Question about Betty Crocker BCF1350 Work Top Blender
Worn Gears I believe that the plastic gears on both the Jar and motor are worn, so when under very little pressure, it slips and is ineffective. Is this possible and if so, can they be replaced?
  • Anonymous Jan 08, 2008
    How do I order the the gear that is attached to the jar?
  • Jose Mederos Feb 22, 2008
    Gears needed for GE Blender Model 169053
  • 619 Answers
Kitchen ... Betty Crocker Store where you can find Cookware, Small Appliances, Cutlery, Kitchen Tools, Bakeware, Tableware, Barware, Storage products and more.
Hi, yuo may ask for the answer of parts needed.
Posted on Jan 14, 2008
Blender glass jar is leaking at base
It will either be the rubber gasket (it goes between the glass jar and the blade assy) or it could be a worn bearing/bush around the chopping blade shaft. Replace either the gasket or the blade assy.
Apr 02, 2014 | KitchenAid 5-speed Blender With Glass...
Ninja blender motor part is wore out
-I don't think they carry any replacement parts for Ninja Blender.
-Possibly not the spline plastic.
-Inside on top of the motor there is a planetary gear there. Possibly worn out or lose screws as well that not hold it in place to mesh together.
-But before you can reach to these parts you have to take the bottom cover off, remove the plastic spindle. IT's very tight.
Good luck
Jan 11, 2018 | Euro-Pro Ninja 1000 Watt Prof Blender 3...
Leaks at the bottom of the glass holder
I'm no expert but in my experience if it leaking at the bottom then either the jar /carafe has a few chips or cracks around the hole in the bottom that the blade fits through and in that case you need to replace the jar and your blade assembly may still be good and can be moved to a new jar/carafe. Or the blade assembly has come loose a little and need to be tightened or some the washers (usually the rubber ones) have worn out and need to be replaced. There's plenty of explanation here at amazon and else where on how to replace the assembly blade, move it to a new jar and tighten it down, etc. Hope this helps!
Sep 26, 2013 | Waring Blenders
Leaking blender jar
If it is not the HUGE blade retaining ring under the beaker a bit loose then you will be buying new parts to repair it. The only other possibilities are beaker cracked and leaking (new beaker) or bearings & seals worn (new blade & bearing assembly)
Oct 30, 2012 | Vitamix Super 5000 Work Top Blender
Sounds like gears are slipping and blades stop turning. no obvious damage to drive socket or gear on end of blade shaft.cant remove drive socket any suggestions on removal? Blade assy fits very loosly into...
First thing is to find the small hole on the plastic piece below the drive socket and remove the silicone in from it. Next turn the drive socket until the little arrow on the drive socket lines up with the hole, then look thru the hole to see the allen wrench screw in there loosen screw to remove drive socket.
Sep 15, 2011 | Vitamix 5000 Work Top Blender
The coupling to the motor is loosely rotating on the motor shaft. Has the threads on the coupling worn out. it is a breville optiva cbl6 blender
The coupling bush wear out in due time and must be replaced. if there is a wearing detected it must be changed or it will result in failure of the bush/ bearings of the motor and jar. You will need to remove using anti clockwise direction, Get the correct spare part from the dealer to replace. Good day
Aug 16, 2010 | Blenders
I need a replacement jar for a GE Blender model 169053
By now I'm sure you've given up, but do you still need the jar? I have one that is now useless to me since my son tried to run the blender when the jar and base were not seated correctly and the rotors on both were worn off.
Aug 17, 2009 | Back to Basics Blender Solution 5500...
Plasic gears
Not usually is the short answer. If you can find a Sharp repairer who may have that part in, they can repair it. Or contact Sharp customer support services (google the company where you are).
In the UK Sharp have more or less closed down most of their Household Appliances other than their microwaves and it is difficult to source parts generally.
Jun 27, 2009 | Sharp EJ-12GDW Work Top Blender
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
Drive gear is slipping. Motor turns but the blade fails to turn
sounds like a shear pin either on the motor or the blade assembly. If you put the blender on low without the cannister on top touch the gear on top of the unit and see if the gear slips or stops. Use a pencil or something..Not your finger. If it stoops then the pin is broken at the motor. If not, it is broken at the blade unit.
Hope this helps
Mar 17, 2009 | Back to Basics Smoothie Jr. B Work Top...
Betty Crocker BCF1350 Work Top Blender Logo
561 people viewed this question
Top Betty Crocker Blenders Experts
Are you a Betty Crocker Blender Expert? Answer questions, earn points and help others
