When I try to open the file the screen freezes. I have 140 photos in my library. I have to use control/alt/delete to get out. Am using Windows XP. Printer is HP C4280.
  • greenridge10 Nov 14, 2009
    I am a beginner and don't know what "add a service explore.exe" means. I feel my $13 paid to Fixya was wasted. Yesterday I finally set up a chat with HP and found that the entire Photosmart Essential program isn't working. They helped me transfer to Picasa until the problem is solved.
  • 80 Answers
Add a service explore.exe
Posted on Nov 14, 2009
Had the xp screen open. Opened my documents. Tried to drag quicken files to mac, which I do all time to back it up. Realized it wasn't dragging so dragged back to the quicken file. Now screen is frozen....
Simply Hard Reset it, IE: Turn Power Off and On. This should resolve the problem. Any damage, problems, have already occured, but a re-boot should fix it, at least it will return it back to a working desktop.
Jan 19, 2010 | Microsoft Virtual PC 7 with Windows XP...
Tip
Windows xp keyboard tips
and also
and
Windows system key combinations
  • F1: Help
  • CTRL+ESC: Open Start menu
  • ALT+TAB: Switch between open programs
  • ALT+F4: Quit program
  • SHIFT+DELETE: Delete item permanently
  • Windows Logo+L: Lock the computer (without using CTRL+ALT+DELETE)
Windows program key combinations
  • CTRL+C: Copy
  • CTRL+X: Cut
  • CTRL+V: Paste
  • CTRL+Z: Undo
  • CTRL+B: Bold
  • CTRL+U: Underline
  • CTRL+I: Italic
Mouse click/keyboard modifier combinations for shell objects
  • SHIFT+right click: Displays a shortcut menu containing alternative commands
  • SHIFT+double click: Runs the alternate default command (the second item on the menu)
  • ALT+double click: Displays properties
  • SHIFT+DELETE: Deletes an item immediately without placing it in the Recycle Bin
General keyboard-only commands
  • F1: Starts Windows Help
  • F10: Activates menu bar options
  • SHIFT+F10 Opens a shortcut menu for the selected item (this is the same as right-clicking an object
  • CTRL+ESC: Opens the Start menu (use the ARROW keys to select an item)
  • CTRL+ESC or ESC: Selects the Start button (press TAB to select the taskbar, or press SHIFT+F10 for a context menu)
  • CTRL+SHIFT+ESC: Opens Windows Task Manager
  • ALT+DOWN ARROW: Opens a drop-down list box
  • ALT+TAB: Switch to another running program (hold down the ALT key and then press the TAB key to view the task-switching window)
  • SHIFT: Press and hold down the SHIFT key while you insert a CD-ROM to bypass the automatic-run feature
  • ALT+SPACE: Displays the main window's System menu (from the System menu, you can restore, move, resize, minimize, maximize, or close the window)
  • ALT+- (ALT+hyphen): Displays the Multiple Document Interface (MDI) child window's System menu (from the MDI child window's System menu, you can restore, move, resize, minimize, maximize, or close the child window)
  • CTRL+TAB: Switch to the next child window of a Multiple Document Interface (MDI) program
  • ALT+underlined letter in menu: Opens the menu
  • ALT+F4: Closes the current window
  • CTRL+F4: Closes the current Multiple Document Interface (MDI) window
  • ALT+F6: Switch between multiple windows in the same program (for example, when the Notepad Find dialog box is displayed, ALT+F6 switches between the Find dialog box and the main Notepad window)
Shell objects and general folder/Windows Explorer shortcuts
For a selected object:
  • F2: Rename object
  • F3: Find all files
  • CTRL+X: Cut
  • CTRL+C: Copy
  • CTRL+V: Paste
  • SHIFT+DELETE: Delete selection immediately, without moving the item to the Recycle Bin
  • ALT+ENTER: Open the properties for the selected object
To copy a file
Press and hold down the CTRL key while you drag the file to another folder.
To create a shortcut
Press and hold down CTRL+SHIFT while you drag a file to the desktop or a folder.
General folder/shortcut control
  • F4: Selects the Go To A Different Folder box and moves down the entries in the box (if the toolbar is active in Windows Explorer)
  • F5: Refreshes the current window.
  • F6: Moves among panes in Windows Explorer
  • CTRL+G: Opens the Go To Folder tool (in Windows 95 Windows Explorer only)
  • CTRL+Z: Undo the last command
  • CTRL+A: Select all the items in the current window
  • BACKSPACE: Switch to the parent folder
  • SHIFT+click+Close button: For folders, close the current folder plus all parent folders
Windows Explorer tree control
  • Numeric Keypad *: Expands everything under the current selection
  • Numeric Keypad +: Expands the current selection
  • Numeric Keypad -: Collapses the current selection.
