Question about Emerson MW8102SS 1100 Watts Microwave Oven
It runs but does not heat. last nite used the speed defrost now it won't heat for anything made a noise while on speed defrost
  • 464 Answers
Sounds like the magnetron may be gone on it. this creates the heat. if the unit is older, it's not worth repairing, but if newer, check you manual for the warranty. some mags have 3-5 years warranty.
Posted on Nov 13, 2009
I can heat for a few minutes and then the power
Ithink yo timer is not right you must get an technician cause its too complicated
Sep 14, 2014 | Microwave Ovens
Hi sharp microwave R-33ST 900w was used to defrost now won't heat anything up how do I change settings back?
It should default to the highest power setting.
If not, you can reset it by unplugging the power for a minute or two, plugging it back in, and setting the clock.
Otherwise, refer to your owner's manual.
Apr 15, 2013 | Microwave Ovens
I have a GE Profile Spacemaker 2.0, MOD Number: JVM2070SK02 Last week the thing stopped heating anything. Sounds fine, but won't heat. Any tips?
okay thats sounds like you have to take your microwave to a repair man.the HV capacitor can be open or the magnetron is bad these 2 components i mention are responsible for the heating of your microwave if they go bad..then your microwave wont heat.good luck.
Sep 23, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave won't heat anything up. The light comes on, the plate turns round and it makes all the right noises but it doesn't heat anything up.
Since the light and fan work the main board or the processor is working .Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
As there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Thank You for using FIXYA.
Sep 17, 2011 | Belling Microwave Ovens
How to defrost solid frozen thick steak
you can set your microwave to defrost or 50% power to defrost steak
if this was helpful please give it a thumbs up to help others too
May 19, 2011 | Microwave Ovens
Our GE built in microwave model # JKP62G suddenly started making a loud noise when we try to use it. It does this on any power level and on the defrost setting also. It does not seem to be heating...
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Jan 01, 2011 | GE Microwave Ovens
Not heating food, worked last nite and today i can turn on but is not cooking food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 18, 2010 | Dacor PMOR30SS Microwave Oven
Installed a new hmw9305 last nite, no power
Sounds like you blew the fuse. I have a tip at http://www.fixya.com/support/r4223574-microwave_oven_will_not_heat which explains the problem, how to correct it and where to get any parts. Let me know if you need more help.
hardrocko
Thanks for using FixYa and for the generous rating.
Mar 11, 2010 | Bosch HMV9305 Microwave Oven
Have a goldstar microwave apparently made by lg and last nite it just stopped heating everything else works fine just will not heat
Check the fuse between the highvoltage terminal of the transformer and the hivoltage capacitor. If it is Ok replace the magnetron.
May 07, 2009 | Microwave Ovens
Emerson MW8102SS 1100 Watts Microwave Oven Logo
211 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
