Question about Aqua Leisure 2,150 GPH Filter Pump
Need a capacitor for my Aqua Leisure 2150GPH pump.
Need a capacitor for my Aqua Leisure 2150 GPH pump. Do you know where I can buy one
  • 279 Answers
If there is a motor repair shop in your area, go there. They will be able to get you one or offer a good substitute. Good luck...Lee
Posted on Nov 13, 2009
Aqua 1100 pump just don't want to pump there is power and it is humming how do I clean the filter and what else can it be
Sounds like the capacitor has given up. If you can, remove the back of the pump, turn on and see if you can start it by hand. If so then it is capacitor. Take to a pool shop/ service centre for repair
Jan 04, 2017 | Aqua Pool & Spa
PLACEMENT CAPACITOR FOR A TSURUMI PUMP MODEL HS2.4S WHERE CAN I BUY ONE?
being that this us a sump pump that goes in the water you need to take it to a pump rebuilding company. so that new seal are put in. I would never do a repair even on a cord to a sump pump for that reasonl. Never what to know that I made a mistake that killed someone.
Please take the pump to a company that does that. Look in the old fashion yellow pages or on line for someone close to you
Thanks and be safe
Tom
Sep 08, 2011 | Tsurumi Pump s Submersible Water Pump ...
My 2 hp aqua-flo pump 1.5" in/out, side disharge, 240 v is leaking. do I need a new one?
The two most common causes for leaking pumps are worn out seals or leaky gaskets. The seal can be replaced and the pump can last for a long. The same thing can be said for a leaking gasket. I don't know what parts are available but many pumps can be assembled after buying all the parts. It is just higher priced.
If you are mechanically inclined you can do either of the above jobs but it best to watch someone else do it first. If you bring your pump to Leslies pool supply when they are not very very busy they can usually repair it while you watch.
I hope this helps.
Aug 29, 2011 | Aqua Flo 2 HP Aqua-Flo Pump: 1.5" in/out,...
I have an aqua flow master 3.8 hp xp2 pump in my hot tub, it sounds like it is receiving power as it is clicking on but it will not start. have i fried the motor? the shaft turns ok but nothing is...
Many of these pump motors have a capacitor and start & run windings. I had a pump motor a week ago that was free to rotate, but only hummed. I looked inside the back end, everything looked good, I bought a capacitor online for $7 + $15 shipping, installed it and it worked. The capacitor will have voltage & rating on the side.
BE CAREFUL, CAPACITORS KEEP VOLTAGE EVEN WHEN NOT PLUGGED IN. If you don't know how to handle them, take the motor to a local motor repair shop.
Gary
Aug 02, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
How oprates the timmer in my 2500 gph intex filter pump
When the timer mode is set it will only run for the hours you have the knob positioned to. It will then shut off. You will need to restart it everytime.
Jun 21, 2010 | Intex Krystal Clear Model 635 Pool Filter...
This is an older beckett pond pump about 550 gph. The impellor will not turn unless you give it a spin . Could it be the capacitor ?
check bearings may need to be lubed then check motor amp draw if within specs then test cap if weak or not holding charge replace
Mar 25, 2010 | Beckett Water Gardening Beckett Statuary...
Does anyone know where I can get a replacment impeller for a 2008 model Sunterra 2000 gph pump ? The cover comes off and looks replaceable. I have a warranty replacment 2009 model and the cover of it is...
If you find a replacement 2000 Impeller for your 2008 sunterra pump, let me know! I called the company who promptly told me they don't sell component parts for any of their pumps larger than 1250. They very matter-of-factly told me to go buy a new pump.
plasticmaster@msn.com
Oct 29, 2009 | Sunterra 202000 Pond Pump 2000 Gph, Black
I have a 4300 GPH Pump It got left on out side of
Most likeluy it overheated wile running outside of the water. It neds the water for cooling.
You might need to buy a new one
Sep 23, 2009 | Sunterra 3000 GPH Pond Pump 203000
Aqua Leisure 2,150 GPH Filter Pump Logo
128 people viewed this question
Top Aqua Pool & Spa Experts
Larry Maranto
Shehu Pro
Shehu Pro
Are you an Aqua Pool and Spa Expert? Answer questions, earn points and help others
