Question about Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D
Freezer is 4 months old, when we closed the door it used make a vaccum sound like it was sealing now it no longer makes that vaccum sound.
  • 464 Answers
It doesn't mean the fridge door gasket isn't sealing properly, if just means it has worked itself into a permanent seal. if you aren't having any problems with the fridge, don't worry about it.
Posted on Nov 13, 2009
I have 20 cf Whirlpool model #evl202nxtn freezer,I can feel cold air from the top of the door seal.Anyway to stop this with out replacing the seal.The freezer 18 mth old.Thanks
oh wow . i have the same freezer with same exact problem. i bought it brand new. i can definately see the seal on top is not installed properly. i always thought it was only my freezer but i guess its a manufacturing issue.
Sep 24, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Unit runs continually with gurgling sounds
defrost fully once a year or more if you notice it frosting up.it should run at minus 18c to 20 c for best results. 0f is fine.gurgling noise is normal (liquid turning to gas before compressor turns it back to liquid).make sure door seals all round and the kids close the door asap after use......also if you portion up food prior to freezing and vacpack it it will last longer.and be easier to store/rotate.
Feb 17, 2010 | Frigidaire 15 cu. ft. / 425 liter Chest...
Freezer door has a gap in the middle. Seal doesn't
Put a long straight edge on the door to verify a warp. A 4 foot level is good for this test.
If the door is in fact warped. You should pull back on the seal,loosen the screws behind the seal holding the door liner in place,adjust the door to the straight edge and re-tighten the screws.
If the straight edge does not show a warped door,take a hair dryer and heat the seal where it is off the frame. Do this with the door closed and you will see the seal relax and touch the frame. Let it cool in this position before opening the door again.
If neither of these is the cause,loosen the door hinge and re-adjust the door position,then re-tighten the hinge screws.
Feb 13, 2010 | Frigidaire 19.53 cu. ft. Commercial...
Frigidaire upright--"Hi temp" warning light on door. Don't know why freezer temperatures are so high (into 30s), food is thawing. Electrical seems to be fine. Have not noticed problems with door. New...
2 months old should still be under warenty.
Check the freezer fan by opening the freezer door and pressing the door switch and listing for the freezer fan sound. If no sound then the fan motor could be bad.
Look at the back wall too see if you have frost build up. If you do then you have a defrost problem.
If thees are not your problem you could have a seal system problem. (( freon leak ))
Jan 11, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My Kenmore freezer is continuously running. It
clean all of the door seals and all of the contact point with freezer
Jul 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer vaccum seal not working
check the gasket and make sure that it it not pinched and letting in air whe the door closes. primaryly around where the hinges are.;
Dec 27, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer not cooling
ZoeM, I am thinking freeze up from humid conditions, too much 'window shopping' or bad door gasket (is that the seal of which you speak?). If the unit is only 9 months old...it has a full warranty. Don't do anything to it beyond what is described here.
Defrost the unit completely. If you can get warm air to the coils, do so. If not, leave it off and open for 2 days to completely defrost.
To check most door gaskets: first, make sure the gasket and its mating surface are both clean and visually undamaged. Next, test by simply closing the door on a piece of paper...use a strip about 2-3 inches wide and long enough to go inside the unit that you can slide across the gasket/frame surface. Close the door with the strip near any suspect areas. You should not be able to pull the strip out easily. Replace any damaged gaskets.
Dec 03, 2007 | Baumatic Upright Freezer BV12A
GE Upright Freezer problem/door
The door seal is damaged or the hindge alignment have allowed the warm air to enter and the cold air to leak out the of the freezer. Look and feel around the door for the cold air and check the top and bottom hinges to make sure they haven't become loose. Look for tears also around the seal because this will do the same thing. Let me know what you find. JT
Oct 23, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
259 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
