Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile pss26lsra ss....refrigerator side is freezing the food...and causes water to not dispense, I guess because it must be froze...regardless of what you turn the temp to, it still freezes...I cleaned the back coils, not the problem...don't believe it is the temp guage!...how about the damper assembly, fresh food inlet cover kit??? - Kit includes damper, fan assembly??? Please help!
  • 74 Answers
SOURCE: ge profile built in SS refrigerator
Go to www.geappliances.com - service and support section - parts and search for your model number . You will be able to get an exploded diagram in pdf format for each section of the appliance.
Graham
Posted on Nov 28, 2008
  • 351 Answers
SOURCE: GE side by side Profile Performance.. water freezes on the floor
hmmm could be a really bad defrost problem but we will most likely find that the drain is plugged..... i recommend taking the food out and turning the machine off overnight if you can
Posted on May 06, 2009
rylee_smith
  • 8619 Answers
SOURCE: ge side by side profile. freezer works fine, all
Hi!
First of all you need to clean the coils (condenser coils under the unit or evaporator coils inside the freezer). The coils inside could be iced over because of failure of defrost system. Now check that the condenser fan under the fridge is working properly. Check that the fan in the freezer work which pulls cold air from the coils inside freezer and blows it to the fridge side. Are the temperature control knobs in the fridge adjusted correctly? It actually just opens a vent to let more or less cold air in from the freezer. It takes a while for the ice to build up in the freezer enough to affect the cooling.
My first guess would be the defrost timer. You can manually turn it to engage the defrost cycle and observe whether or not the defrost heaters come on. Now use a hair dryer to speed up melting the ice when there is lots of ice buildup. Most timers are 24 hour timers. It will turn the defroster on every 6 or maybe 12 hours depending on the model.
Before testing the defrost heater, unplug the refrigerator to avoid an electrical shock hazard.
The defrost heater is usually located at the back of a side by side freezer or under the floor of a top freezer. It will be necessary to remove obstructions such as the contents of the freezer, freezer shelves, icemaker and the inside rear or bottom panel of the freezer.
The heater is connected by two wires. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 24, 2009
  • 1531 Answers
SOURCE: fresh food part not cooling, damper not opening
if the damper is not opening then you should replace it.there might be a problem witht the thermastat control. but most likely the damper has failed and need to be replaced.
Posted on Feb 24, 2010
blueextc3221
  • 15935 Answers
SOURCE: The fresh food section was
This damper is controlled by the main board of the fridge in most cases.
Testing should have been conducted to see if voltage was being applied to the "stuck" damper.
It may, in fact, be doing exactly what it's told.
Reply with the model # and I can give you a definitive answer.
Thanks!!
Posted on Aug 31, 2010
Will not dispence water
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
WATER WILL NOT FLOW
Oct 30, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
The food in the refrigerator drawers (crisper and meat) are freezing and the waterline froze. What is causing this and is it worth repairing?
I have Ge GSS25XSQA SS side by side and the food in the refrigerator drawers (crisper and meat) are freezing. Also the ice dispenser is frozen closed. The water dispenser still works.
Want can I do to fix it. Would dirty coils have anything to do with this?
Terry
Nov 10, 2010 | GE GSS25SGPSS Side by Side Refrigerator
The water is leaking from the Ice dispenser and the food is thawing
Seems like the freezer is not getting cold enough. If the ice maker was leaking the water would freeze. It would not cause the food to thaw.
Oct 17, 2009 | GE Profile PSW26P Stainless Steel Side by...
May 06, 2009 | GE Profile Performance 25.2 cu. ft....
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Not getting water from dispenser in door
if you can get ice but not water from the dispenser then suspect a frozen water line within the door . Check you get water to the connector at the bottom of the freezer door. Sometimes you can clear the blockage by connecting a steamer to the pipe but this will only be a temporary fix . If the pipe has frozen within 6 inches of the dispenser outlet then there is a heater mod that can be fitted WR49X10173
Nov 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge profile built in SS refrigerator
Graham
Nov 21, 2008 | GE Profile¿ 48" Built-In Stainless...
Water freezing at bottom of refrigerator/Temperature not right
thats a water tank holding water dfor the dispensor, if everything in refrig is freezing quite possible that the water in tank froze as well, which would explain no water,
Feb 24, 2008 | GE PSS26NSWSS Profile 25.5 Cu. Ft....
GE (PSS26MSRSS) Side by Side Refrigerator Logo
239 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
