Question about RCA HD56W58 56" HDTV
I can turn the set on but it doesnt put out any picture,and it makes a high pitched ringing sound
  • RCA Master
  • 8,457 Answers
Ur high voltage is dead,the FBT the big block of plastic with a red wire hook to a board.That thing is dead.U know how to solders,Website, Tv repair World.com buy the part.
Posted on Nov 13, 2009
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
Dec 16, 2015 | LG 55LE5400 TV
Surround sound troubleshooting
The ringing is a power supply that has gone into protect mode due to a fault.
It needs to be sent for repair.
Jan 19, 2018 | RCA Audio Players & Recorders
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
High pitched ringing sound from my tv
It most likely is coming (based on model number listed here) from the high voltage transformer---ways to silence that up to and including replacing that part.
Jun 16, 2012 | RCA HD52W59 HDTV Projection Television
High pitch pulsing & picture now
I would check the set for bad connections. The high pitched sound you are hearing is the high voltage section. If the convergence IC has completely failed, that can cause this as well. Try using STK392-150 or STK392-180. Either one will sub since they are pin compatible and they both can handle more power, thus should last longer. Also, make sure that you use plenty of the heatsink compound when mounting these.
Dan
Jun 26, 2008 | Philips 43PP9202 43" Rear Projection...
High Pitch Sounds
In this model the horizontal drive coil vibrates and makes a high pitch squeal. Most times it is intermitent. Touching on the coil with something (non electrical, like wood) will make it stop or change it's pitch. The fix my shop uses: It's not to technical, but, we put fingernail polish around the coil. It's a remedy I've used for decades and has always worked. Some shops use a hot glue gun. With the back open you can hear the coil to locate it. When fixing the problem have the set unplugged. When a technician is working on a television while it's plugged in. He uses only one hand and stays away from the high voltage.
Jun 25, 2007 | RCA HD52W59 HDTV Projection Television
High pitch sound and fuzzy
The high pitched sound, probably not, unless you open this TV set and find out what is making the noise and replace the part. Most likely a coil or transformer is vibrating so fast that the frequency is very high. On the focus, possibly can be adjusted. Now when you take off the back of this TV set, i must warn you, follow my instructions to the letter as there is enough High Voltage in this set to make a grown man cry! After you take out all of the screws off the rear cover,carefully lift up the cover straight up. Oh by the way the TV should be face down. Opps! Not stand back up the TV set and there will be a Grey or black block like looking thing with a large red wire going to the top of the picture tube. on this block you will find two controls, one will say screen, and the other will say focus. DO NOT ADJUST ANYTHING ELSE WHEN YOU ARE IN THIS TV SET!!! No slowly rock the focus control back and forth till you get the sharpest picture. Put back on the back cover and enjoy!!! Good Luck
Jun 13, 2007 | Samsung TXJ2879 28" TV
High pitch ringing noise and picture distortion
Sounds like the capacitor that goes bad just before the hIgh Voltage transformer goues bad. If i were you I would call an authorized RCA repair Shope and see if this is going to cause more damage to your set in the future.
Aug 25, 2006 | RCA HD52W59 HDTV Projection Television
RCA HD56W58 56" HDTV Logo
131 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
