Question about Homelite 'Yard Broom' Leaf Blower
Where to get a new pull string for blower?
A broken pullstring on my Homelite Yardbroom Blower
  • 486 Answers
Any lawn & garden outdoor power equipment dealer
Lowes, Home Depot, Menards: get a recoil rope and handle for a Briggs push mower
Posted on Nov 13, 2009
How to replace starter Rope
William, could not find your exact model, the links below should help as a lot of blowers and string trimmers pull ropes are changed using similar method.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Quick and Easy Homelite Weed Wha cker Starter Pull Cord Replacement
How to fix string starter recoil on small outdoor power equipment like...
How to Install Pull Start Recoil for Backpack Blower
Apr 10, 2016 | Troy-Bilt Tb4bp 32cc 4-stroke Gas Powered...
Broken pull cord mac320v leaf blower
The pull string is in a housing underneath the fan. Remove the left (as you're holding the blower with the outlet facing away) housing. The blower fan is visible. Use a 1/2" light duty impact driver, it's a conventional clocking leftie loosie rightie tightie. Remove nut, thick flat washer, fan, and another thick flat washer. Three screws are holding the pull string housing. Remove the housing. Three more screws and thin flat washers, and the spool is in your hand. Reassemble in reverse order.
Apr 15, 2013 | Homelite Consumer Products Backpack...
My leaf blower string will pull out about six inches then it stops.
Hi, the problem can be one of two things. One, the rope may simply be jammed at that point and you just need to pull off the recoil housing and free it up with a screw driver. Two, your engine is seized. If this is the case you're better off buying another because the time and effort to fix these things successfully will outweigh the cost of a new one. Good luck.
Dec 21, 2010 | Homelite 'Yard Broom' Leaf Blower
We are going to reassemble a strater chord on a Homelite gas leaf blower. What is the proper way to do this properly? We want to make sure the return mechanism works.
remember to prewind the pulley in the direstion the string pulls it out, then slip the rope inthru the hole in the pulley, tie a not and then release the pulley and let it pull the rope in.if tou do it backwards you will break the recoil spring
Nov 05, 2009 | Homelite 'Yard Broom' Leaf Blower
Pull cord will not retract
Have to take all 3 plastic covers (housings) off to get to the spring and tie the new pull rope or change the spring. Just did mine, spring just unlatched and string wouldn't retract. Did not have to by any new parts....works great! Took me 1 hour to get it done.
Sep 10, 2009 | Homelite 'Yard Broom' Leaf Blower
Need to replace pull cord
the coil unit comes off blower,the string is wound on the pulley on the underside
Jul 17, 2009 | Homelite 'Yard Broom' Leaf Blower
My homelite yardbroom 2 won't start. Maybe wrong gas/oil mix
Hi
If you remove the fuel you believe to be the mixture out of the fuel tank and refuel with the correct mixture then remove the air filter. Put a few drops of the correct mixture in to the intake it should start. it may take a few times of repetting putting the fuel in to the intake, but eventually it will clean out the bad fuel and run good.Remember to replace the air filter!
Apr 24, 2009 | Homelite 'Yard Broom' Leaf Blower
Yardbroom II pull start hard to pull
put a teaspoon of mix oil into the spark plug hole, some times the metal starts to bind in the engine. keep the wire off and the plug in and pull the cord a bunch of times until it starts to get easier, if you need to add more mix directly to the hole then do it. hope this helps
Mar 28, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite 'Yard Broom' Leaf Blower Logo
153 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
