Question about Frigidaire FRS26R4A Side by Side Refrigerator
Freezer cold Fridge warm - Frigidaire FRS26R4A Side by Side Refrigerator
  • jgonz720 May 11, 2010
    Your freezer coils may be frosted up. This would decrease or even eliminate airflow to fridge. Need to check the defrost circuit.
  • Frigidaire Master
  • 43,501 Answers
Posted on Aug 12, 2010
Emerson compact fridge with freezer compartment freezer is very cold fridge nothing just warm is there any fan to blow air>> thanks
Your freezer fan unit may be frozen behind the inside wall and therefore not circulating the cold air down.
Se if you can remove the screws and back wall to check the fan unit.
Not all modeles can be repaired this way
Jun 04, 2016 | Emerson Cr500 Refrigerators & Freezers
LG french door refrigerator with bottom freezer. Freezer is cold but the refrigerator is warm
Refrigerator Freezer is Cold But Refrigerator is Warm ...
www.repairclinic.com/...Refrigerator/...---/Refrigerator-freezer-is-cold-b...
Refrigerator freezer is cold but refrigerator is warm? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
LG Refrigerator Freezer is Cold But Refrigerator is Warm ...
www.repairclinic.com/...Refrigerator/...-/LG-Refrigerator-freezer-is-cold-...
LG refrigerator freezer is cold but refrigerator is warm? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
4 Reasons Why Your Freezer is Cold but Fridge is Warm ...
www.bestfridgereview.com/freezer-is-cold-but-fridge-is-warm
Jul 25, 2014 - Your freezer is cold but refrigerator is warm? This can be a very big problem. Check Out the top 4 most common problems and their solutions ...
Why is my refrigerator not cooling? - Refrigerator - iFixit
Jan 04, 2016 | LG LFC20770ST
Fridge Freezer not cold
Is there a fan inside the freezer compartment to direct cold air to the fridge? Check it's working. If not fanned, check rear wall of fridge. If not cold, unit may be short of gas.
Apr 20, 2014 | Refrigerators
Kenmore classic bottom freezer refrigeration warm but freezer is cold
I would guess you have just caused a build up of ice to block the air way, which normally takes cold air into the fridge. manually defrost (unplug and wait until the ice goes away) then restart and it should be fine
Nov 11, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Maytag fridge (model MBB2256GES) freezer cold but fridge warm
Sounds like one or more of ofvyour 3 defrost components have failed which are defrost heater , defrost thermostat, and defrost timer or board
Nov 06, 2017 | Maytag MBB2256GES Bottom Freezer...
FREEZER IS TO COLD, REFRIGERATOR TO WARM
if you can; find the vent(s) between the top and, bottom boxes (where the evaporator fan is located: closing these vents makes the freezer colder and, the refrigerator warmer, opening these vents the reverse is true.
Jul 19, 2010 | Frigidaire FRT17G4B Top Freezer...
Kenmore refrigerator Freezer is cold but fresh food side is warm
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jan 26, 2010 | Kenmore 57029 Side by Side Refrigerator
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Jan 05, 2009 | Frigidaire FRS26ZSG
Frigidaire FRS26R4A Side by Side Refrigerator Logo
78 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
