Question about KitchenAid Dishwashers
Kitchenaid KUDP02CRB - top rack dishes are not getting clean
Kitchenaid KUDP02CRB - the dishes are not getting clean on the top rack, is it the motor?
  • 161 Answers
Maybe not... if unit is incorporating more than one spray arm,chances are the upper spray arm is not getting water.pull top rack forward,gaze under top rack near rear manifold.slowly push rack back in.notice if manifold inserts into upper wash feed.if so,possible motor issue. if not,bingo was his name-o!
Posted on Nov 13, 2009
  • 464 Answers
I don't think it's the motor. check out the attached breakdown and make sure there are no broken parts where the water feeds the upper spray arm.
The top rack is not cleaning. The dishes on the bottom rack come out clean but the ones on the top rack don't look like they have even seen water?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it
Oct 19, 2010 | KitchenAid 24 in. KUDS02SRSS Stainless...
Top rack dishes not getting clean
When the dishes on the top rack are not getting clean the most common problem is that the water supply hose in the rear of the top rack is misaligned. With the rack empty, pull out the rack and look in the rear where the supply hose slides into the water supply. Often a plastic clip or two has come apart. Realign everything and it will work fine. If you need a diagram go to sears direct parts where they have an excellent website. Enter your model number and you will be able to see a schematic showing each part and how they go together. Joe
please rate my answer as very helpful. thank you.
Apr 04, 2010 | KitchenAid 24 in. KUDI02IR Built-in...
Hey- Two things could be wrong.- clog, or bad motor. Sump screen needs to be cleaned of debris. Removal of sump cover to access screen requires torx bits and some patience. Replacement of pump requires pulling out dishwasher to access bottom. Motors fail when seal between motor and pump fails. Will still operate, but become weaker over time. Parts available- motor about 100$ at appliance parts pros.appliancepartspros. Hopes this helps- Thanks- ED
Feb 26, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishes, glasses on the top rack dont get cleaned. The bottom rack is fine. What may be the problem?
Probably a blocked spray arm. Remove the top spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Jan 25, 2010 | KitchenAid 24 in. KUDS25 Built-in...
The dishes on the top rack are not coming clean
check top spray arm to make sure all of the spray hole are clear
Oct 09, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Top rack whisperquiet dishwasher no water
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/8573754.pdf
I know this isnt the same model, they dont carry your manual as of yet. But it does have some suggestions to look at on page 17. I had the same problem and I looked really carefully and found my sprayer arm was blocked. I cleaned it out and havent had a problem with it again. I do check it regular now.
Sep 27, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
My whisper quiet dishwasher is not cleaning the top rack dishes
I'm having the same problem. Did some testing and found that the sprayer on the top rack is not even moving and hence not getting any water. Not sure what to do.
Sep 07, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
DISHWASHER NOT CLEANING TOP RACK DISHES
I had the same problem (no water being delivered to the top rack) and found that the chopper assembly was completely blocked. I removed it, washed it, put the whole thing back together. It works like new now.
Note that it is not easy to get to the chopper assembly. I used the "pump and motor parts" diagram on http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208193720.pdf. The inlet protector was especially difficult to get off, but I was able to pry it off to expose and remove the chopper assembly. I cleaned all the parts I removed really well before re-installing.
Jun 16, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
Dishwashers Logo
631 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
