Question about Cuisinart Brew Central 12-cup Coffee Maker
How do I clean my coffee maker? I have very hard water.
  • 464 Answers
I have a Cuisinart also and this is what i do: fill the resevoir with white vinegar and start the machine. once it has started through, shut if off for about 2 hours, then start it again. do this a couple of times using the same vinegar. afterwards run about 3 pots of cold water through to rinse it out, this should help clear the pumping tubes inside.
Posted on Nov 13, 2009
    Problem Solver:
  • 4 Answers
Put white vinager init instead of water and run it through its cycle. Do not put coffe or a filter in it. This will smell a bit, but it will clean the hard water deposits out of it.
4 Suggested Answers
SOURCE: cleaning my coffee maker
can the carafe of the stainless steel coffee maker go in the dishwasher?
Posted on Apr 20, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: funny tasting coffee
Vinegar/water cleaning is a good idea, but it won't necessarilly solve funny-tasting coffee. First, replace your charcoal water filter - you can get the Cuisinart brand-name replacements at Lowe's, Bed/Bath/Beyond, or Williams-Sonoma in most areas.
To do the vinegar/water cleaning, just pour 1/3 caraffe distilled white vinegar and 2/3 caraffe water into the water reservoir and brew it like it was regular coffee - I would simply bypass the self-clean function if your Cuisinart has one. Repeat up to 3 times, using a fresh batch of vinegar each time.
(if you have the caraffe-less DCC-2000, then just pour in 4 cups vinegar and 6 cups water).
Then run a full cycle of water. Then run a combo of 12 tsp lemon juice and 12 cups water (or 10 tsp and 10 cups water) to improve the taste.
On your next batch of coffee, use bottled water just to rule out any possibility that your local water supply may be contributing to funny-tasting coffee.
Now your coffee should be tasting fine again.
-Tha Mp3 Doctor
Posted on Apr 04, 2009
  • 85 Answers
SOURCE: The red cleaning light on my cuisinart coffee
Hello sandra_strat,
There are two possible issues, but easy to do. When decalcifying your unit the solution should be 2 parts water and 1 part vinegar. So if you have a 12 cup maker it would be 8 cups water and 4 cups vinegar. Complete the process with a pot or two of fresh water to rinse. Second, there may be a water filter stick that is removable. Open the lid and look for it in one of the corners, pull it out and remove the carbon filter there. (You can get a new on Amazon). Then replace the stick.
I hope this is a help for you. If it is please leave positive feedback for me. Thanks! NormanZ
Posted on Jul 14, 2009
Keurig reservoir lite still blinking after water added
Make certain the container is flush with the body of the coffee maker. Press it in tight and if that fails, the contacts may be coated or need repair. Clean with vinegar as stated in the manual to clear deposits. Average...replace filter 3 Mo. Clean 6 weeks depending on Hard or Soft water conditions.
Jan 22, 2014 | Keurig Platinum B70 Coffee Maker
Cooks coffee maker ...lits up but does not go thru the coffee making cycle...about a year old...never has been cleaned...this coffee maker does not need a paper filter...how do i clean it?? i have no inst....
If it does run some water throught you can try to de-calcify the coffee maker by running a cup of CLR (brand name) through the cycle a couple of times. This will clear most of the water mineral deposits that often clog the coffee making system. After the CLR treatment, run clean water through the system at least twice to clear any remaining CLR. Hopefully this will allow you to enjoy coffee again.
You should clean the coffee maker at least every 30-45 brewing cycles depending upon the hardness of your local water. Regular cleaning by running a cup of white vinegar should work with the more aggressive CLR treatment if you have very hard water.
Hope this clear the problem. Thanks.
Nov 22, 2010 | Cook's Essentials CEFB2B
The light is on to clean it and I do not have an owner's manual. Can you please explain? How do I get the light to stop blinking?
Most coffee makers are cleaned by filling the reservoir with undiluted white vinegar (3 cups). (Do not add coffee.) Remove the water filtration disk if you use it before starting. Then start the brew cycle as if making a cup of coffee (including putting a paper filter or the permanent filter in the filter basket and close the lid). Put a decanter on the warming plate. After brewing, turn off the coffee maker and let stand for 30 minutes. Run another cup of vinegar through the coffee maker. Take the decanter filled with vinegar and discard the liquid (pour down the sink drain). Rinse the decanter. Fill the reservoir with clean water and put in a new paper filter (or clean the permanent filter and put it back). Again do not add coffee. Run a brew cycle to rinse the unit. Discard the water that is in the decanter after the brew cycle. Do a second clean water only brew cycle (with new empty paper filter or permanent filter after cleaning again). However, if you notice an odd taste, repeat the rinse cycle.
You can alternatively use the Mr. Coffee Coffee Maker Cleaner (mix as directed on that package). In either case, this removes mineral deposits (calcium from hard water). For soft water, the cleaning should be done every 80 brew cycles. If you have hard water, do this every 40 cycles.
