Savin 9935 dpe not working
I HAVE PURCHASED A SAVIN 9935DPE COPIER AND IT WAS WORKING FINE BUT HAD IT IN STORAGE FOR A COUPLE MONTHS AND NOW THE MACHINE IS NOT WORKING AFTER i HOOKED IT UP THE FINISHER CODE IS COMMING ON BUT i can not find any paper jammed in it and not sure what to do next.
  • 92 Answers
Try to ask your question to the problem section you will have more chance
Posted on Nov 13, 2009
Savin 9935DPE is printing one thick vertical balck line down the copy or print pages. About 2 of every 3 pages printed. What's wrong?
are you printing from Doc feeder or glas?? if from feeder then try to make a copy from the glass, does it still do it? yes problem is with drum.
No? problem is with the small scanning glass to the left, look carefully see if any spots or lines on the 1inch glas --- clean it
Sep 05, 2012 | Savin 9945dpe 9935dpe 2035dpe 2045dpe...
Need to replace the thermistor on my Savin 9945 DPE Copier- how do I access the thermistor unit? Where would it be located on the machine?
replacement of parts of copier is done by a technician, well if you could follow this you can replace the thermistor. open the right side and the front cove, the fuser is located on top of the OPC carriage unit, push the blue level going to the right side while pulling the fuser unit. after removing the fuser unit remove its the top and bottom cover. the two thermistors is located on top near the fixing separation claw beside the two thermal fuses. Good luck!
Aug 26, 2011 | Savin Office Equipment & Supplies
I have a service code CS541 for a Savin 2522 - I need to repair it
Ricoh copier service code SC541 refers to the fuser assembly having a problem.
Sometimes they code can be temporarily reset, however, it will eventually come back
and not go away!
While the printer is on do the following:
  1. Hold down both of the arrow keys for 10 seconds
  2. Press ENTER
  3. Select Option 2 for Engine
  4. Choose 7 Data Log
  5. scroll down to 7807 and execute it. click OK
  6. press the escape button until you get to the engine option
  7. then select option 3 to end
  8. restart the printer by pressing the power button.
If the above does not work, repeat the procedure but instead of 7807 look for SC calling, something like that, and reset the whole thing.
The reality is that the problem is fixable though, and do not need to purchase a new fuser, after clearing the code, the printer should work fine again
Jan 31, 2011 | Savin 2545DP Black and White Copier
Savin 9935dpe /ricoh 350 toner waste near full. Where is the
If you can locate the imaging drum unit, the ink is usually stored inside. The imaging drum has a roller with green film over it (this part may not be exposed), which is light sensitive, don't leave it in a bright area for long periods of time, or you may shorten the drum's lifetime.
You'll may have to remove the green roller (is sometimes a dark-blue or black), or some other parts, in order to find a grate. This grate is usually where the ink is dumped, though the design may differ depending on the model. Also, be careful when taking apart your drum, as it is filled with powdered ink, and if you turn it the wrong way, it will spill, and it is very very messy. If you're in an appropriate cleaning area, however, this may be a good way to locate where your ink is stored.
I'm not particularly familiar with Ricoh products, but that is how most laser-printer technology works.
Jun 22, 2009 | Ricoh Office Equipment & Supplies
Savin 9935DPE document feeder maintenance
GO ONLINE TO SAVIN: TYPE THE FOLLOWING INFORMATION:
WWW.SAVIN.COM/SERVICE_MANAUL
/TECH_SUPPORT
/SERIVES
/HELP?
CALL SAVIN ASK TECHICAL SUPPORT, ASK FOR A TECHICAIN THAT REPAIRS OR FIXS THAT TYPE OF EQUIPMENT AND EXPLAIN THE PROBLEM AND SEE IF HE HAS ANY IDEAS YOU CAN TRY BEFORE YOU GO OUT AND SPEND ANY TYPE OF MONEY ON THAT PART.
ROD
May 12, 2009 | Office Equipment & Supplies
HP 190 Cartridge cleaning not lasting
You should apply to service. The Fault is caused by wear-out rakel knife. This device which clean the photo a drum.
Mar 25, 2009 | HP 190 Copier
I have a savin 9935dpe b&W multifunction copier. It states an error code of: "functional problem SC321-00" and to poweroff the machine or call for assistance. I powered off the copier and...
the laser unit can't write, pull out laser unit to clean out (do not open black box ) laser unit located at left down corner of the toner unit. after clean if still not work, change laser unit.
Dec 11, 2008 | Office Equipment & Supplies
Copier reset procedure.
hi fixya180,
It seems that the error code 541 (which indicates a problem with the heating unit thermistor in the machine), cannot be reset by the user for safety reasons, ref;
http://savin.custhelp.com/cgi-bin/savin.cfg/php/enduser/std_adp.php?p_faqid=7081&p_created=1102093227&p_sid=9TrLDc-i&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTQzNiZwX3Byb2RzPTI1MTAsMjUxNCZwX2NhdHM9MCZwX3B2PTIuMjUxNCZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9ZXJyb3IgY29kZQ**&p_li=&p_topview=1
This error requires service support from your local authorized dealer or original point of purchase. You say that you've verified the functionality of your fuser unit; then a authorized Savin printer technician will probably just have to reset the error code of your copier.
Hope you find this info helpful in solving the problem and thanks for using the FixYa service
Kind regards
Mar 07, 2008 | Computers & Internet
HP ScanJet 7650 asking for DPE
This problem happened to me to (OfficeJet 6310xi). These steps solved my problem:
When the program has the error, there's a button so you can show it where DPE is. Click the button
Navigate to Macintosh HD/Library/Application Support/Hewlett-Packard/HP Scan Pro/DPE/
Click on DPE 11.6.app
Then I could scan to pdf. When I upgraded to Leopard, I reinstalled my HP software, even though HP says it isn't totally compatible with leopard.
Nov 04, 2007 | HP ScanJet 7650 Flatbed Scanner
119 people viewed this question
jasbo
jasbo
