Question about Toshiba Satellite A105 Notebook
Moniter problem when i turn on my laptop the screen sometimes freezes and there are horizontal lines that wont move. i dropped it several times could there be something wrong with the graphics card or connection to the moniter is just screwy?
  • 91 Answers
I suggest u to try connecting the laptop to any external monitor. If the display is fine on the external monitor, then u need to get repair/replace the monitor. U can determine the LCD issues by connecting External monitor.
Posted on Jun 17, 2008
  • 54 Answers
Haller,,,kindly show your laptop computer to one shop cause they can check its LCD if working or deffective,,,,,thnkzzz
Posted on Jan 08, 2008
  • 233 Answers
The LCD screen is damaged.
hope this helps
6ya staff
SOURCE:
Why does my acer aspire z5761 keep freezing and has horizontal lines across screen and constant bleep?
You probably somehow killed the screen. Did you drop it or bang it into something? You can try downloading and replacing the drivers, but I doubt that will help. Lines on the screen are usually a physical problem, not software related.
You may try a Windows Restore if your machine has that ability. Some do, depending on who you bought it from. Again, doubful it will help, but worth a shot.
Need more information on the bleep. When does it bleep? Constantly? When you touch the screen? Or when you boot it up? What kind of bleeps? One? Several? Long? Short? Both? Repeating sequence?
Jun 28, 2015 | Acer Computers & Internet
Sony FD Trinitron WEGA KV27FS100 horizontal lines across top part of screen
Check and replace all electrolytic capacitors in the vertical output section circuit. There will be 5 or 6 of them to replace. Replace all at one time. The fault you describes here is technically known as 'vertical retrace lines'. Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 990 posts to different brand TVs now. Sometimes, you might get some more details from there.
Oct 13, 2012 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Buzzing sound and the screen freezes with horizontal lines on the screen
if you use external monitor works ok?or same situation?
its sounds like a failure of the graphic card
Oct 06, 2012 | HP Pavilion dv6t Notebook
Compaq V5005us is weird. Powers on with black screen and freezes
It sounds like your Video card and/or motherboard are starting to give out or your LCD is giving way. Try plugging the laptop into an external screen and see if it still acts strangely or even displays on the external monitor.
Mar 18, 2009 | Compaq Presario 2100U Notebook
Display has lines that run through it
they can be horizontal. I think your graphics card on your motherboard is bad. you should consider sending it to acer so they can replace it with a new one.
May 18, 2008 | Acer Aspire 3000 Notebook
Resolution has lines in the 320x240 format
try to relocate your cam away from monitor, speakers or from pc. there maybe interference coming from these units. you may also try moving the cam cable and check for loose or intermittent connections. try removing/ reinserting the cable several times, this will gonna clean the pc to cam contacts
Sep 10, 2007 | Creative Labs PC-Cam 600 Digital Camera
Screen and volume problem
Hello, the problem regarding horizontal blue line can be around vertical output stage with IC(LA78045). Please check for cold soldering, resolder the suspected solderings. Best regards.
Apr 27, 2007 | Sony KP-46WT520 46" Rear Projection...
Horizontal lines obstructing the second half of the ti 83 calculator screen, anyone know repair tips?
I had the same prob with vertical lines on the screen, and getting messed up when there was lots of numbers on the screen.
Solution: Change your batteries. Put some freshies in then adjust your contrast until you see the little black box. If you still have a problem with the lines, darken the screen until it's black (2nd up repeatedly) and let it sit for a couple minutes. Lighten your screen back to normal (2nd down) and turn off then turn her back on.
Jan 17, 2007 | Texas Instruments TI-83 Plus Calculator
Toshiba Satellite A105 Notebook Logo
191 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