The manual is available from www.mrcoffee.com/Product.aspx?pid=121 , if I have the correct product version. For some reason this site isn't coming up for me today. Check the manual to find out if there is any specific details for cleaning that aren't shared with other Mr. Coffee products.
I hope this helps.
Oct 29, 2010 | Mr. Coffee 12-Cup Programmable Coffeemaker
Where is the clean button on the coffee maker?
There is no clean button.
To clean the scale buildup in the water system, you need to run a couple of cups of clear vinegar throught the system, run 24 cups of water (2 brew cycles) through the system to flush.
If the buildup is severe, you can substitue a calcium cleaner like CLR (Calcium-Lime-Rust) cleaner in place of the vinegar for a more aggressive cleaning.
Depending upon the hardness of your water, you need to do the cleaning every 30-45 pots of coffee.
Let me know if you have any other questions. Thanks.
Sep 06, 2010 | Cuisinart DCC-1200 Coffee Maker
The water hardly drips out and then a quarter of a cup and grounds in it.
Try to clean the kneadle with paper clip. Just insert the paper clip in the small hole of the kneadle and try to make coffee without any coffee in the machine.
Also a more frequent flash of water without coffee in the machine will keep it more clean.
Aug 22, 2010 | Keurig B60 Coffee Maker
My senseo coffeemaker has stopped pumping hot water through the coffee pods. What do I do to fix it?
When was the last time you clean it with vinegar? Run vinegar through it and you will see hard water scales that were built on the heater. Coffee makers should be clean out every month then with 2 rinse cycles after that.
Jan 24, 2010 | Philips Senseo HD-7810 Coffee Maker
Error Message
Suggestion was Descaling the Coffee Maker from KitchenAid Phoebe (I'm guessing customer support)
http://kitchenaidconversations.com/forums/topic.asp?TOPIC_ID=14441&SearchTerms=err+2
Cleaning scale from coffee maker DO NOT USE THAT MUCH VINEGAR! Put a tiny bit of vinegar in the carafe and fill carafe the rest of the way with water. Run that vinegar/water through machine. Using another container, fill machine with plain water and run that through. Repeat until the vinegar taste is gone. If you do not run lots of plain water through the machine after, your coffee will taste like...um...disgusting! Also, use a spell-checker before improving this posting.
To clean hard water deposits from a coffee maker use distilled white vinager. You may need to use as much as a gallon if the scale buildup is really bad. Fill clean coffee pot one half full of vinager and run through machine as if making coffee. Repeat this process several times using fresh vinager until it comes out clear. Do this once a week and your maker will work much better.
Thanks.
Mar 24, 2009 | Coffee Makers & Espresso Machines
Cleaning light came on and now, coffee pot will not work
Automatic clean function
The coffee maker is equipped with an automatic clean function. After 60 brewing cycles, the clean indicator/button (22) lights up. This indicates coffee maker should be cleaned by using the automatic clean function and the charcoal filter (17) should be replaced.
NOTE: The coffee maker can continue to be used, when clean indicator/button (22) is on.
• To begin the cleaning cycle, remove the charcoal filter (17) from the water tank (10). Fill the tank with a vinegar and water mixture (1/2 vinegar and 1/2 water) or a descaling product. Press clean (22) button for three seconds. The clean indicator/button (22) flashes and the cleaning process begins.
Cleaning process:
• 24 cycles of 7 seconds brewing and 21 seconds off
• 30 minutes rest
• Brewing the remaining descaling solution
• After cleaning process is complete the clean indicator/button (22) goes off. Fill water tank (10) with clean water and run one brewing cycle to rinse the coffee maker.
• Change the charcoal filter (17) (ill. k). Reinsert the charcoal filter to the coffee maker (ill. l).
NOTE: You can use the cleaning function before reaching 60 cycles (especially if the water hardness is above normal). Press and hold clean indicator/button (22) for 3 seconds.
NOTE: The Cleaning Process takes 60 minutes to complete. You cannot cancel the cleaning process before it is complete. Unplugging the machine only delays the cleaning process.
Jan 26, 2009 | GE 106591 Coffee Maker
Err nessage 2
Aug 19, 2008 | KitchenAid KCM511 Coffee Maker
Kitchenaid coffee maker giving me error 2
To clean hard water deposits from a coffeemaker use distilled white vinager. You may need to use as much as a gallon if the scale buildup is really bad. Fill clean coffee pot one half full of vinager and run through machine as if making coffee. Repeat this process several times using fresh vinager until it comes out clear. Do this once a week and your maker will work much better.
Jun 16, 2008 | KitchenAid KCM511 Coffee Maker
Open Questions:
See all Cuisinart Brew Central 12-cup Coffee Maker Questions
Cuisinart Brew Central 12-cup Coffee Maker Logo
307 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
