Question about Pioneer SD-532HD5 53" Rear Projection Television
I HAVE A PIONEER 50' TV AND THE TV REPAIR MAN WORKED ON THE COLOR CONVERGENCE AND NOW HE SAYS THAT I HAVE TO FINE TUNE IT? the main problem was the blue line.
    Top Expert:
  • Pioneer Master
  • 14,553 Answers
YOU need to have the original Pioneer remote to do this--I do not understand if someone fixed and you had the remote why he did not adjust it?
With the Pioneer remote you go into the customer menu and adjust convergence--most also have a TECH menu for this but you still need the remote and a code to get into this--REMOTES FOR THESE SETS ARE HARD TO FIND AND EXPENSIVE.
Let me know if you have questions--I am here to help.
If this helped you, rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 13, 2009
It has color at the bottom of the screen almost halfway up. I need to know how much to fix.
Tv have colors lines R,G,B mis alignments,have colors shadows or 3D pictures?Yes?Mean ur tv have a dead convergence board to causes this problems known as a tv convergence picture problems.The tv convergence board must have to be fixed like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 06, 2011 | Pioneer SD-P50A5-K 50" Rear Projection...
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Red will not adjust correct with convergence, it is off mainly in the corners by a coupe inches. TV has not been moved in any way.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
Tv turns on but the screen is black. Before it went black we were haveing bands of color on the top and bottom and everthing was kind of like in three D they were all three colors and like 3 of them there.
Ur tv have convergence problems,now the 2 STK convergence ICS are completely dead,U lucky u tell it was 3D screen,before it go completely dead,went black screen.Or ur problems it will very hard to diagnose.U now how to do soldering?Must replaced 2 STK convergence ICS,some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 03, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
Bands of color show on bottom of screen -need service manual
Ur convergence it dead.U know how to solders?Tries websites.Tv repair World.com,Tvrepairkits.com.For the convergence kit.
Dec 17, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Replace a convergence chip on a tv
This is not specific to your set/model but should give you a good general idea.
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 29, 2009 | Pioneer Televison & Video
Colors dont line up and green is "dancing" all over screen
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
May 15, 2009 | Sony KP-57WS500 57" Rear Projection...
Green blnking light on pioneer plasma - Picture does not come on
You can try a hard reset : Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck..
Nov 23, 2008 | Pioneer PureVision PDP-5030HD 50 in....
TV shuts off seconds after being turned on
This is actually a common problem with this unit and one that Pioneer is aware of... Over time the feed resistors in the convergence circuit change in value and the convergence ICs begin to fail, placing more of a load on the power supply than necessary and stressing components in the SMPS. The fix; Pioneer recommends upgrading the convergence IC's from STK392-110 to STK392-180, change all resistors in the convergence circuit that have changed in value and replace the power supply to repair the unit.
Jun 27, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Convergence problem?
If it's OK when first turned on, I would suspect either bad solder connections on the convergence or power supply board, or capicators on either board heating up and breaking down. Pioneer parts are expensive, so I would look for a shop that can do component level repair. You may save about $100 or so.
Jan 18, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-532HD5 53" Rear Projection Television Logo
370 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
