Question about Sprint Hitachi P300 Cellular Phone
I have a Hitachi VT-M272A VCRwhich works fine except.When using the remote in the guide mode I can get to all settings except numbers 1 & 2 which are used for programing recording and VCR Plus.I have tried a new remote with same problem,any ideas?Maybe the VCR it's self?
Dual remote set up
Kenneth,
I would be happy to assist you in setting up multiple remotes to the same TV. To do this is a quick fix. If you want the remote to control the TV1, make sure the remote has a green '1' tab in the bottom. Once that is done, access the system information screen and program the remote to the listed remote address. The steps are the same with the TV2 remote, except make sure there is a blue '2' as the bottom tab. I have provided the steps to program the remote below!
Addressing Remote to Receiver:
1.) Go to System Info screen.
2.) Hold down the SAT button until all mode lights light up.
3.) Enter a number between 1 and 15 using the number pad on the remote.
4.) Press the pound (#) button.
5.) Once the SAT button blinks three times, press record.
6.) Test the remote and see if it works.
Apr 14, 2013 | DISH Network Televison & Video
Pioneer plasma elite pro-504pu how do reset to factory mode on standby mode >??
hi,
u cam reset ur only by the following way.
p { margin-bottom: 0.21cm; }
In order to enter Service Mode, TV guide must be turned off
In order to do this procedure you must have and use the correct remote. The full function remote that
came with the set has a TV Guide Logo in a red box. This is the remote you should use.
NOTE: If TV guide has not yet been setup, then the 1st step is to follow instructions to set TV guide up.
Enter ZIP code, cable or ant. Etc.
1.press and release the "TV Guide". TV guide will appear on the screen.
2.Navigate to the TV Guide tool bar and use the ">" button to select "setup" in the menu and press
and release the "enter" button
3.use the "arrow down" button to select "default options"
4.press and release the "enter" button and select "general defaults"
5.press and release the "enter" button (opens menu on lower left side)
6. use the "arrow down" button to select "auto guide"
7. use the ">" button to select "off"
8. use the "arrow down" button to select "done"
9. press and release the "enter"
10. press and release the "TV Guide" button to turn the display off
System Reset Using Service Mode:
1. Enter Service Mode
2. Use the "muting" button to select "initialize" screen
3. While on the "initialize" screen
4. Use the "down arrow" button to select "final setup"
5. Press and release the "enter" button to select "data reset"
6. Use the ">" button on the remote to select "yes"
7. Press and hold the "enter" button until the screen goes black release "enter" button on remote.
8. Power the unit off using the remote control
9. Unplug the power cord from the media receiver to complete the reset
10. Plug in the media receiver; turn the system on and reset is complete.
ok
Jan 11, 2011 | Pioneer Televison & Video
Remote on tv 2 is not working, except to turn the tv on and off and volume. Menu or guide will not work.
velvia_w
Since the remote is not changing channels or bringing up your Program Guide, you will need to readdress the remote to your receiver. I have provided instructions on how to do this. Before readdressing the remote, you might check on the receiver if the antenna (on the back of the receiver) is secure and straight up and down, not at an angle. I hope this helps.
Remote: All Other Remotes
  1. Go to System Info screen
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button
  5. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
Ray Calo
DISH Network
Oct 23, 2010 | DISH Network IR Remote Control
Can the convergence on a Hitachi rear projection tv be set with a remote other than the original?
No, but almost any Hitachi remote for their projection sets will work--different Hitachi remotes use different buttons in the DECAM or advanced convergence adjust mode.
Tell me the model number and I am fairly sure I can tell you the part number of the correct remote. These remotes can be purchased new or used on Ebay at fairly low prices 15-30 dollars.
Let me know if you have questions and if this information helped you rate this solution as I do this here for free.
Also, if you have any questions about your Hitachi confirm the actual model number and I will help you.
I am an expert on this brand and own two of their projection sets myself.
SD TECH
Dec 09, 2009 | Hitachi 50UX57B 50" Rear Projection...
I'm pretty sure the convergance chip is out. My problem is that I do not have the original remote. I have one made by Dynatron. I can't figure out which button is equilivant to Status, or ANT. Help please.
Almost any remote will work for this set if it is Hitachi--understand----if you have one of the two STK-392-120 CHIPS THAT THIS MODEL USES BAD--It will not adjust....
All of the Hitachi remotes will work but different ones use different buttons in the convergence mode--if the model is 43fwx20b it uses a Hitachi remote with the number CLU-4321UG... printed on the front of it.
If you get a different Hitachi remote let me know--I have a book from Hitachi that shows most of the remotes by number and photo and shows which buttons do what in convergence.
Let me know if you need to know how to replace the chips-----usually you can get a remote for this type of set pretty cheap on Ebay.....
Regards, SD TECH
Oct 15, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Buttons stopped working
If there is a tv button on the remote, try pressing that..
Chances are its damaged and you might need to order a new one from Hitachi or possibly use a universal.. With remotes there really isnt much you can do when they stop functioning.
Jul 17, 2008 | Hitachi VT-RM391A Remote Control
Intructions for programming a remote control
I own this remote. Here are the instructions.
1 turn on your tv or catv
2 aim remote at tv or catv
3 while holding tv or catv button press 0 to 9 last ch 100/ent or channel
4 release both buutons when tv or catv changes channel.
note press tv or vcr or catv button first to select desired function
Mar 06, 2008 | Hitachi VT-RM380A Remote Control
Hitachi F361 VCR Digital Auto Tracking (not 631!)
I had the same problem when I got the TV from someone and I didnt have a remote. I went out and got a ONE FOR ALL remote and once I got it set up I had it in VCR mode and hit the AV button and now I can get to the channels. Hope it works for you.
Oct 31, 2007 | Hitachi VTFX631A VCR
Sprint Hitachi P300 Cellular Phone Logo
32 people viewed this question
Top Sprint Cell Phones Experts
Dan Shibata
Dan Shibata
Brett Duxbury
Brett Duxbury
David Ellis Rhea
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
