Question about Acer Aspire 5100 Notebook
DSL & Acer Aspire 9410
My DSL connection (ethernet) times out on my new Acer laptop. It works fine on my PC. It continually times out and the pages are very, very slow loading up when they do load up. I have tried using the DSL with no anti-virus programs and no firewall but the DSL continues to time out or not connect at all.
Any advice welcomed because the Acer techs just tell me "I don't know."
Hey kara1.
what os are u running on + what is the error code of the problem
Posted on Jan 08, 2008
    Problem Solver:
  • 16 Answers
In your browser try going to tool and then click on options then goto advance. click network and then settings. check to see if your computer is trying to connect through a proxy server cause f it is then click on direct connection to the internet. I have the same problem that it changes without me knowing until I try to load a new web page. Not figured out how to solve completely but it's a start.
Hope this helps
Acer wont connect to internet with either ethernet or wireless.
There is a possibility that there is a fault with the drivers, you may want to contact your local Acer office as the site drivers are not always the correct one, other than being able to look at it personally you may also want to a good local repair/service centre to test the lan and the wifi card, good luck.
May 13, 2015 | Acer Aspire 5736z 4460 Laptop
Hello, I have a Brother MFC-5890CN Printer/Fax/Copier which has a wired connection to my PC (Windows 7) & works very well. However I would also like to be able to access the MFC-5890CN from my Laptop...
http://download.brother.com/welcome/doc002358/cv_mfc6490w_eng_net_b.pdf
page 14 shows a diagram of router
This above network user guide document also explains configuring the setup
on the back of the printer look for an ethernet symbol
look at
https://openclipart.org/detail/137839/ethernet-connector-symbol
to see what it looks like
then plug in cat 5e ethernet cable (not a crossover cable )
on the back of the router should be several ports with the same symbol .
Mar 31, 2017 | Brother MFC-5890cn Color Flatbed...
Ethernet bridge works fine with three laptops but not new HP.
you should check the wireless interface settings it might be set to work as (802.11a and the bridge is configured to work as 802.11b or 802.11 g) , usually wi-fi interface and bridges by default supports and operates in b and g
Feb 23, 2010 | HP Computers & Internet
My Acer, running windows vista, is not recognizing that it is attached via an ethernet cable, to my verizon dsl modom. Dsl is working on my laptop wireless computer but not on my desk top. The ethernet...
Have you told poota that you are accessing internet?
Go to internet connections, verify your poota has an icon enabled, if showing disabled/enable
If no icons you need DSL setup disc for new connection>
Nov 16, 2009 | Acer Aspire One PC Notebook
Internet connections
Change your ethernet cable from DSL to computer Ethernet port.
Jul 21, 2009 | Acer Aspire One PC Notebook
DSL connection
This could even be the Dsl modem loosing internet sync, They will tell you its you're end and thats fine check the modem, it also could be the ethernet cards going into standby Thus turning off the wake on lan feature in bios or other software would provent the card from going to sleep.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 26, 2009 | Dell Ethernet Card Network Adapter
Printer quit working
try a test page first to determine that the printer has basic abilities.
http://tinyurl.com/6qcpgy
Aug 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
Acer 5420 laptop on D Link DI524 Router
first of all, to check the wireless card on a friends network or a public hotspot, like starbucks. if that internet is slow, then most likely it is your wireless card that is on the fritz. otherwise, if it is fine on these networks there is a compatability issue with your router and your cards. make sure that if your router is very old, it is still compatible with a newer adapter.(e.g. n-wirelesscards maynot work with b-routers. and a-wireless cards will not work with b/g/n routers...or vise-versa.)
Jul 23, 2008 | Acer Extensa 4620 Notebook
Ethernet light blinking
ok this sounds easy
heres your problem you
DsL is a glorified phone connection its not smooth and is always in a state of flaux along with your neighbors there neighbors so on and so forth
technecoly i would run cable connection that does not flaux with neighbors always have a strong signal and wont interfere with your videos
DsL is slow as 58 bit data fax modem i found it a waist of money and time waiting for system to play catch up
now if you want to play videos with out interupt turn off cable dsl modem this will bring function back to normal in video mode
your comps fine its just your service provider
May 09, 2008 | Westell Wirespeed LiteLine 6100...
Acer Aspire 5100 Notebook Logo
113 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
