Trouble!! My TV turns on . I can hear the sound perfectly fine with or without other devises pluged in, but the picture doesn't work. I can't figure out the problem. can some one help. it squealed and then lost the picture
  • 54 Answers
Hi???ahem im not an expert one but i think theres something wrong with its flyback or the current entering into your picture tube....!!!
Posted on Jan 08, 2008
My 32" LG LCD is losing its resolution; picture washed out but sound working fine, any ideas?
Check your settings, you might just need to track and reinstall all channels again...sometimes caused by bad weather/showing
( no signal ) or you can see your manual trouble shooting guide.
Hope this tip helps.
Aug 03, 2015 | LG Televison & Video
Can this be fix, And is there a video on how to fix it and what tools you need ?
This happened to me... I unplugged the tv for 10 seconds and e everything worked fine when i pluged it back in .
Dec 23, 2017 | Philips 51PP9200D Television
Buzzing sound + Tv picture is very weird.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} CHANGED Z SUSTAIN BOARD.PICTURE PERFECT.APART FROM WHITE DOTS.. AND ALSO ALL FUSES AROUND IT .THINK IT COULD BE DUST OR FINGER PRINTS ON RIBBON JOINTS,,WILL RE CHECK AND WIPE F/PRINTS TO SEE IF ANY CHANGE.
GOOD LUCK
May 23, 2010 | Polaroid TLA-01911C TV
Advent ht3251a wont turn on
working on same model same symtons,pluged sys into a vareact tv came on normal,problem gone.set works ok when plug into ac outlet.can,t say what cause problem,set work ok now without veriact.will air test three days to see if probem returns.will try freez spay on chips.
Feb 20, 2009 | Recoton Advent Advent HT3251A TV
Trouble!!
sounds like a loose video cable. Check your connections
Mar 03, 2008 | Mitsubishi VS-60601 60" Rear Projection...
PS32500 32" TV Problem
The sound that you hear is coming from the sound detector not working or not receiving any audio. If the set is set to a second audio (SAP) program this could be you trouble. Some programs are broadcast this way. (such as Spanish for Spanish speaking people. Check you audio program settings.
Stargazer
Feb 19, 2008 | Proscan PS32500 32" TV
My TV pictures turns black afetr a few hours but I still can hear sound perfectly!!!
It sounds like your rptv lamp is going out. If this is an older DLP this is most likely the cause. You can get a replacement at www.laptopsforless.com part number BP96-00224J for $151. If the tv is still under warranty, I would have them do it, otherwise replace it yourself. If so here is a link to give you step by step instruction. Please give me a good rating. ;-)
Dec 18, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Trouble!!
Most of the time when theres no picture on a mitsubishi projection set, theres no verticle sweep. Most likly cause is the verticle output IC or the b+ feeding the IC or Both. This is not a consermer replaceable parts. It could also be the PIP module if the set has one . Remember these sets have alot of hi-voltage even when the sets unplugged. Good Luck
Jun 22, 2006 | Mitsubishi VS-5059 50" Rear Projection...
Trouble!!
If you have sound and no picture you either do not have any high voltage, the CRT emitters are not powering up or there is no video drive to the crts. A long shot would be the brightness is turned down but unlikely. The most likely problem is no high voltage. Odds are the Horizontal Output Transistor is open. This is easy to check with a vom if you are familiar with TVs. If not have a professional do it. TVs are dangerous and complicated. If the HOT is open it will need to be replaced along with either/and the flyback and HV divider block. If the Horizontal Output is ok the problem could be just about anywhere. First you need to make sure that all necessary voltages are present and correct. After that you need to determine which circuit or section is not working. At this point the sound is the only thing you know works. Good Luck.
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
