Question about Motorola Mobility W370 Cellular Phone
My screen is white, i can't see anything
The sound is on.
My dragon touch 7 inch tablet doesnt start up. the screen goes directly to white and it wont go from there
There are a couple things that could cause that. Does it still have sound? If you can hear the sound continue, it is likely caused by either damage underneath the screen, moisture inside it, heat/sun damage, etc.
Jul 22, 2016 | TabletExpress Dragon Touch 7 Black Dual...
Acer All in one multi touch i5 Win7. Start all right, but then screen turn white. Can't see anything.
try reverting to vga mode
http://www.playtool.com/pages/safemode/safemode.html
tap f8 a couple of times after bios shows, then select vga mode in the list
if that works then you can change to a different resolution in display
Dec 31, 2013 | Acer Aspire Z3771-UR20P - P G630 2.7 GHz -...
SCREEN WHITE AND WILL NOT DO ANYTHING
It sound that the main digital board has damaged. Contact any experienced service technician to confirm.
Sep 27, 2012 | Audiovox FPE1907 19 in. LCD Television
My screen is white
sounds like the lcd screen went bad due to water danamge/humitity. problems with water damage is they can start rite away or several month down the road. if you have phone insurance, use it.
Sep 13, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
White screen on the display Can't see anything else except white screen. Front screen is a jumbled mess.
Your screen's wire in the phone was most likely diconnected from a fall or many falls. the front screen sounds like the same thing.
Jun 26, 2009 | LG VX5300 Cellular Phone
Screen is white
Hi
maybe you have defective Flrx ribbon wire or the LCD is the defect.
Thanks!
Dec 14, 2008 | Haier Portable DVD Player PDVD7
White screen
dorub,
you do not get any sounds right?  If no, you need a  new hard drive.  There is no magic fix for a white screen.  Either your hard drive is corrupted..  if no sound it's your hard drive.  If there's is sound it could be your lcd connector.   As a matter of fact it could be your hard drive cable.  At your own risk feel free to open up the mysterious unit and make sure the big metal rectangular prism in there is properly connected.
Sep 30, 2007 | Magellan RoadMate 700 GPS Receiver
Motorola Mobility W370 Cellular Phone Logo
61 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
