the saw.
- broken connection in plug?
- broken wire between plug and switch?
- switch not functioning?
- switch set between forward and reverse?
- Speed control potentiometer contacts dirty?
- Bad brushes?
Aug 25, 2015 | Dewalt Saws
Won't start when motor is warm. Saw for half hour and shut it off and it refuses to start again
this sure sounds as if it's an overheating problem , this causes the ign ckt to over heat and shut off the spark at the plug , id get a real good look at the cooling fins and make double sure theres no sawdust or other stuff in there blocking up the works , if you continue to run saw to overheat eventually it will damage the ign ckt to the point it wont come back on and saw wont run ,Period.
I use strong compressed air to blow out stuff stuck down in the ribs of saws(wear glasses )
Aug 06, 2015 | Husqvarna 550 XP 50.1cc 16 in. Autotune...
Compound mitre saw won't shut off unlss unplugged
Check yhe switch it may have dirt in it or be bad. But the switch is the first place to check.
Sep 26, 2009 | Ryobi Circular Saw W/Dual Laser
Chainsaw will run but will not shut off with the run/stop switch
The cut off wire is probably broken before the switch. Depending on the make,you'll need to remove the pull start housing to fix it.
Jul 15, 2009 | Garden
Saw will not run
I had the same problem several months ago with a craftsman (shut down during a long rip), and the reset switch had tripped but did not actually pop out. I tested everything in the line between the power supply and the motor, and found out that the reset switch was not conducting. I was able to reset it manually before re-installing it into the saw, and it's been fine ever since. I'd test that before you start pulling the motor out, it would be a much easier fix if the switch was just sticking.
Apr 13, 2009 | Craftsman 10" Table Saw
Husky Wet Tile/Stone Saw with with Laser and Stand Logo
155 people viewed this question
Top Husky Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Husky Measuring Tool and Sensor Expert? Answer questions, earn points and help others
