Question about Whirlpool Duet GHW9150P Front Load Washer
I have a F25 code pop up and it will not spin
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 107 Answers
If this is the washer and not the dryer then error code:
F25 = DRIVE MOTOR TACHOMETER ERROR
This is a major error you can try some of the items listed below?
If the control is unable to properly detect motor speed, the machine
shuts down. If a failure occurs during high-speed spin, the door unlocks
after 3 minutes.
1. Verify the shipping system including shipping bolts, spacers and
cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive motor and the Motor
Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
Posted on Nov 13, 2009
My whirlpool front load washer will not spin out. its showinf error code F25
According to the tech sheet, F25 indicates a possible drive motor tachometer error. (NOTE: The tech sheet is located behind the front quarter panel- remove the three hex head screws at the very bottom to remove the panel. The tech sheets will be folded up in a little plastic pouch. Since there a various reasons for your problem, I just can suggest starting point since there is a code displayed.
Dec 23, 2016 | Whirlpool Washing Machines
F25 code on 3000 series maytag washer
Google search brought up:-
F25
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
A serious and difficult fault to repair. Call a technician.
Nov 13, 2016 | Maytag Washing Machines
Hi Have a WEC7500VW whirlpool front load washer shows a F25 code . Looked at the tech sheet in washer does not show that code what is it? Also washer will not spin out on high at end of cycle. Did the...
Not sure what you mean but if the washer doesn't spin then it's probably the switch that controls the spin action.
On most washers, when you open the lid or door the spin cycle stops for safety's sake. In many cases, there is a small extension on the door or lid that engages the switch when you close it. Look where the extension is supposed to engage and that's the switch. I was able to fix my broken switch on my GE washer by cutting the edge of the plastic on a pen and gluing it to the extension so it pushed the switch mechanism down further to start the spin cycle.
Hopes this helps.
Paul
Sep 29, 2014 | Washing Machines
F25 error code
The "F25" error code means the control board senses the inlet thermistor shorted. The inlet thermistor is a part of the hi-limit thermostat which is located on the heating element box.
- The hi-limit thermostat kit Part number: AP3094323
Read more: http://forum.appliancepartspros.com/dryer-repair/54078-whirpool-duet-dryer-error-code-f25.html#ixzz2n2Rmgm7a
Dec 10, 2013 | Whirlpool WED9400S Electric Dryer
Front loader maytag stop in middle cycle give error F25
Remove your service panel and look for your tech sheet inside a jacket in the inside of the service panel. An F-25 is usually a broken wire between the main control and the motor control.
Oct 09, 2011 | Washing Machines
Fault code F25
If you remove three screws along the bottom front the bottom panel comes off.
On the inside, on the right wall, is a plastic bag with a paper labeled "FOR SERVICE TECHNICIAN ONLY".
This has a section titled "FAILURE/ERROR DISPLAY CODES" with all the error codes along with an explanation and recommended procedure. For F25, this is:
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
I got this working for many on this site :)
Thanks
Fame !
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Won't spin. Error code F25
Apr 18, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite F25?>
mostly likely need to replace speed control board
Oct 19, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,049 people viewed this question
Dan Webster
Dan Webster
Sal De
