Question about Procom QL300TYLA Heater
Internal thermostat cuts off and blows out the pilot light. How to fix ?
  • 1,420 Answers
This unit may have two sensors at the pilot, a thermocouple that keeps the pilot on and a thermopile that allows the burner to ignite. If the pilot will not light, replace the thermocouple. If the burner goes out and the pilot with it, replace the thermopile. Heck as long as you have the unit open, replace them both. Cheap insurance.
Posted on Nov 13, 2009
Just so happened to pass by your problem and we had same thing happen, not saying this will be your fix also but after looking for answers everywhere i lightly wire brushed off end of the part where the flame comes out ( with small wire brush) used an air can like for computers, lightly sprayed air in and aroud the flame tip area and presto had no problem any more. I spent more time trying to bypass the obvious easy answer and after 3 weeks of contemplating disassembly did the easy and glad i did, there was no disassembly...hope this works for you too...tommykamakazi
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
Feb 19, 2018 | Desa International Heating & Cooling
Heater will light up and then it just cuts off. Pilot stays lit.
thermostat is probably bad if pilot stays lit but burners go out
Oct 27, 2009 | Desa International GWP20T GLOWARM Wall...
Pilot light and furnace seems to work fine but during the night the pilot goes out. What can I do to fix this? Is it the thermostat, thermocoupler, gas line? Dave
My experience with this is that first replace the thermocouple. As thermocouples age they sometimes become less efficient and intermitent. If you still have the problem check that the groves cut in the burner tubes are not plugged because sometimes an uneven flame will blow the pilot out upon ignition. Also any drafts around the furnace can blow out the pilot. Make certain that all flame shields are installed correctly. I have even had pilots blow out when a door was opened causing an excessive draft. And make sure your draft is operating properly and not restricted.
Oct 09, 2009 | Heating & Cooling
Radiant Flame Heater by DESA International pilot light will not stay lit. The manual is not available. Could this be a thermocouple? If so, how do I change it. The flame in the "logs" will light...
You need to replace the pilot light. This is an easy replacement, it goes from your gas control valve to its place in the heater. You can try "taping" the dust out or pulling it out and blowing it clear. This will fix your pilot light problem.
Sep 29, 2009 | Heating & Cooling
We have a model VP1600E Propane Space Heater
Not sure I can help but will try. Sounds like you have a blockage in the pipe or jet and when it heats up it is choking. Best way to clean Propane and/or Gas heaters is to blow compressed air through the pipe. You may be able to just blow the air down the pilot light and main jet and it could fix the problem and clear the jet.
If not you will need to pull off the covers to expose the piping and look for the pipe going to the jet or pilot and if you can undo the pipe and blow compressed air through it. You may find a bit of dirt or carbon is causing the blockage. If you undo any pipes make sure you tighten them back up. Hope this solves your problem.
regards
Bryan
Feb 27, 2008 | Vanguard International Infra Red - Large...
Pilot light wont stay lit once heater shuts off/ light goes off randomly
Hi Watertec00,
I am not familiar with this heater but it sounds like it could be a blockage in the main gas line into the heater or perhaps a blockage to the pilot gas line and maybe starving for gas. Best bet first is to check the main gas line from the heater. Easiest way to do this is to remove it from the heater and blow it through with compressed air. Then try the heater again. If that doesn't fix the problem then you can try blowing compressed air down through the pilot line. Could be a little dirt creating a blockage there. Then try the heater again. If it still does the same thing then try removing the panels to expose the heater's piping. If you can remove the main pipe into the heater from the gas and blow compressed air through it it should clear any obstruction from both the main line and the pilot. If this doesn't work then I would think you have a more severe problem and will need to take it to your local Heater Repairer. Hope this helps.
Regards
Bryan
Dec 18, 2007 | Procom MN100HPA Heater
Procom QL300TYLA Heater Logo
321 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
