Data port settings
Trying to connect my Krazer1 Cell to my HP/Windonw's Vista. The phone works fine on my regular PC. Error comes up: data port?? Is this the setting that is the problem?
    Novelist:
  • 101 Answers
Hi Rthorntor,
The "Data Port" is the port you connect to the PC with. Devices can use the parallel port, serial port, or USB port.
The phone should have a "control panel" where you can select this.
Can't find much data, on a Krazer1 phone, but if you know where it's website is, I would suggest you you check for Vista drivers, since Vista handles it ports differently.
Good Luck.
Posted on Jan 09, 2008
QTEK
Airtel Hack for Free GPRS All you need to have is
–>PC
–>Serial/USB cable/Bluetooth dongle
–>Any Browser(I suggest Opera as we can browse both wap and other sites)
Follow These Steps:
—>Activate Airtel Live sending a message MASALA ACTIVE to 121
—>Create a profile with the following settings in your data account under Data Communication
GATEWAY : 100.1.200.99
APN : airtelfun.com
USERNAME : blank
PASSWORD : blank
PASS REQ : OFF
ALLOW CALLS : AUTOMATIC
IPADDRESS :
DNSADDRESS :
DATA COMP : OFF
HEADER COMP : OFF
and then Under INTERNET PROFILES,
INTERNET MODE : HTTP or WAP (both works)
USE PROXY : YES
IP ADDRESS : 100.1.200.99
PORT : 8080
USERNAME :
PASSWORD :
–>Create a new dial-up connection on your pc after connecting the mobile to pc,using the NEW CONNECTION WIZARD as follows
ISP Name : Anyname
Phone Number : *99***1#
Username and Password : blank
–>Configure your browser to use the proxy 100.1.200.99 and port 8080.
–>Connect to the dial-up account. You will be connected at 115.2kbps
—>Now if you try to access any site on your mobile you ll get an error message like “Access Denied”
—>Open your browser, and start browsing and voila it opens the regular sites and if u beleive ull get a d/l speed of 5-6 kbps
Common Errors:
If you are getting any error wile dialing a dial up connection than go to
Control panel>> Phone and modem>>>select modem and click on its properties >>advanced
and enter the following initialization commands
CODE
AT+CGDCONT=2, “IP”,”airtelfun.com”,”",0,0
Now it should be connected without any error......!
May 26, 2009 | Lands Phones
Subscribe to packet data first..
Here is what to do : In opera mini check what type of connection is been set . There are to types [HTTP , SOCKET] . Just try to switch between them and you'll solve the problem . For me [SOCKET] is always better , because [HTTP] takes long time to load a page . If that didn't solve the problem , then in the phone , go to SETTINGS and make sure that all applications are allowed to use your preferred access point as default for Applications .
your rating is very important for me , that's why I've helped you .
good luck .
May 11, 2009 | Nokia 6300 Cellular Phone
Cell phone (LG KP199) to PC (Win XP) USB data transfer problem
When you connect your phone to the PC, it shows two options for connecting: Mass Storage and Cell phone. Select mass storage.
For connecting in Cell phone mode you need to have the PC Suite for this model which as on date is not available.
You can use any third party softwares like mobimb, Mobtime Cellphone manager etc. for connecting to PC.
Dec 30, 2008 | LG KP200 Cellular Phone
Samsung sgh j700 phone shows up as mass storage device
check the pc connectivity settings on ur phone.
make sure that ur using the 2.0 port of ur computer
dont use front usb ports cpu. use rear ports. they are faster.
if still problem persists. try below
conect ur phone to usb. now without disturbing the connections switch off and then on the phone. now there may be chances.
samsung sofware could be corrupted due to virus on ur pc. remove all the viruses then freshly install suit
Dec 09, 2008 | Samsung J700 Cellular Phone
Error 734: PPP Link control protocol was terminated
hi dear, if you are facing the error 734 with n82 using nokia pc suite then i think the solution is delete the extra string in phone and modem option which is in control pannel. the path is control pannel>> phone and modem option>> modem>> select N82 USB modem then click on properties>> advanced tab>> Delete the commend. After that delete the modem settings in handset then connect. it works. just try this . . . . .
Nov 27, 2008 | Microsoft Windows Vista Home Premium with...
SYNC LGKU990 to PC
This is what sorted it out for me.
When you go through the connection wizard on the LG PC Suite take note of the port number that it is using.
Then go to device manager(for win xp go to start/control panel/system, click on the Hardware tab then device manger) on your pc. Expand Ports(COM & LPT) and right click on LGE Mobile USB Serial Port and select properties. Take note of what port is indicated in brackets. Go to the Port Settings tab and select advanced. Change the com port number to what LG PC suite was using. Select OK, OK and try connecting again with the Wizard and see if you can transfer data etc
Let me know if that helped.
Sep 04, 2008 | LG KU990 Viewty
Sharp gx17 Handset Manager(PC)
I had the same problem, and the solution is:
Open the Handset Manager, select Options->Interface Configuration, and in select the COM 4. Click Ok and see it connecting to the phone. It worked for me!!!
Apr 14, 2008 | Cell Phones
"Please insert a disk into drive.. "
  • u can install lg internet kit from " wowlg.com" then u can connect with ur USB for connectivity,
  • for connecting internet u need to select 'com port' option instead of mass storage .
  •  or if u want to trfr data from mobile to PC or vice versa u can selecrt the option of mass storage , then automatically ur h.set wil restart,u wil get the option USB "ON" on ur mobile. u wil get new link in ur PC "removable device " in option My computer, open that to trfr data.
Oct 22, 2007 | LG Shine KE970 Cellular Phone
Can not connect using LG Mobile Sync
I have the same problem like everyone else in this forum! here is the solution:
1. The USB modem driver came with the CD may or will not work, so get the latest drivers for it.
2. Before install the new drivers, change your phone setting under " setting -> USB connection -> from MASS STORAGE to DATA LINK.
3. Plug the usb cable to the phone and to your PC, it should do anything or give any message if it does just cancel it for now.
4. Install the new USB driver you just download, while install it will said something like " does not work with XP " just click OK don't panic.
5. After it finished installed you will see by the clock that it find the USB LG blah blah...and ding ding sound if you have sound on.
6. Now go back to LG Sync software and click on Connect & choose LG modem com port whatever it there.
7. You're done !!!
Here the link where to get the new USB driver:
http://it.lgmobile.com/web/web.product.manualSoftwareRF.laf
Yeah the link is all Italian ...don't panic, I couldn't read it either LOL...just click on the picture where you see the phone and the PC with wrap around with arrow, then follow instruction will be in English.
Good Luck!
Keep posting good answer that you find and help out other just like US!
Sep 20, 2007 | LG Prada KE850 Cellular Phone
LG Prada
To Synchronise the Phone with the PC you must go to "connectivity" and set the USB Connection on the phone to Data Service and use the LG Sync. software. To transfer files such as photos videos or music, set to -Mass storage- and use windows explorer to Drag & drop. it's easy.
Jul 24, 2007 | LG Prada KE850 Cellular Phone
Computers & Internet Logo
128 people viewed this question
Alun Cox
David Payne
David Payne
