Question about Motorola Mobility MOTORAZR VE20 Cell Phone
I'm trying to adjust the volume up for hearing the caller as I don't hear the best. VE20
How do I adjust ringer volume on wired ATT two Line phone model 993
VOLUME buttons;
During a call, press to adjust the listening volume.
While the telephone is not in use, press to adjust ringer volume.
Oct 30, 2014 | 3M 993 Two-Line Corded Speakerphone with...
Where is speaker on alcatel cell phone?
? Microphone? For the other person to hear you the microphone on the phone must work. You cannot adjust that. For you to hear them you need a speaker on your phone. You can adjust the volume of the speaker on your phone. If callers cannot hear you try putting your phone on the speaker, rather than handset mode so it becomes a speaker phone. Then, while talking to someone to test the phone, try holding it in different ways to see if you are covering the microphone with your fingers. Without knowing what model of phone (specifically) you have I can't figure out where these are located on your phone. You can google the model though and locate them yourself easily.
Aug 31, 2014 | Alcatel Cell Phones
My callers cannot hear me
Check to see if you have it on mute. Go into your menu options and under sound hit ok It should show master volume, keypad, earpiece,speaker try master volume then volume up .
Dec 20, 2013 | LG Dare VX9700 Cell Phone
I can't hear peoples voices when they call. The volume only works for the ringer
If you want to change volume of the caller's voice, then try adjusting the volume control WHILE you are actually talking on the phone during a call.
If you try to adjust the volume when there is no call in progress, then the volume controls will only change the ringer volume.
If you provide the exact model number of your particular device, then we may also be able to provide you with the User's Manual for your phone.
I hope that was helpful Loli.
Good luck and take care.
Joe.
Dec 09, 2011 | Apple iPhone Smartphone
I can hear callers but they cannot hear me. Mute is not engaged,
Please see the link below for the User's Guide.
• Headset is muted. Long press (3 sec.) the volume down button on headset to unmute the microphone. See page 16.
• Improper positioning of voice tube. Try various other positions.
• Voice tube may be clogged. Remove voice tube and test to see if callers can hear you without it. If they can, then replace the clogged voice tube. See page 18.
• Speaking volume is too low. Increase the speaking volume by
adjusting the speaking volume minor adjust buttons on the base unit as described on page 16. If the volume is still too low, select another speaking volume major adjust setting as described on page 16.
• Incorrect configuration dial setting for your phone. Try other
phone configuration dial settings on the base unit. Ensure the
selected number is in line with the position indicator. See page 14.
Plantronics CS70 User's Guide
Good luck from Headsets Direct!
Jul 18, 2011 | Plantronics CS70 Wireless Headset
Incoming calls: the caller can hear me but I can barely hear the caller
If you have already adjusted the volume of your cellphone, then the problem is in the earpiece. If the phone dropped accidentally the earpiece loosens its contact and you need to open the phone to adjust the contacts. If the phone was not dropped, the earpiece is busted and needs replacements.
Nov 02, 2010 | Motorola Mobility RAZR V3
I can hear the caller but caller cannot hear me on 29870GE1-A digital answering machine
Hi, Please check whether the mic has gone bad in your handset.
the connectivity is just fine as your are able to hear the caller. but if you think there must be something wrong with the caller's phone, try calling someone else and check.
please let me know if you need more help. Thank you:)
Oct 23, 2010 | GE 29870GE1 Corded Phone
Low volume on calls. cannot hear caller unless i'm in an absolutely quiet room. I have the master volume at max. also, the flash is so bright that the pics i take are overexposed. Can i shut the flash off...
for the low volume, the fault is from the earpiece. Trust me, I faced this same problem and when I changed the ear piece, I began to hear calls clearly.
You could also get a earphone and use it to receive and make call pending the time you get the earpiece fixed. Earphone will even be much louder.
Concerning the flash, do some adjustment settings as you rightly suggested.
I wish you the best.
Dec 31, 2009 | Cell Phones
During the call I cannot hear the caller very well
chnge the spekar nothing slove your problem than jumper setting
Mar 07, 2008 | Nokia 6030 Cellular Phone
Cannot hear incoming call or caller cannot hear me
First check and adjust call volume. It should set be optimal and secondly during a call adjust the microphone volume. If this is ok and the problem exsist then the microphone, speaker or some other hardware need to be replaced. Contact local hardware expert.
Aug 25, 2007 | Palm Treo 650 Handheld
Motorola Mobility MOTORAZR VE20 Cell Phone Logo
90 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
