Question about Fujitsu LifeBook A6020 PC Notebook
I have a fujitsu lifebook that will not charge my battery. I replaced the ac adapter, and i replaced the battery and continue to have the problem
  • 247 Answers
Bad power circuit on the motherboard. Usually part of the motherboard and thus would require motherboard replacement to fix the problem.
Posted on Nov 13, 2009
I have a fujitsu lifebook A series, Model AH531/GF0, it will not receive current from my ac adapter. The computer is total blackout. What is the main problem of said lifebook?
Please check the voltage at the pin end of the laptop using a multimeter in the voltage range. If absent then there is fault in the adapter and must be opened to confirm or replace.If present then connect and check the voltage at the pin end of the battery terminal in the laptop , if present the battery is a suspect.Check this link: http://www.fixya.com/support/r5164850-laptop_power_supply
Jan 17, 2012 | Fujitsu Computers & Internet
How do you replace the fan on a Fujitsu s2210 laptop?
How to Replace a Fujitsu LifeBook S2210 Fan
1. Follow your laptop owner's manual and assembly guide carefully as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, DVD drive , Ac adapter and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive, screen sled.
3. Turn the laptop over and remove the screws on the bottom that hold the keyboard in place. Flip the laptop over, open it, then lift the keyboard up and out. Unplug the flexible ribbon cable that connects the keyboard to the motherboard.
4. Remove the screws that hold the laptop keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the Fujitsu LifeBook S2210 CPU Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and cpu cooling fan. Replace the screws, plug the Fujitsu LifeBook S2210 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new Fujitsu cpu cooling fan running and feel warm air blowing from the vent on the side of the laptop. A Fujitsu LifeBook S2210 Fan does not run continuously, so don't be concerned if the Fujitsu LifeBook S2210 Fan shuts off periodically.
Jun 26, 2011 | Fujitsu LifeBook A series AH550 NoteB......
Fujitsu lifebook blinking battery led, bad ac adapter?
i would try purchasing a universal laptop charger on ebay and see if it works. they are under 25 bux. worse case scenario you will have a backup ac adapter. be careful plugging in other ac adapters because the polarity could be wrong or it could have to much amps
Jul 11, 2010 | Fujitsu LifeBook A6025 Notebook
S6010 will not charge battery and will not work on power lead
Are you seeing the battery or power light on the laptop go on when the ac adapter is connected? If not, it may be the ac adapter, or usually the charging port. I have had to change charging ports many times. But if you get no lights, it needs either a new charger, and if that doesn't change anything, it needs repair.
Dec 16, 2009 | Fujitsu Siemens LifeBook S-6120D Notebook
My lifebook s7010 won't startup. After put the on button the screen still remains black. The fujitsu logo will not appear on the screen.
Unplug the AC adapter from power cord, then remove the battery.Wait 30 min and put the battery back.Plug the AC in power cord and try again.If not start you need check AC adapter with voltmeter.If the AC working your computer need service.
Nov 10, 2009 | Fujitsu Siemens LifeBook S7010 Notebook
I have a Lifebook N3520 and just replaced my battery but is not charging. MAchine is about 3-4 years old. Do I need to update my Bios?
I assume that the battery you referring is the main battery pack. If I am correct, I am sure that your problem is the battery pack itself. These are usually Lithium Ion battery and they only have a life span of ~3 years. There is no need to replace your BIOS if your PC is working when it is powered by the AC adapter.
Oct 06, 2009 | Fujitsu Siemens LifeBook N3520 Notebook
Charging Fujitsu Siemens D7830
Have you ever replaced your AC Adapter, if yes than replace AC Adapter with an OEM....
Jul 22, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Fujitsu LifeBook A6020 PC Notebook Logo
565 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
