Question about Kenmore Oasis HE 27082 Top Load Washer
What does LF means? and what should I do - Kenmore Oasis HE 27082 Top Load Washer
    President:
  • 1,937 Answers
See the following Whirlpool Service Manual for their Cabrio washer which is basically the same as the Kenmore Oasis.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
6-1
DIAGNOSTICS & TROUBLESHOOTING
DISPLAY FAULT / ERROR CODES
DISPLAY
(Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
(F30)
Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged
the basket but control does not detect a water level change.
• Is water supply connected and turned on?
• Are hose screens plugged?
• Is water entering the tub? If so check pressure hose connection to machine/motor control.
• See TEST #2.
Posted on Nov 13, 2009
What does LF mean on the washer? When I start my load it pops up as LF and stops washing. What do I need to do or what is wrong?
LF (F30)
LF flashes when the control don't sense any water coming in like it is supposed to do. Things to check:
Hoses connected; water turned wide open.
Is water siphoning out due to having the drain hose too low? (30 inches above the floor)
Pressure hose from tub to control loose, pinched, hole, Sediment in tub? themobilian_1135.jpgthemobilian_1136.jpgBlow that tubing out and re-secure; retry with water OUT of tub so the pressure can properly build in that tubing. themobilian_1137.jpg
Bravos codes and service manual HERE
Jan 29, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
What does LF mean - my kemore washer quit working
hello
mean while LF error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
The LF error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
however,what you need to do tp fix up the problem is to unscrew the washer then clean up all forms of dry and water you can seen in it with this the problem of the LF error code is solve .
please make sure that all form of power supply is put OFF before you can do this
thank you and thanks for using fixya.
Jun 03, 2010 | Kenmore 24032\24036 Top Load Washer
Code lf keeps popping up
lf code means long fill. If the water fill time exceeds 10 minutes, the water valves are turned off and lf is flashed. Press STOP/CANCEL to clear the display.
Mar 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does the code Lf mean?
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Feb 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
LF READING ON PANEL
LF means "Low Flow". Remove the filters to see if the code goes away. If not, the pressure switch may be bad.
Feb 09, 2010 | Aqua Flo 1 HP Aqua-Flo Pump: 1.5" in/out,...
Our washers keep flashing LF after the wash cyle and stops workin, not spining very fast either.
Hello there :
the Dreaded LF code means
LF Long fill If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed.
check the water controle inlet valves that are attached to the machine for proper operation and replace if found bad
Jan 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
The washer is showing a code of LF what does this mean
LF Long Fill
Oct 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Lf what does it mean?
Lf means long fill make sure your taps are on. or your filters in the hoses arn,t plugged in other words it is taking longer than 10 minutes to fill
Dec 11, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
329 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
