Question about Matsonic MS9158E+ Motherboard
Connecting power leads and reset leads to motherboard?
  • Matsonic Master
  • 4,806 Answers
On the motherboard the pinouts on the front panel should be colour coded, and marked with letters like in this picture >>>>>
The connectors are also marked corresponding to where the connect on the motherboard, like in this picture >>>>>>
If the board is not colour coded then the motherboard will marked with the same letters, you may need a strong light to see the marks.
Regards.
Posted on Nov 13, 2009
I have disconnected all th ewire from my motherboard and i have installed all wire but unable to connect pw button,reset button,HDD led wire and anothed LED wire please tell me how can i install them in...
Locate the case connector pins on your motherboard. This will be a bank of two rows with 10-12 pins in each row. Each pin will be about 1 cm in length.2 Locate the power lead behind the power button on your computer case. The lead will consist of two thin wires, usually white and black, held together by a small plastic cap.3 Examine the underside of the power lead for an arrow or dot. If one is present, the marking signifies the first pin. This must correspond with the first pin on the motherboard, which will also be indicated by an arrow, dot, or number. If no markings are present, the lead can be installed in either orientation.4 Place the lead over the power pins within the pin bank. The correct pins will be indicated by a diagram on the motherboard, or by a picture in your motherboard's instruction manual.5 Connect the power cable to the back of your computer, and turn the computer on.
  • Oct 14, 2011 | ASUS P5PE-VM Motherboard
    I've uploaded the motherboard manual for you here: http://www.weeks-behind.com/fixya/MS9158E.PDF
    See page 14 and locate panel 2. Then refer to the panel 2 diagram on page 21, which show both the power and reset switches or leads.
    Jul 19, 2011 | Matsonic MS9158E+ Motherboard
    I am looking for the mother board connection diagram so i can connect the towers front panal ie power switch /reset ect
    Connect the front panel leads to the motherboard connector marked "JFP1" using the following pins as indicated by the markings on the motherboard and the front panel leads: HDD LED on Pins 1 and 3; power LED on Pins 2 and 4; reset switch on Pins 5 and 7; and the power switch on Pins 6 and 8.
    Good luck.
    Mar 03, 2011 | MSI 865GM2-LS Motherboard
    I have a gigabyte ga 81865gme775 mother board, can you give me the front pannel connection details
    hello jknr09
    my name is ausi
    i can not find your motherboard on gigabyte web site. however the boards nowadays are standard as far as front panel header goes.
    on gigabyte mother board you will see the hedae as two rows of pins like this.
    the bottom row first 4 pins are the speaker pins. the next single pin is void the next two are reset switch. the last two are hard disk lead.
    the top row first two pins are message lead (usually not used). the next two pins are power switch exactly opposite the reset switch.
    the power lead connection on gigabyte boards are a three pin header next to the front panel header.
    hopefully this is helpful.
    please vote for me
    Jan 20, 2011 | Intel Motherboard
    Computer will not power on after installing g41t-m motherboard. All connections were made according to manual. Any suggestions?
    Make sure that the ram you are using is compatible with this system board, also there two connections to the system board to the power supply (1) 24 pin connection and (1) 4 pin connection, are they both in there tight? Is the hard drive drive spinning? Are the connections correct for the reset and power switch. Double check the manual on those connections.
    Nov 02, 2010 | EliteGroup G41TM (V10) (G41TM(10))...
    Info to connect front panel leds
    Each of the ends of the cables that lead to the LEDs should be labelled, e.g., 'PWR/power', 'RST/reset', 'SPK/speaker', 'HDLED/hard-drive-LED', 'PWRLED/power-LED'.
    Connect each labelled connector to the labelled pins on the motherboard.
    May 29, 2010 | Matsonic MS9158EP (DSMTSMS9158EP)...
    KM18G pro motherboard power connection, reset sw, power sw, etc.
    Hi.
    You can download the manual for your motherboard here.
    Inside you will find information of where does each connector go. Each connector on the case has a marking on it (HDD, PWR, RST or similar) which stands for hard disk LED, power button, reset button and so on. Connect it to the right place, and problem is solved.
    If you need any further assistance, feel free to ask.
    Your responses are intended to improve the level of service provided. Please rate your experience.
    Jan 18, 2009 | Albatron nForce2 KM18G Pro (KM18G PRO 2.0)...
    Reset/power/led etc..lead connections
    on most motherboard it is possible to read there to set the wires.
    hope this helped a little.
    May 15, 2008 | Compaq Presario 5000 PC Desktop
    MS-6378 ver 2 Motherboard fitted to my Time Computer
    here it is your manual man
    http://asia.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=283
    msi site your board/the manual..youll have there at the beginning the diagram of wires and pins..
    I have a MSI too..great boards man..great boards..
    fixya:)
    bye
    Feb 07, 2008 | MSI MS-6378 Motherboard
    hi bob i need to know the motherboard's serial number then shouldn't be a problem finding the service manual for it with all the information you require some motherboards got that information imprinted near the pins if you look close enough
    Aug 05, 2007 | EliteGroup P4M800PRO-M Motherboard
    Matsonic MS9158E+ Motherboard Logo
    478 people viewed this question
    Top Matsonic Computers & Internet Experts
    David
    David
    Alan Hohenbrink
    Alan Hohenbrink
    Robert Karst
    Robert Karst
    Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
