The dlink will not connect to internet because it says the usb port is not high speed how do i fix this
    Scholar:
  • 169 Answers
I think your usb slot supports only version 1.1 Install a new external usb 2.0 card or higher.
USB versions and speed rates are as follows:
USB 1.0/1.1 - 1.5 Mbit/s (Low-Speed) and 12 Mbit/s (Full-Speed)
USB 2.0 - 480 Mbit/s (now called Hi-Speed)
USB 3.0 - 4.8 Gbit/s (SuperSpeed)
Posted on Nov 13, 2009
It says i need to use the "high speed" usb port for my mobile internet modem. Where can i find one
use USBView.exe fromWindows Driver Kit (WDK) or download USBView.exe only from http://www.softpedia.com/get/System/System-Info/USBView.shtml Install and click items connected. Check port speed.
Apr 30, 2014 | Dell Latitude D620 Notebook
Connecting wireless router to server
If routing and remote access is enabled on the server, it should handle the bridging automatically between the two nics...
Otherwise, simply turn off the DHCP in the router, have the server and all the clients connect to the LAN ports, and they will automatically get their address from the server. In this scenario, you don't need to worry about the WAN port on the router.
But you might want to think about using the WAN port on the router to provide an added layer of security rather than exposing your server directly to the internet. You can set up all the port forwarding you need on the router.
More info here:
http://www.dlink.com/us/en/support/product/dwl-g700ap-high-speed-2-4ghz-802-11g-wireless-access-point
The manual is here:
http://www.dlink.com/us/en/support/product/-/media/Consumer_Products/DWL/DWL%20G700AP/Manual/DWL_G700AP_Manual_EN_US.pdf
You need a pdf reader (adobe) to read the content.
Good luck.
Nov 18, 2012 | D-Link DWL-G700AP 802.11g/b Wireless...
Globe symbol won't turn green.
I was banging my head for 2 days with about 35 different configurations and finally tried the following and it worked just fine. Also, tried connecting 3 computers and they all connected with "NO" issues. Even connected wireless with "NO" issues. Now I am at 20mb download speed...J compared to AT&T 1.5mb download speed.
This is my DLINK model -> (DIR-601 Wireless N 150 Home Router Wireless router)
1. Reset your Comcast Surfboard Cable Modem by unplugging it for 5 minutes.
2. Then reset your DLINK Router to the manufactures default settings. Then Unplug DLINK Router for 1 minute then plug it back in (Just plug your cat5 cable into port 1 and connect it to your computer) there should not be anything else plugged into the DLINK Router at the time you make the changes. Just 1 computer can be connected.
3. Went into the DLINK configuration 192.168.0.1 and changed the PPPOE setting that I was using for my AT&T Modem to Dynamic IP (DHCP). Once you make the changes save them and then unplug your DLINK Router it's off.
4. Turn on Comcast Surfboard Cable Modem and wait until all lights are on. Now plug in a cat5 cable from the Surfboard Comcast modem (NOT A CROSSOVER CABLE LIKE THE CD INDICATES) to the INTERNET port of your DLINK Router. Now turn on your DLINK router.
5. Then turn on your computers or restart them and it will pick up IP Addresses from your DLINK Router
Jun 08, 2010 | D-Link Wireless N 150 Home Router 4Port...
Xp computer say camera is a high speed device and
This means that your camera is a USB 2.0 device, but you connected it to a (slower) USB 1.1 port.
Usually, this is only a hint and you should still be able to download images, albeit rather slow.
To fix this you should first try to connect the camera directly to one of the USB ports at the rear side of your computer and see if this fixes the problem. If so, there either is some problem with the front side USB port or you were using a USB 1.1 hub.
If you still get a warning, your computer obviously is equipped with a USB 1.1 interface only. You could add USB 2.0 support by installing a USB 2.0 card like this.
Mar 21, 2010 | Polaroid i1035 Digital Camera
How do I intall the dlink router if I dont have a cd drive My computer is a dell inspirion and is runs on vista
hello, here is what you need to do: if have a pc connected to high speed modem directly you will unplug the network cable from the back of your pc/laptop and that end will then go in to "WAN" port on the new dlink router.
second, you take another wire and plug one end in your pc/laptop and the other end in one of the 4 lan ports in the back of your new dlink.
restart everything in the following order at 30 seconds duration:- first the cable/DSl modem, then dlink, then your pc/laptop.
once everything is up open up internet browser and test connectivity.
at this point you should have internet up and running but you need to configure you router and wireless etc.
from your browser in address bar type in http://192.168.0.1 and hit enter that will bring you router login prompt : default user name is "admin" and password is left blank and hit enter, you are now in router to configure options as you please.
I would strongly recommend changing your router password administration and if you plan on using wireless, setup SSID, encryption, network key on wireless. NEVER LEAVE IT OPEN.
Hope this helps
let me know if you have any questions
Amar Sondhi
Dec 04, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
I currently use a cable modem to connect to the internet from my Imac. I have dlink wireless router that I used to have for my old pc so that my work laptop could connect. How do I install the dlink on the...
No need to install the dlink on the imac. All you need to do is connect the modem first the dlink. (Modem connected to Internet or WAN port of the dlink). Now if they are connected, your imac should be plugged in to port 1 of dlink, and your PC to port 2. That should do it.
Nov 18, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Had hispeed USB device fitted know cannot connect to internet. I am using a dlink wireless connection, it was working fine before this. regards robert t
does removing the hi speed USB device fixes the problem? providing OS, type of USB hi speed device and complete PC specs would also help
May 05, 2008 | Computers & Internet
Connection of DLINK router(DI-524) and 8port10/100M ethernet mini swtch
If the switch doesn't have an "uplink port" or autodetect the port speed, then you will need a crossover cable to connect the DLINK to the Surecom switch. If this is the same issue then rate this one so it can be closed. If not then let me know how it goes. Good Luck
Sep 28, 2007 | Computers & Internet
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
