Question about Frigidaire FEF366 Electric Kitchen Range
Oven overheating element will not cut off already replaced element and temp probe
  • 464 Answers
Sounds like you have a runaway clock, is there any code coming up on the ERC?
Posted on Nov 13, 2009
Oven is overheating and keeps cutting out
Might need a new temp probe. The temp probe tells the board the oven temp, but if it fails the hi limit switch shuts the oven down when it gets too hot. On the back of your range there should be a tech sheet in a pouch. It will have resistance values for your temp probe.
Jan 30, 2011 | Ovens
Sometimes the oven works and sometimes it doesn't. I replaced the oven temp probe and all was well for about a month and now it is happening again. I had to cut off the clips to the new probe and the...
hello,
Have you check on the element to be alright ?
but am sure that it is a powering problem may be you change the wire and the element at a time and make sure you are buying the original thermostat from the same company for easy compatible .
Thank you and thanks for using fixya.
Sep 18, 2010 | Frigidaire FEB27S5A Electric Single Oven
The oven wont heat up.
Hi.
Since the oven has two heating elements, if the oven does not heat up on any condition, and both broiling and baking element are not working, then the most common fault causing the problem is a faulty temperature probe.
The temperature probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electronic oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reaching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Mar 03, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven has stopped heating up
Hi.
This oven should have two elements.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electroning oven control to baking and broiling element.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
Regards.
Mar 03, 2010 | Baumatic B180 Electric Single Oven
I have bought a replacement main oven Thermostat for a tricity bendix Town & Country Mod no SIE459TCGR the conections on the replacement thermostat 46THC15/F5G1E2 are different from the original can...
Hi.
This is an universal replacement part, that is the reason why it is different from your TB original part.
The thermostat should have the temperature probe already attached.
Fit temperature probe and thermostat, then connect the element (s) wires on one side of the thermostat. The order in which you connect element polarity to thermostat does not matter. The thermostat will cut off power to element when the specific temperature is being reached by the temperature probe.
Dec 12, 2009 | Ovens
Oven does not reach set temp
What are using to measure temp ? Are you using a grocery store bi-metal or professional thermal probe ? and further to that, how long are you waiting to check temp. after range "beeps" or announces preheat complete ? The bi-metal type thermometers do take several minutes longer to reach actual temp as opposed to the ranges temp. probe. Does this unit have the "hidden" bake element ? That sounds like a huge temp difference. These units do require an additional 10mins of wait time after announcing ("BEEP") the preheat is complete (check your manual, it should confirm this) Elements don't go "bad" it either comes on (amp draw) or it doesn't.
hope this helps.
good luck
Sep 26, 2009 | Frigidaire Ovens
My oven's bake/broil element won't heat
It could be the stat (temp probe) or the cut outs. if these are faulty then it will not allow the elements to heat up
Sep 21, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Already replaced heating element in lower oven and the temp still will not remain constant
Oven temperature problems are commonly attributed to a faulty oven temperature probe. The following link explains how to replace one:
http://www.fixya.com/support/r393313-checking_replacing_oven_probe
A replacement probe can be purchased on line at appliancepartspros.com. Just type in your model number and look under the "Cavity" heading for item number 3. The part number is AP4009009.
If you measure the oven probe and determine that is NOT the problem, please let me know. I hope you find this information helpful.
Mar 30, 2009 | Maytag MER5775Q Electric Kitchen Range
Hotpoint oven overheating
Yes this is repairable, the probe in oven called a thermostat,that wire that goes out the back small hole goes up to the oven temp. knob ie thermostat. part # .WB20K10004 you can find it at
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=824183&PPStack=1 about $60.00 good luck
Mar 28, 2008 | Kitchen Ranges
Re: oven
the temp probe ( rod sticking out of rear wall inside oven ) should ohm out at 12-1300 ohms at room temp. the other possible cause is the heat relay on the control board is bad .this does not display a fault code.
Jan 17, 2008 | KitchenAid Architect Series KEBC107KSS...
Frigidaire FEF366 Electric Kitchen Range Logo
245 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
