Question about Canon EOS Rebel X 35mm SLR Camera
How do you take double exposure shots with this camera?
  • 685 Answers
That camera was never designed to take double exposures. You could shoot the whole roll with your first exposure, then carefully and exactly load it again and shoot the second exposure, but everything must line up exactly to even using the same starting sprocket hole to line things up. Not really easy or cost effective, but it can work if you are careful.
Posted on Nov 24, 2009
How do i stop my camera from taking double exposures
your on camera settings in Exposure has the multiple exposure option On.
Oct 20, 2014 | Nikon D3300 DSLR Camera with 18-55mm Lens...
How to shoot dhr with sony dsc-w570?
I don't know your specific camera, but the answer is pretty universal. HDR is High Dynamic Range. Few cameras can do it themselves. You will need a tripod. Take a series of pictures at different exposures, 1 stop apart. You can do that with the exposure adjust +- control. Take one shot each at normal, +1, +2, -1, and -2. Then you will need HDR software to assemble the pictures. There are many programs, some free, some not.
Dec 29, 2011 | Sony Cyber-Shot DSC-W570 Digital Camera
Can't roll film for double exposure.
After taking the first shot, hold down the Multi-Exposure button while cocking the film-advance lever. This cocks the shutter without winding the film. You can continue to do this for as many exposures as you want. Just don't hold down the M-E button while cocking after the last exposure.
The Multi-Exposure button is the button on the front of the camera just below the shutter release button.
Apr 11, 2010 | Vivitar V3800N 35mm SLR Camera
Exposure inconsistency with 18-200mm on my Nikon D300
A plus-or-minus one-third stop is perfectly normal if you're handholding the camera, especially when metering a high-contrast subject such as a lit lamp. If you really need to lock the exposure, use the exposure-lock button or set the camera to manual.
Sep 22, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Pentax SF10 Camera -- double exposure
If you press the film release button like you are going to rewind exposed film you may be able to activate the film advance lever to cock the camera so you can take another picture, and the film should stay on the first exposure allowing you to re - expose it. I would underexpose each image 1 F stop because.you are exposing the same film twice. Double exposures are always an iffy proposition and anything can happen. After the second exposure cocking the film advance should allow the film to advance once again. You might test this on the final pictures on a roll in case the camera won't start advancing the film after you try it. This way you won't blow a whole roll worth of pictures testing it.
Apr 12, 2009 | Pentax PZ-70 QD 35mm SLR Camera
D300 Manual exposure problem
likely there's nothing wrong with the D300 - all that's happened is that its inadvertently been set into bracketing mode and hence it cycles through 3 or 5 or 7 different exposures each time it is activated!
Sep 22, 2008 | Nikon D300 Body Only Digital Camera
Time exposure shot
Hi - You can download the manual by clicking the link underlined in blue below:
FinePix S5200
The max exposure time is 15 seconds. See page 42:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 03, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Forget how to take double pictures.
Hey xplaur,
To take a multiexposure photograph you should first expose the film, and then push the multiexposure button which is on the front of the camera on the top left when you are looking at the front of the camera. After you press this button advance the winding lever to set the shutter, and since the multiexposure button was pressed this shouldn't wind the film to the next frame. Now take your second exposure, and if you want to make another exposure on the same frame repeat the process. Keep in mind that every time you expose a single frame after the initial exposure you will be doubling the exposure on the frame. I usually under expose each exposure by one third on a double exposed frame. If you do more than two exposures I would underexpose each exposure by even more. Multi exposures are fun but tricky, and I would suggest you experiment and have fun with it. I will also say that black and white film is much more controllable and forgiving when it comes to this than color film. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 31, 2008 | Vivitar V3800N 35mm SLR Camera
Extremely long time writing to CF card
IIRC these cameras support a noise reduction feature through a custom function. The camera will take a second exposure with the shutter closed (i.e. against something pure black) to see which pixels in the camera are "hot", and then will use that information to remove that hot pixel noise from the original image. "hot" pixels depend on temperature and exposure length so the camera would need to do this on every shot.
Mar 05, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Double-exposures
DMC-FZ10 and an external flash with a manual trigger can do it. Just set a high aperture number, slow shutter speed, take the pictures...change camera direction a little..then as soon as you can, re-trigger the flash manually.
Sep 07, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Canon EOS Rebel X 35mm SLR Camera Logo
333 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
