Question about Ricoh Aficio 2022 All-In-One Laser Printer
We are getting SC392 error with our ricoh 220 copier. Any help would appreciated
  • berhane_redd Nov 13, 2009
    we did unplug and plug on the machine, but still getting the same problem. Any other suggesting that we might need to try
  • Ricoh Master
  • 19,396 Answers
Here definition and eventual fixes:
SC392: TD sensor initial setting error
-Definition-
TD sensor output voltage falls out of the adjustment range (2.0 ± 0.2 V) after the
TD sensor initial setting has been finished.
- Possible causes -
• Someone forgot to remove the toner seal of the PCU
• ID sensor defective
• TD sensor abnormal
• Drum does not turn
• Development roller does not turn
• Poor connection of the PCU
Try disconnecting power cord and restarting the machine.
If you have a spare toner, test a different toner. A faulty cartridge may cause this same error.
If the problem is not cleared , then often this error is caused by a faulty drum. Since there are several different fault that can trigger TD sensor error, it would be better to have a technician testing the unit before replacing parts.
If you want to know part prices, or if you want a quote on repair, you can call Ricoh number listed on your owners manual.
Regards.
Posted on Nov 13, 2009
  • Ginko
    Ginko Nov 13, 2009
    I told you several steps, not only to unplug.
    Try a replacement toner.
    If that does not work, I explained you what the problem can be , it is TD sensor on drum unit.
    At that point your choice is risking to replace drum, or calling a technician.
    To decide you need to call Ricoh at the support number listed on the manual.
    The restart (powercycling) was only a step that is compulsory on troubleshooting.
    Call Ricoh and decide if having machine tested or if to replace drum unit.
    Regards,
How to clear error sc392 on ricoh aficio 270/220 photocopier
A few things to look for is make sure the developer roller and drum are actually turning (missing gear, teeth, etc...). Are any obstuctions blocking the developer from brushing the drum (I place paper between the drum and developer so I don't scratch the drum during *ssembly, if I forget to remove it - code). And make sure the connectors are secure.
It's not enough that we do our best; sometimes we have to do what's required.
or
https://www.google.com.af/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0CCIQtwIwAQ&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DvPe5fL_erZs&ei=jSWMVNb3L8jOygOjhYAg&usg=AFQjCNGPjBajIAh-ZNVxMbICi6EYxdN3zQ&sig2=4OZiTxo5eatVb3bXAD_6Zg
search the above link and watch the video
Dec 13, 2014 | Ricoh Aficio 220 270 Drum 60 000 Yield...
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
What does sc392 mean on a mp2510
seal of the PCU
ID sensor defective
TD sensor abnormal
Drum does not turn
Apr 03, 2014 | Ricoh Aficio 2022 All-In-One Laser Printer
I lost my manual for ricoh 220 and now whenever i try to make a copy the end product is half of the page.i would like to know how to format my copier or how to set the copier so that i get the exact s
Go to ricoh-usa.com/downloads then in search box enter 220 make sure manual is check below search box . Press search scroll down page click on manual. If need a different language try the ricoh.com website
Jan 14, 2014 | Ricoh Aficio 220 Laser Printer
What can correct an SC392 on a Ricoh MP W2400?
SC392:Toner density sensor initial setting is not performed correctly.
  • No developer
  • Developing roller does not turn.
  • Development roller coupling gear is not correctly attached.
  • Poor connection of PCU
Source: Ricoh Errors
May 06, 2011 | Ricoh Office Equipment & Supplies
I need some solution for the error code for ricoh aficio 220,the error code was SC 543..can you help me for this problem..tnx..
Fusing overheat error
Symptom:
Detected fusing temperature
remained above 230°C for 1
second.
Possible Cause:
• Fusing thermistor defective
• PSU defective
Nov 22, 2010 | Ricoh Aficio C811DN-T1 - printer - color -...
I need the service manual for the Aficio 220
hello there here is several links that will help you out ok
best regards michael
  1. RICOH AFICIO 220 Service Manual RICOH AFICIO 220 - It's a complete service manual, and it's in PDF format. ... i got my service manual for philips vr685-02. Thanks a lot for my very clear and ...www.user-manuals.com/service-manual-RICOH-AFICIO220.html - 73k - Cached
  2. Ricoh Service Manuals - Copier Service Manuals Ricoh Service Manual/Parts catalog CD's for FT, NC, Fax, FX, Afico, AP, MLP, SLP, ... Ricoh Service Manual/Parts catalog CD's for FT, NC, Fax, FX, Aficio, AP, MLP, ...www.knowthesource.com/index.php?cPath=26 - 57k - Cached
  3. AFICIO 220 RICOH AFICIO 220 Owner's Manual ... for delivery information. Model: AFICIO 220. Type: Owner's Manual. Delivery: ... Manual received - Many thanks for an excellent service. Alain Fagan - 2006-04-11 ...www.manuals-in-pdf.com/55709-p-11284.html - 65k - Cached
Sep 14, 2009 | Office Equipment & Supplies
SC392
SC 392 Possible causes -
· Someone forgot to remove the toner seal of the PCU
· ID sensor defective
· TD sensor abnormal
· Drum does not turn
· Development roller does not turn
· Poor connection of the PCU
Regards,
Jun 11, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 220 Laser Printer Problem not printing
This is an error related to the laser unit.
Switch off the machine.
Please replace the Polygon mirror motor situated in the laser unit.
Part number AX06-0181.
Good luck and please rate me.
May 14, 2008 | Ricoh Aficio 220 Laser Printer
Ricoh Aficio 2022 All-In-One Laser Printer Logo
323 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
