Touchscreen; Do not respond by tapping or pressing
At first my touchscreen only respond when pressing very hard. After few times the screen do not react at all. I treid to reset with on/of switch and paperclip. The first and second cros react but the third cross do not react."Useless" will it solve my problem if I re instal my firmware?? I suppose I will have to register first. Please send me a link to where I can download total new firm ware and do I have to delete old firmware. I am not very smart with this. Regards Harry
  • 92 Answers
Hi, scuse me but i thing you will have more chance if you aske your question in the problem section
Posted on Nov 13, 2009
No signal how do I fix it
You have not said what model garmin nuvi ?
The touchscreen on a Garmin nuvi GPS usually loses sensitivity or stops responding if it's lost calibration.
This usually happens after prolonged usage.
Touchscreen problems are also caused by dirt, smudges and improper care.
If your Garmin nuvi's screen isn't performing as expected, Garmin provides solutions and tips to not only improve the device's performance, but prevent premature wear and tear.
Calibrating the Screen
If the Garmin nuvi's touchscreen isn't working, you need to calibrate the screen.
Calibration resets and repositions the screen for optimal performance without deleting saved settings.
Before calibrating the screen, press and hold the "Power" button to turn off the device.
Pressing and holding the "Power" button again for about 30 seconds automatically displays the calibration screen.
Pressing the dot on the white screen calibrates the touchscreen automatically.
Updating Software.
If The Garmin nuvi's touchscreen is still unresponsive, updating the device's firmware to the latest version can solve operating system problems that lead to touchscreen problems.
Before updating the device's firmware, connect the GPS to the computer using the USB cable. When the computer detects the GPS, the "AutoPlay" menu appears on the screen.
Tapping the arrow on the menu automatically opens the "myGarmin Agent" download page.
From there, follow the prompts to update your Garmin nuvi's software quickly and safely.
Cleaning. In some cases, the Garmin nuvi's touchscreen won't respond to touch if the screen is dirty. Touchscreens are sensitive to dirt and smudges that decrease sensitivity.
If the screen is dirty, cleaning it with a soft, clean, lint-free cloth improves performance.
If the screen is severely dirty, using water, isopropyl alcohol or eyeglass cleaner removes tough stains.
To avoid damaging the screen, apply liquid to a cloth instead of directly to the touchscreen before cleaning it.
Tips.
Refer to your Garmin nuvi's maintenance and storage information found on the device's manual prevents premature wear and tear.
If the screen stopped working after prolonged exposure to extreme temperatures or water, the device's hardware is most likely damaged.
In such a case, you need to contact Garmin for additional troubleshooting and possible repairs.
Attempting to disassemble and repair the GPS yourself only increases the risk of damaging the unit even further.
also it could be a battery problem if the nuvi is not getting power ?
May 08, 2013 | GPS
The touch screen wont function with touch of the fingers.
Touchscreen not working
Clean the screen with a microfiber polishing cloth.
Do not wear gloves while using the touchscreen.
Do not use the touchscreen with wet hands or immediately after applying hand
lotion.
Moisture affects touchscreen behavior in the same manner as it affects a
trackpad.
If you have a protective plastic sheet or film on the touchscreen, try
removing it, because it may be preventing the touchscreen from working properly.
The current application may be unresponsive; press and hold the Sleep/Wake button
on top of iPod touch for a few seconds until a red slider appears.
Then press and hold the Home button until the application quits.
If that doesn't work, turn the device off and turn it on again. Press and
hold the Sleep/Wake button on the top of the device for few seconds until a
red slider appears, and then slide the slider.
Then press and hold the Sleep/Wake button until the Apple logo appears.
If the device did not turn off, reset it. Press and hold the Sleep/Wake button
and the Home button at the same time for a least ten seconds, until the Apple
logo appears.
Please rate me
Dec 07, 2010 | Mach Speed T3000 MP3 Player
Z22 palm handheld touchscreen won't respond - i've done soft reset -- several times -- used the 5 way to bring up the touchscreen -- tapped and nothing happened.
Hi, Try doing a hard reset to see if this will correct the problem.
Hold down the power button and at the same time use the tip of your stylus or any other non sharp item and press the inside the reset hole on the back of your palm.
When you see the Palm power logo appear you can let go of the power button and also the one on the back of you unit.
It will display a message asking if you want to do a hard reset and that it will erase all your data. select yes by hitting the up part of your 5 way button on the bottom of your unit. This is the one you use to navigate around your palm screen. After it resets you wil then be prompted to reset the screen by tapping the targets. If it works great. If not then you have something wrong that needs to be looked at. Before you send it in go to:
www.palm.com.
Select pda and then your model. From there go to the support screen and do a live chat. This is free and they may be able to live you some help. Best wishes.
Sep 19, 2009 | Palm Z22 Handheld
Locked LG Incite phone with nonresponsive touchscreen
You have to reinstall the rom
http://www.wireless.att.com/answer-center/main.jsp?t=solutionTab&solutionId=KB102425
May 27, 2009 | LG Incite Cell Phone
DS Lite bottom touchscreen seems "stuck"
i think you should either get a new ds or tap the touch screen hard. if tapping the touch sreen harder does not work then that means it is time for a new ds.
Jan 18, 2009 | Nintendo DS Lite Console
Treo600 Touchscreen doesn't respond.....
Try running a piece of paper around the edge of the screen. There may be was something stuck in there, pressing the screen slightly and causing it to not respond to the stylus
Jan 14, 2008 | Palm Treo 600 Handheld
Touchscreen
try calibrating the unit
Oct 17, 2007 | Pioneer AVIC-N1 Car DVD Player
Touch screen
You may have dust accumulation around the edges of your touchscreen, between the screen and the case. Try using a can of compressed air. Gently press down on the edges of the touchscreen to expose the gap between the screen and the case, and shoot the air in there. This worked for me when my Treo 600 touchscreen stopped responding.
May 23, 2007 | Palm Treo 600 Handheld
Getting past the 'Align Screen'
Had the same problem starting about 3 months ago with my Axim X5. Couldn't get the touchscreen to respond in order to input my password. However when I sync it to my computer I had better success at getting the touchscreen to work and respond. Tried the business card tip of sliding it between the touchscreen and metal cover/frame of the PDA and now it seems to work even better. Great tip. Hope it becomes the more permanent fix for getting my PDA touchscreen to respond. Mack
Jan 28, 2007 | Dell Axim X5 Pocket PC
64 people viewed this question
 Grubhead
Grubhead