  • RIGHT ARROW: Expands the current selection if it is not expanded, otherwise goes to the first child
  • LEFT ARROW: Collapses the current selection if it is expanded, otherwise goes to the parent
Properties control
  • CTRL+TAB/CTRL+SHIFT+TAB: Move through the property tabs
Accessibility shortcuts
  • Press SHIFT five times: Toggles StickyKeys on and off
  • Press down and hold the right SHIFT key for eight seconds: Toggles FilterKeys on and off
  • Press down and hold the NUM LOCK key for five seconds: Toggles ToggleKeys on and off
  • Left ALT+left SHIFT+NUM LOCK: Toggles MouseKeys on and off
  • Left ALT+left SHIFT+PRINT SCREEN: Toggles high contrast on and off
Microsoft Natural Keyboard keys
  • Windows Logo: Start menu
  • Windows Logo+R: Run dialog box
  • Windows Logo+M: Minimize all
  • SHIFT+Windows Logo+M: Undo minimize all
  • Windows Logo+F1: Help
  • Windows Logo+E: Windows Explorer
  • Windows Logo+F: Find files or folders
  • Windows Logo+D: Minimizes all open windows and displays the desktop
  • CTRL+Windows Logo+F: Find computer
  • CTRL+Windows Logo+TAB: Moves focus from Start, to the Quick Launch toolbar, to the system tray (use RIGHT ARROW or LEFT ARROW to move focus to items on the Quick Launch toolbar and the system tray)
  • Windows Logo+TAB: Cycle through taskbar buttons
  • Windows Logo+Break: System Properties dialog box
  • Application key: Displays a shortcut menu for the selected item
Microsoft Natural Keyboard with IntelliType software installed
  • Windows Logo+L: Log off Windows
  • Windows Logo+P: Starts Print Manager
  • Windows Logo+C: Opens Control Panel
  • Windows Logo+V: Starts Clipboard
  • Windows Logo+K: Opens Keyboard Properties dialog box
  • Windows Logo+I: Opens Mouse Properties dialog box
  • Windows Logo+A: Starts Accessibility Options (if installed)
  • Windows Logo+SPACEBAR: Displays the list of Microsoft IntelliType shortcut keys
  • Windows Logo+S: Toggles CAPS LOCK on and off
Dialog box keyboard commands
  • TAB: Move to the next control in the dialog box
  • SHIFT+TAB: Move to the previous control in the dialog box
  • SPACEBAR: If the current control is a button, this clicks the button. If the current control is a check box, this toggles the check box. If the current control is an option, this selects the option.
  • ENTER: Equivalent to clicking the selected button (the button with the outline)
  • ESC: Equivalent to clicking the Cancel button
  • ALT+underlined letter in dialog box item: Move to the corresponding item
reference: http://support.microsoft.com/kb/126449
on Nov 12, 2014 | Microsoft Windows XP Professional With...
Tip
Key-bord shorcut
· Shift + F10 right-clicks.
Win + L (XP Only): Locks keyboard.
Similar to LockWorkstation.
· Win + F or F3: Open Find dialog. (All Files) F3 may notwork in some applications which use F3 for their own find dialogs.
Win + Control + F: Open Find dialog. (Computers)
Win + U: Open Utility Manager.
Win + F1: Open Windows help.
Win + Pause: Open System Properties dialog.
· Win + Tab: Cycle through taskbar buttons.
Enter clicks,AppsKey or Shift + F10 right-clicks.
· Win + Shift + Tab: Cycle through taskbar buttons inreverse.
· Alt + Tab: Display CoolSwitch. More commonly known as theAltTab dialog.
Alt + Shift + Tab: Display CoolSwitch; go in reverse.
· Alt + Escape: Send active window to the bottom of thez-order.
· Alt + Shift + Escape: Activate the window at the bottomof the z-order.
· Alt + F4: Close active window; or, if all windows areclosed, open shutdown dialog.
Shift while a CD is loading: Bypass AutoPlay.
· Shift while login: Bypass startup folder. Only thoseapplications will be ignored which are in the startup folder, not those startedfrom the registry (MicrosoftWindowsCurrentVersionRun)
· Ctrl + Alt + Delete or Ctrl + Alt + NumpadDel (BothNumLock states): Invoke the Task Manager or NT Security dialog.
· Ctrl + Shift + Escape (2000/XP ) or (Ctrl + Alt +NumpadDot) : Invoke the task manager. On earlier OSes, acts like Ctrl + Escape.
· Printscreen: Copy screenshot of current screen toclipboard.
· Alt + Printscreen: Copy screenshot of current activewindow to clipboard.
Ctrl + Alt + Down Arrow: Invert screen. Untested on OSesother than XP. · Ctrl + Alt + Up Arrow: Undo inversion.
Win + B : Move focus to systray icons.
2.) Generic
· Ctrl + C or Ctrl + Insert: Copy.
Ctrl + X or Shift + Delete: Cut.
· Ctrl + V or Shift + Insert: Paste/Move.
· Ctrl + N: New... File, Tab, Entry, etc.
· Ctrl + S: Save.
Ctrl + O: Open...
· Ctrl + P: Print.
· Ctrl + Z: Undo.
