Question about Proscan PS32125 32" TV
3 inches missing on both sides
Hi, I have a 1997 Proscan PS32125 tv and for a few years I have been missing like 2-3 inches of the picture on both sides of the screen. Is there a way to fix this? Thanks a lot.
  • bernimx Jan 08, 2008
    It is actually cutting off like 3'' on both sides (I lose 6'' total of what should be on the screen). I went over the menu and can't seem to find anything...
  • bernimx Jan 18, 2008
    bump?
Bump for help please.
Posted on May 03, 2008
  • 579 Answers
Sounds like it is a widescreen TV stuck in standard view mode. Should have a menu option called widescreen or movie format.
Do you see the whole picture squeezed down or is it actually cutting off the sides of it?
Posted on Jan 08, 2008
Shrunken picture
HI!
can you take a picture to your tv to see exactly what happen to your vertical problem!? then you can post here thanks!
Nov 02, 2007 | Proscan PS56670 56" Rear Projection...
My tv is stuck on a channel
You have a problem with a internal circuit.you can try by, powering off the tv for about one day. then turn it on again
Dec 15, 2008 | Proscan PS32125 32" TV
36 INCH 1997 - 1998 SONY TRINITON
Proceed with caution! High dangerous voltages exist within.
Check the current sense circuit from the aquadag coating.
Jul 15, 2017 | Televison & Video
Proscan ps52810 52 inch projection - composite/HD problem
I want to know where is the fuses because I can't start my t.v. manual or with the control I open the back and front can see no image no contact nothing what can I do?
Mar 10, 2008 | Proscan PS36600 36" TV
Tv shuts on and off by itself
This tv may have a defective flyback transformer . Your chassis # of this set indicates it is ctc197 . some of these sets also had weak caps in the power supply or loose connections in the horizontal section . If your set clicks like it is coming on then clicks right back off and does this a few times then i would say it is the flyback transformer . If not suspect the other circuits as your problem . A shop might charge between $80.00 to $120.00 to fix it . If you can't fix it , call around to get the best price . Good luck
Mar 07, 2008 | Proscan PS32125 32" TV
Proscan PS 50670
try soldering the tuner connections RCA/proscan have had some issuse with the solder around the tuner.
Feb 24, 2008 | Proscan PS52800 52" Rear Projection...
Proscan PS61700 Beeping no picture
I have a 60in Proscan Projection TV. My picture is out and the TV only beeps.
Brian Allen
Feb 03, 2008 | Proscan PS61700 60 in. Rear Projection...
Very poor picture
  • your problem is called picture with retrace lines.
  •  your problem is in video output circuit
  • as you are saying that it was off for a year that means there is possibility of loose contact in that section.
  • plz check the following
  • supply to video output absent or loose print.
  • loose connector in crt base.
  • crt base loose
  • voltage on screen control or g2 absent or wire loose.
  • screen control located on flyback transformer mistuned.
  • hope this will help
  • good luck.
Oct 19, 2007 | Proscan PS32125 32" TV
Picture problems
Sounds like a problem in the main power regulator circuit, such as a bad capacitor or regulator IC or transisitor. There are no user serviceable parts inside these sets and every thing is soldered into place. I recomend that you call in a trained service tech to assist you with this repair.
Sep 25, 2006 | Proscan PS50670 50" Rear Projection...
Televison & Video Logo
194 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
