Question about Hitachi NV45AB2 Roofing Coil Nailer
Air comes out of the back - Hitachi NV45AB2 Roofing Coil Nailer
  • Adelaide Nail Gun Repairs
    Hi Adrian If your talking about were the hose attaches. Try putting thread tape on the thread of the fitting. If its coming out of the top cap (breather/exhaust) then you may need to get it serviced(replacing your internal O-ring). Or if its leaking air between the top cap & the body then you may need to replace the gasket(1st try screws are done up). Good luck!!
  • 55 Answers
On the back of the gun there is a allen wrench screw take it out and the back cover underneath it is a o-ring take it out and get a replacement it is bad try looking at an Ace hardware near you thats where i go they have a great selection
Posted on Dec 01, 2009
Water gurgling in heater, heat is warm, air is very light coming out of the vents, sometimes air goes cold then comes back warm.. a bump will make it go cold
it's look like the a/c evaporator is block by dirt,oil look at it ..It should be clean as this one
hope it helps
Apr 04, 2014 | 2000 Chevrolet Blazer
Cold air comes and goes
Well if you have it set to coldest position and dose that sounds like low on refrigerant
Jun 27, 2013 | Heating & Cooling
My dryer is not drying i noticed there was no air coming out the vent out side
disconnect the exhaust vent from the back of the dryer and see if you have any air coming out of the back of the dryer if you do you will most likely have to replace the exhaust vent line that goes from the back of your dryer to your outside vent. Blockages of lint build up over time and should be cleaned at least once every 6 months. If you find that you have no air coming out of the back of the dryer when you remove the vent line message me back for further diagnosis. I await your reply
Thank you
Rick
Oct 27, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
I puh the button on my whirlpool tub and it doesnt start anymore
This sounds like either the air button is not working or the air switch in the back of the motor has quit. You need to find out if the motor operates. If the motor comes on then it is a process of elimination. Check the air switch in the back of the motor and see if you can turn the pump on/off by blowing into the air switch with a straw. If it comes on by blowing in the switch then the air button is bad. If it doesn't come on then the air switch is bad.
Jan 11, 2011 | Home
Turn on unit starts blowing cold air for about 5 minutes the compressor kicks off. will not come back on. you can turn it off and back on and compressor will start back up again for about 5...
soulds like when it starts the high pressure switch kicks it out when you turn the power off you equalize the pressures check you coils and filter they need to be cleaned most likely this is the problem
Sep 11, 2010 | Comfort-Aire RAD-243 Air Conditioner
Comes on and runs then cycles off, and may not come back on. fans run every thing seems to work compressor dose not come back on.
if a portable air conditioner, is the water tank full of water ? if so empty it.
Other option for any a/c unit (not just portable unit) is that it has a gas leak.
Apr 21, 2010 | Genie Aire PACR12 Air Conditioner
Cool air comes out of the back unit vents and hot in the front
under the dash on the bottom of the heater box there is a little selector motor most likely that motor has gone bad
Aug 07, 2009 | 2000 Ford Expedition
MY AIR CONDITIONER TRIPPED ,NOW IT WONT COME BACK
Unplug unit let set till cool then turn on motor has heat trip button that will pop out so it wont over heat, It should pop back in when it cools off. Make sure filter is clean and condenser is not iced over by high humidity. If unit still wont come on check house fuse or breaker it should be on a circuit by it's shelf, flip it off and back on so it is closed all the way.
Jun 27, 2009 | Fedders A6P09S2A Air Conditioner
No air flow coming out of the back of the dryer
take back off and clean out the lint built up in the dryer
Jun 21, 2009 | Dryers
Hitachi NV45AB2 Roofing Coil Nailer  Logo
46 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
