I have a t or f 1200r-b velodyne subwoofer that as soon as it powers up it emits a loud humming niose even after the patch cords are out. I know that it is a old unit but I have enjoyed it for many years
SOURCE: Major buzz/Humming sound coming from my subwoofer
supid ******* thanks for the suggestions *******
Posted on Jun 04, 2008
  • 124 Answers
SOURCE: My Velodyne CT 80 powered subwoofer does not power on?
Fuse in amp may be blown or the amp is dead
Contact Velodyne, the replacment amp is not very expensive
Posted on Jan 04, 2009
  • 124 Answers
SOURCE: I have a Velodyne fsx-12 subwoofer. Problem is
Velodyne is the only source for parts and service on this unit.
You will need to contact Velodyne
Posted on Sep 21, 2009
  • 144 Answers
SOURCE: mirage s8 subwoofer is emitting a constant hum
that is just the radio from the input,its normal
Posted on Jun 19, 2010
SOURCE: Velodyne F-1800 RII Subwoofer Fuse
I am having the same problem... call Velodyne... if you have the coke can thing with the pink stuff it can't be repaired.
Posted on Jan 02, 2011
Velodyne ct100 loud humming +speaker drown backwards.Can I fix at home
The loud humming could be caused by a cable on the input that is not grounded. It could also be caused by some sort of power supply failure.
Feb 10, 2016 | Velodyne Audio Players & Recorders
Have an older (6 + Yrs) VX-10A model, that's worked fine up until now. I recently moved, hooked up the same stereo and surround sound speakers, which worked fine, but the subwoofer made a loud hum as...
Disconnect the input and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
Mar 03, 2011 | Velodyne VX-10 Subwoofer
I am having a problem with my Velodyne f-1200r subwoofer. It pops and cracks then shuts itself off. This happens on a passage of music or theater at even moderate volumn. There is no problem with driver...
If you can test the capacitors in the power supply you might just locate the issue. Would need to remove and use a cap tester. Bad ones can look just as good as new ones.
Sep 07, 2017 | Audio Players & Recorders
Speaker makes a rather loud humming noise.
You can go buy a audioquest SUB-X subwoofer cable with a additional ground wire on it an connect the ground cable to the ground slot of the receiver an the other end to a screw on the sub or into one of the high output terminals on the woofer if it has them an this will take that humming sound right away but the cable is around $90
Mar 28, 2010 | Velodyne HGS-10 Subwoofer
Humming sound when on/off
humming sound when on is usual if the volume is turned up.
humming sound the same when on or off could be transformer plates fluxing.
if loud recommend replacement of power supply.
if ok then recommend unplugging the device after use.
Nov 13, 2009 | Velodyne DPS-10 Subwoofer
When powered on speaker pushes all the way out
The problem is in the Amp. Velodyne is the only place you can get it repaired.
You will need to contact Velodyne for service
Mar 20, 2009 | Velodyne SPL-1500R Subwoofer
The power fuse blows as soon as the unit is plugged in
There is a problem with the amplifier within the sub. Many of these units never completely turn off. They are often set to automatically startup when a signal is detected. This may be the case here. The loud hum as a defect in the output amp section. At this point you probably have a blown amp section. The "protection" for this is to cause a dead short that will open up the fuse. This unit will require service. It is unlikely that any service info is availabel to the general public either.
The fix could be simple, but without seeing the unit, I can not state that for sure.
Keep us posted.
Dan
Feb 03, 2009 | Dual L8SW Subwoofer
Not working until the power switch is toggled
Try turning up the sub output on the onkyo.
Aug 05, 2008 | Velodyne CHT-10 Subwoofer
106 people viewed this question
 Grubhead
Grubhead
