Question about Lexmark X4270 All-In-One InkJet Printer
What do i need for settings on the printer to print from the computer
    President:
  • Lexmark Master
  • 2,022 Answers
You only need to install the driver software of the printer to your system and conncet the usb cable .
Posted on Nov 13, 2009
Computer says paper jam in printer but printer will make copies
Welcome to the ever popular-widely experienced world of:
PAPER SIZE MISMATCH!!!
YES! That wonderful world where unbeknownst to you but knownst to us (OK I watch Spaceballs WAY TOO MUCH) When you are sending a print job, somehow the paper size setting has been changed. Either in the printer itself, or in the print properties settings in your OS.
Double-check those paper size settings and try to print. If it still happens, try resetting the print settings in the printer back to factory default. Make sure you print out the printer configuration before resetting in case you need to reinstall those settings.
Nov 06, 2013 | HP PSC 1401 All-In-One Printer
Sharp MX-2610N printer can't set-up the print job (for labels from by pass tray) from my desktop computer.
Some documents like word override the settings... you need to change/save within your document you are printing. page layout and then page set up
Sep 16, 2012 | Sharp MX-2300N Color Copier
Both Side not print
HP Laser Jet P3005s Network Printer doesn't print on both sides so you need to do that manually.
Feb 24, 2010 | HP LaserJet P3005n Printer
Bad ESC Seq
The ‘Bad Esc Seq’ message on the MT645 indicates the printer is not recognizing some of the commands it receives in the data from the host computer system. These commends are sent in the format of Escape Commands Sequences hence the ‘Bad Esc Seg’ error message displayed on the printer.
There can be a number of reasons for the printer displaying the ‘Bad Esc Seq’ error.
The first thing that it may be worth doing would be to power the printer off then disconnect the printer from the computer system. Once the printer has been disconnected from the computer system power the printer back on again. If the ‘Bad Esc’ Seq’ message is seen when the printer is disconnected from the computer system this would tend to indicate there is a fault with the printer.
If the printer powers on OK and does not display any errors when it is disconnected from the computer system it is possible that one of two things is happening.
The first thing is that a print job has been sent to the printer using the wrong printer driver on the computer system, this will send data to the printer that it does not recognize. If this is the case the print job on the computer system would need to be cancelled and resent using a printer driver suitable for the MT645.
The other thing that may have happened is that the Emulation setting on the printer may have for some reason changed so the printer not longer matches the set up on the computer system. You may need to change the emulation setting on the MT661 so it matches the host computer system set up. The printer may need to be set to either Epson or IBM emulation depending on the computer system set up.
The Current emulation setting on the printer can be found by printing a configuration page, this can be done in the following way;
Put the printer OFFLINE
Press the MODE button
Press the DOWN ARROW until HELP is displayed
Press ENTER
The printer will print out a configuration page showing the current settings, this will include the Emulation setting. This can be checked to ensure it matches the computer system set up, or change to ensure the emulation is correct for your application.
If you are printing from Windows try printing using the Generic Text only printer driver, this will not send escape commands to the printer, so should print correctly. If you still see the Bad Esc Seq message I would recommend having a look into the connectivity between he printer and the computer system.
May 22, 2009 | Tally MT645 Printer
WIRELESS 6650 lexmark will not print.
Most wireless printers need to be set up with USB lead and then you need to change the settings to wireless On my Lexmark on the computer it has advanced settings under the print settings folder then advanced setting then find printer and the software will usually fin the printer once that is down it may be a good idea to reboot the computer so the settings take effect
Jan 22, 2009 | Office Equipment & Supplies
Lines on a photo when printed
The print quality usually depends on the program you're using to print them on your pc.
Your camera only ever sends photos to your printer, so the best settings are already selected by the camera and it's built-in photo program.
Your printer doesn't 'know' whether your printing a document or a photo, so the settings for each program on your computer are basic (known as default settings), and need to be changed by you to get the best from your printer
Find the settings that let you alter the printers options (in Word, it's FILE \ PRINT \ PROPERTIES), and make sure the printer output is set to maximum quality, and that photo paper is selected as the paper type.
Some options such as 'maximum quality' only appear when you've chosen 'photo paper', and some printers (such as the ip4300) have seperate options for gloss or matte paper, so go through all of them until you see what you need.
Hope that helps :)
Oct 06, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Removal of border on bottom and right side of 8X10 print of color slide.
well this could be caused by a couple of things that i know about.
1: there is a line of dirton the drum, which may need to be cleaned to clear it.
2: there is a shadow set up when it prints now.
May 30, 2008 | Epson RX620 All-In-One InkJet Photo...
Can I set default printing to black and white for color laser printer?
Yes. Any printer's default options can be set as desired. Open the printer's properties (Start/Control Panel/Printers/right click the printer and left click Properties), and change the setting as you wish, then click OK. Those settings should be used each time you use the print command, unless you change the settings for that particular print job.
Hope this helps, and please rate my advice, good OR bad.
Feb 05, 2008 | Office Equipment & Supplies
Print size
Need to know what OS you are using - are you printing PCL or postscript. How are the computers connecting to the printer network or direct connection?
Nov 28, 2007 | OKI B4350 Laser Printer
Epson LX-300 can't print
Check your parallel port settings on the XP computer. Compare these setting with the settings on the computer where the printer works. If you are using serial port for printing, then check the serial port settings.
Jul 01, 2007 | Epson LX-300 Matrix Printer
Lexmark X4270 All-In-One InkJet Printer Logo
21 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
