Question about Whirlpool Dryers
Whirlpool gew9868kq2 runs, all program panel lights work no heat under any setting
  • 464 Answers
You may need the element which is #14 in the attached breakdown, part #3387747. OR, it could be a thermostat(s) #47 & 48 come in a thermal cut off kit, part #3977394 and #42 is an internal bias thermostat and the part # is 3976615. hope this helps.
Posted on Nov 13, 2009
My Whirlpool GEW9868KQ2 dryer is stuck on the towels/cotton setting and will not change to any other setting. Also when i press the stop/cancel button, it wont turn off. Please help!
This is probably due to a stuck button. The only way to fix is to pull the board off and check the buttons manually and/or replace interface control.
Dec 12, 2011 | Whirlpool Dryers
Model gew9868KQ2 wont start E7 code
How do you remove the Toe panel off of the Senseon Electric Dryer?
Oct 18, 2011 | Whirlpool GEX9868J Electric Dryer
Clean light is blinking
On Whirlpool manufactured dishwashers, the blinking clean light is an interruption in the dishwasher program that usually indicates a component problem or program malfunction. If a component is defective, it's usually attributed to the heating cycle or thermostat failure. To rule out component failure, or program error, the following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
http://www.fixya.com/support/r3575752-dishwasher_blinking_clean_light
Keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
In many cases, I found this to be a momentary glitch in operation. If the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, it should be affixed somewhere under the dishwasher. I have also found them located inside the inner door panel. Please post back and let me know if you still need assistance.
Aug 23, 2010 | Whirlpool 24 in. DU1050SS Built-in...
We do have Whirlpool Gew9868kq2 dryer , and for
it could be a venting problem cheak out side for a clog and air
Feb 13, 2010 | Whirlpool Dryers
Whirlpool dryer MOD: GEW9868KQ2 wont heat. does turn on ok. have the element out see no breaks. Fuse maybe? where is it located?
You have a bad thermal cut-off . This piece , is a small thermostat looking piece , located ( from the front ) farthest back , on the element housing ( containing the element ) , with 2 wires going to it . Pt # 279769 . This part also comes with the hi-limit thermostat , which should also be replaced .
Nov 22, 2009 | Whirlpool Dryers
My Whirlpool Gold Quiet Partner III dishwasher will not start. I have installed a replacement control board that worked for awhile. When it quit I put the old control board back and it worked for awhile...
Hi Cathy, we are sorry for the concerns. We would advise service with an authorized servicer. If you would like to schedule service please email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and model/serial number.
Apr 11, 2017 | Whirlpool 24 in. GU2500 XTP Built-in...
Whirlpool dryer MOD: GEW9868KQ2 - touchpad not working
Sounds like the control panel may be dead. If you cannot get any lights to come on at all on the front panel, its probably a goner. You can check the voltage coming out of the control pc board via the schematic inside the dryer panel. I have this same exact problem. I replaced the control board 3 times because the panel seems fine if i plug it into an external power supply but will not work when plugged into my dryer. I have my jumpered and running off of a circuit breaker.
Aug 16, 2008 | Whirlpool Dryers
Whirlpool Quiet Partner 980
clean light blinkin???? ry pushing the sanirinse-heated dry--sanirinse--heated dry. tha tshould put in diagnostic mode, there also should be a trouble shooter underthe lower acess panel
Apr 09, 2008 | Dishwashers
Dryers Logo
278 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
