Question about GE Advantium SCA2000B Microwave Oven
Advantium turned off, no lights- nothing on screen, braker is not tripped, i reset just in case. is there an internal fuse?
  • 3 Answers
You can find the replacement fuses at the local Radio Shack.
Posted on Mar 17, 2010
  • 464 Answers
Yes, it will have a ceramic fuse inside and will either be a 15 amp or 20 amp fuse.
Posted on Nov 13, 2009
GE Advantium Oven stopped working
Could be an open internal fuse, magnetron, or control board failure
Aug 29, 2017 | GE Microwave Ovens
Hi, my problem is with my GE advantium speedcook microwave oven. When using 'speedcook' feature, the oven starts, then there is sparking inside the circuit board area, followed by a loud POP, and this...
  • Select the "Options" menu and adjust the clock display settings if the display is blank. Set the clock if the oven won't start. The clock must be set for the oven to work properly, as oven programming is dependent on the clock.
  • Close the door tightly if the oven won't start. The oven won't start if the door isn't closed. You can identify from the lights whether the oven failing to start is related to the door or to the power supply. If the control panel is illuminated and interior lights are on when you open the oven door, you can be sure the oven is receiving power and any starting problems are due to the door not being closed tightly.
  • Press and hold the "Clear/Off" button if the oven performs strangely. Be sure to hold it for a few seconds. This will reset the GE Advantium.
    But as you mentioned that there is /was a loud noise this is a indication of the unit make any usual noise (groaning, gurgling, etc.?) or was / is it either louder or quieter than normal?It may be as simple as the top door switch or its mount or it may be a bad magnetron or shorted diode.
    For manual of the oven.please click the link below:--
  • http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40577-1.pdf
  • Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
  • Aug 12, 2010 | GE Advantium 120 Convection/Microwave Oven
    Advantium 120 blew breaker when door was closed. I reset breaker and it worked for three weeks. Breaker is blown again...when i open the door and reset breaker it works, but as soon as you close the door...
    I'd suspect the interlock monitor switch is stuck, or its mounting bracket is out of adjustment. This is designed to blow the fuse if you try to run the oven while the door is open. The switch is supposed to open when you close the door. This switch is replaceable, but you should have this oven repaired by a professional. There are lethal voltages present with the cover off, and the possibility of microwave leakage is the repairs aren't done correctly.
    Mar 20, 2010 | GE Advantium SCA1001SS Convection /...
    GE Advantium 120 oven: Was boiling water and oven completely powered off. House circuit breaker is OK and not tripped. Plugged into another working outlet with extension cord to see if display came on. It...
    You will need to remove the top grill vent first, then you can remove the screws coming in from the top of the grille vent then that will expose a screw holding down the control panel at the top. Remove the screw and remove the control panel. The fuse is located in a little 1" fuse holder just behind the front panel near the top.
    Feb 05, 2010 | GE Advantium 120 Convection/Microwave Oven
    How do I replace the fuse in a GE Advantium SCA1001KSS?
    under the outer cover on a fuse clip its a special fuse avail at hardware stores
    Oct 08, 2009 | GE Advantium 120 Convection/Microwave Oven
    GE Advantium mircrowave oven
    The problem with my Advantium was the fuse inside the microwave.Thanks to all of your fixya emailers ,I was able to change the fuse myself.I would recommend your site to all as you were a great help to me. Thank you, wlpasko.
    Apr 09, 2009 | GE Advantium SCA2000B Microwave Oven
    GE Advantium - No power at all - PSB2201NSS01
    Does the unit have power?If not check the back and see if ou can take off. Most unit have fuse back there.
    Mar 13, 2009 | GE Advantium 120 Convection/Microwave Oven
    Advantium Fuse
    Remove the housing, it covers the sides and top. Then look above the display near where the 220 cord enters. That is the main fuse. There are 4 others in this oven. Good luck.
    Apr 03, 2008 | GE Advantium SCA2000B Microwave Oven
    GE Profile Advantium Wall Oven 240 volts 950 Watts
    How long does it run before it fails? Does it look like the display is getting scrambled characters? I'm leaning toward a bad magnetron, but it may be more or less than that. If you can give more details and especially the actual full model number (as opposed to the model name Advantium 120) that would help. Thanks!
    Oct 02, 2007 | GE Advantium 120 Convection/Microwave Oven
    GE Advantium SCA2000B Microwave Oven Logo
    290 people viewed this question
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    vince
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
