Question about McCulloch Garden
Fuel line from fuel tank to throttle switch ? broke need to order eager ****** mini pro 2.1 ci 16 inch cant find part #er thanks for your time
  • bailecharles Nov 13, 2009
    eager beaver mini pro 2.1 ci 16 inch chain saw the fuel line from the tank to the throttle switch broke where can i fine a parts list to give me order #er to order
  • Roland W VanLue
    Roland W VanLue May 11, 2010
    model numbers from the ID tag please, and the name as it is listed on the side of the saw. aprox age or date of purchase. thanks, rwvanlue
    President:
  • 2,220 Answers
On the bottom of your saw is a tag with the serial number (i.e. 13-24475) and model (i.e. 600093C).
An IPL number for any McCulloch parts source can be created using the hyphenated serial number and complete model number (i.e. 13-600093C) = “YourCreatedIPL#”.
Use the IPL number you created here:
M&D Mowers
http://www.m-and-d.com/parts.html
Click “Illustrated Parts Diagrams ON LINE”
Click “Click Here for Parts Lookup”
Changes to “Select OEM” Window reads “Briggs & Stratton ▼” Click the arrow and select “McCulloch Power”
Click “Gasoline-Powered Chain Saws”
Click ““YourCreatedIPL#”. HTH
Lou
Typical fuel system:
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly. HTH
Posted on Nov 13, 2009
    Scholar:
  • 110 Answers
There are no new parts available for the old McCulloch products, Search the web, or call Eds mowers in charleston SC 843 557 555
My fuel lines all broke and fell apart, I need a fuel line diagram
Hi chuck belew...
Check out the diagram below.
I believe this is what your looking for.
Please take time to rate me
Bud
Oct 11, 2012 | Poulan Pro PP3416 16-Inch 34CC Gas...
What is the correct fuel/oil mixture for an older Eager ****** 16 inch chain saw?
It really depends on the model number of your Eager Beav er unit. Anything within the last 6 years is 50 to 1 older models can be anywhere from 25 to 1, to 32 - 1 up to 40 - 1. t all depends on the model number.
The usual fuel mixture is 40 - 1 or 3.2 oz. per gallon.
Your chain saw would have to be pre-1995 to use a mixture greater than 40-1. If your chain saw is other than that then use a 32 - 1 ratio. 4.oz per gal.
This is a great fuel mixture calculator:
http://www.csgnetwork.com/oilfuelcalc.html
If you know your model number you can use this page to get an owners / operators manual:
http://www.mccullochpower.com/node7877.aspx
Jun 16, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Will not start type III 2.0 C.I. 16 inch chain saw
Remove the spark plug and test for snappy, blue spark. If nothing, try a new plug. If still nothing, remove the left side cover to expose the flywheel and ignition module. Remove the wire from the module that goes to the ignition switch and retry for spark. I now ok, look for problems with the ignition switch or possibly, the wire is grounding out somewhere. If still no spark, replace the module itself. Use a thin business card for a pole gap gauge, rotate the magnets under the module, set the gauge in the gaps, loosen the mounting screws and allow the module to stick to the magnets. Re-tighten the screws, and rotate the flywheel to remove the card from the gap, then turn the flywheel one complete revolution while checking that the pole gap does not close up at any point. Recheck for spark. If now ok, place some fuel mix in the plug hole and pull through--it should pop several times and maybe even run. If you get only pops, then check the fuel system lines and the filter in the tank. Make sure that the air cleaner and muffler are not plugged. Hope this helps!
Jun 18, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan Pro 220 saw starts & runs fine when finger on throttle, will not stay at idle. Rplaced plug & same issues.
All you need to do is try to adjust the throttle idle speed or else a cheat would be to tighten the cable which means the cable will be pulling very slightly the throttle which means it will remain running when u release throttle.
Nov 05, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have a poulan 2150 chainsaw. I replaced the
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb refills).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Oct 25, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
NEED A FUEL LINE DIAGRAM FOR POULAN 2250 2.2 C.I 16 INCH BLADE
The smaller size line comes out of the tank, leave enough to install filter on that line in the tank, this line goes to the intake side( I think it is the right side of the carb when it's mounted in the saw), of the carb. The other smaller line goes from the other side of the carb to the primer bulb. The larger line goes from the other side of the primer bulb back to the tank, it only has to be pushed in the tank about 1/2 to 3/4 inch. The large line goes in the tank in the hole on the right side unde the carb. The primer bulb has different size nipples. I just put these on mine, it's hard to get the lines in the tank, I sprayed mine w/wd40 and just pushed them in until I could pull it with some needle nose pliers or hemostats.
Apr 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a poulan pro 220 16"
Carb has 2 inlets top inlet connects to tank line with filter on it. Bottom inlet connects to bulb other line from bulb returns to tank on bar side.
Feb 28, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have poulan 2075oc that floods out as soon as u pull started rope.you pull it one time and spark plugs is real wet with gas.Saw set for long time with gas in tank and i had to replace all the fuel lines...
you need to open the carb up and take the old fuel line out of the carb filter.....if it is left.the needle is probaly stuck in the open possition letting to much fuel to go to cylinder
Jan 23, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
566 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