· Ctrl + A: Select all.
· Ctrl + F: Find...
Ctrl+W : to close the current window
· Ctrl + F4: Close tab or child window.
F1: Open help.
· F11: Toggle full screen mode.
Alt or F10: Activate menu bar.
Alt + Space: Display system menu. Same as clicking theicon on the titlebar. · Escape: Remove focus from current control/menu, or closedialog box.
3.) Generic Navigation
Tab: Forward one item.
· Shift + Tab: Backward one item.
· Ctrl + Tab: Cycle through tabs/child windows.
Ctrl + Shift + Tab: Cycle backwards through tabs/childwindows.
· Enter: If a button's selected, click it, otherwise, clickdefault button.
· Space: Toggle items such as radio buttons or checkboxes.
Alt + (Letter): Activate item corresponding to (Letter).(Letter) is the underlined letter on the item's name.
Ctrl + Left: Move cursor to the beginning of previousword.
· Ctrl + Right: Move cursor to the beginning of next word.
Ctrl + Up: Move cursor to beginning of previousparagraph. This and all subsequent Up/Down hotkeys in this section have onlybeen known to work in RichEdit controls.
· Ctrl + Down: Move cursor to beginning of next paragraph.
Shift + Left: Highlight one character to the left.
· Shift + Right: Highlight one character to the right.
· Shift + Up: Highlight from current cursor position, toone line up.
· Shift + Down: Highlight from current cursor position, toone line down.
· Ctrl + Shift + Left: Highlight to beginning of previousword.
Ctrl + Shift + Right: Highlight to beginning of nextword.
Ctrl + Shift + Up: Highlight to beginning of previousparagraph.
Ctrl + Shift + Down: Highlight to beginning of nextparagraph.
Home: Move cursor to top of a scrollable control.
· End: Move cursor to bottom of a scrollable control.
on Oct 10, 2010 | Computers & Internet
When I try to attach a photo from my "my pictures file" I click browse, and my file opens, but I am unable to scroll through it. It freezes. Occasionally it will scroll, but will freeze when I try to...
Even though you want to attach a picture, instead of attaching a photo, try attaching a file instead. You can then select the photo. I think it is some sort of quirk in Yahoo. I had the same problem.
Nov 11, 2009 | Yahoo Mail
Desktop freezes..no icons..nothing!!!
hi... login to safe mode by tapping F8 before u seee the Windows Xp Splash screen... select the option SAFE MODE and wait for a while u ll get the desktop.. then go to USER ACCOUNTS in Control Panel.. and create a new user account... and delete the previous account.. While deleting Make sure to select the option DELETE ONLY ACCOUNT dont select Delete files k... The files from the previous acconut will be saved to the desktop of the new account..
Sep 20, 2009 | HP Pavilion dv1000 Notebook
Tip
How do you delete photos from Sansa e200 MP3 Player?
If you go into Windows Media Player, you have to change the Library option from Music to Photos and THEN go into the Sync tab - should now display photos instead of music.
Alternatively, you can double-click My Computer, double-click the icon of the Sansa, and find the images or picture folder - you may have to change your usb mode to msc in order to view this folder (don't forget to change it back later, or not all of your files will show up when you want them to). ONLY delete image files - if you delete system files, your mp3 player will become unusable.
Or, you can follow the method reccomended by your manual - the full user's manual is available from Sanidsk's website:
Delete Photos and Video
The photos are stored in 2 locations on your Sansa…My Album and
Thumbnails. The instructions below for deleting photos and video from your
player were created using Windows XP with Windows Media Player 11.
To delete photos from your Sansa, please execute the following steps:
1) Connect your Sansa e200 to your computer
2) Select Open device to view files using Windows Explorer on initial
connection
3) Click the drive containing your photos
4) Click on the photo folder.
5) Highlight and delete the photos stored in My Computer\Sansa
e200\...\Photo\My Album and My Computer\Sansa
e200\...\Photo\thumbnail\My Album.
This will help.Good Luck.
on Mar 10, 2010 | Audio Players & Recorders
I cannot close out programs unless using control-alt-delete
yes, seems like there is virus going on your system. Go task manager and see which program is consuming more memory, if you kill that program it will work fine. But now you have to run antivirus and get the virus removed.
Mar 26, 2009 | Microsoft Windows XP Professional
How to delete old file or video form this player
Open Windows Media Player 11 and switch the Library view to Photos (by default, it is usually set to Music - just click the musical not icon and a drop-down will ocme up that says "Photos"
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
Mar 26, 2009 | SanDisk Sansa e200 MP3 Player
How do you delete photos?
connection
Feb 21, 2009 | SanDisk Sansa E280 MP3 Player
Outlook express freezes up frequently when you click on a link
Use ctrl-alt-delete to also moniter the Cpu usage & processes tap for hungury system files. Have this open when you start outlook express if your cpu is running at 100% it will lock up this is probably whats happening
Jan 24, 2009 | Microsoft Windows XP Home Edition
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
