Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
When I turn the TV on, the power light comes on, I hear crackling and sizzling from inside and then the light goes out. Was working fine. Havent opened it up yet
Same thing mine is doing
Posted on Nov 13, 2009
  • 261 Answers
These sounds you're listening to, are one of the ballast symptoms. I would recommend you replace the ballast, because if you keep replacing the lamp, the ballast will keep making the lamp go bad. And trust me you don't want to be spending 110 dlls ever 2-3 months on a lamp because of a defective ballast.
Will not stay on
It sounds like it could be your power supply board. You can get one from tristatemodule or shopjimmy. I personally use tristate its always cheaper and Ive had good luck with them but shopjimmy is pretty good too.
May 13, 2013 | RCA D52W23 52" HDTV CRT TV
TV made a big popping sound, and then a crackling
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php That crackling sound could be of the color wheel:The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9601073A you can find original here:http://www.discount-merchant.com/Samsung-BP96-01073A-lamp-p/samsung-bp96-01073a-lamp-oem.htm?Click=48173 .Have a blessed one!
Apr 02, 2010 | Samsung HL-R5668W 56" HDTV
Is sizzling and crackling normal for a solenoid?
No, sounds like their is something stuck inside .
Dec 20, 2009 | Plumbing
Tv made sizzle pop sound and went out
All depending on the models, but i have seen and work on may units with this problem, there are a few large capacitors on the power supply that are sometimes doubly secured with glue, that in turn becomes conductive and causes faults like this. check all the large capacitors for any low or nil readings and with a fine point probe, carefully remove the glue on the and around the caos, and elsewhere if you see any. Good Luck.
Aug 27, 2009 | Apex Digital GB65HD09W 65" Rear Projection...
There is crackling coming from the horn as soon as the power is turned on, the level of the crackle does not alter with the volume control, the cabinet performs fine otherwise ?????
The horn speaker is wearing out. Inside speakers, there is a magnet, the speaker part is attached to a cone that slides over the magnet, They tend to make crackling noises. Try very gently to apply pressure to the horn and then release. If you hear a scratching sound, the horn will need to be replaced
Jun 27, 2009 | Mackie SRM-450 System
Picture snaps off, Sound still come through.
A crackling sound could mean that the flyback's insulation has failed and it is arcing inside. If that is the case then it may stop working entirely pretty soon. Take it to a tech as soon as you can, the flyback is a pretty expensive part, however if it blows it can break the set to the point that repairs will not be worth it.
Jun 20, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Tv turns off after it gets hot
RCA TV's of that vintage are known for having bad solder joints in the power supply stages and they become very remperature sensitive.
Geno
Mar 17, 2008 | RCA P52937 52" Rear Projection Television
Orange light in the lower part of freezer
pants, don't worry about this, your refer was going into defrost. When this happens, the defrost heater turns on to melt the ice off the evaporator in the freezer comp. Last's about 20 minutes and sometimes you can see the glow and hear the ice hitting the heater...Catriver.
Jan 22, 2008 | Kenmore 53642 / 53644 Side by Side...
Crackling Sound
I just bought a used 60 inch rear projection tv. The picture is fine except I have a crackling sound coming from the front of the tv also. What's the deal?
Jan 16, 2008 | LG RU-44SZ51D 44" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
148 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
