Question about Microsoft Streets & Trips 2009 Full Version for PC
Always get "your registry setting for this application were not copied correctly (S&T 2009 w/ GPS)...." any suggestions? Joe M
  • 247 Answers
Uninstall the program completely. Then reinstall according to the software instructions. Then reconfigure your GPS hardware.
Posted on Nov 12, 2009
Get the following error message: Your registry
If you are installing this on Windows 7 or 8 you will have to contact Microsoft directly. You can use Microsoft Technet or knowledge base to try to find a solution but I have found a bunch of this same error on their site and it appears to be a major problem.
I do know that the registry error is often a mistake and the program may run correctly after you reboot. This is a serious issue with Window 7.
Oct 15, 2013 | Microsoft Streets and Trips 2013 B17-00563
When I started MS Streets and Trips 2010 with GPS, I got a window that said: "Your registry settings for this application were not copied correctly. To correct these settings, run Setup again for...
Look on the box to see if Windows Vista supports this software. If so, I would suspect you have a deficiency in the hardware. (i.e. Not a powerful enough video card, not enough memory or not a powerful enough processor)
Nov 22, 2010 | Microsoft Streets and Trips 2008 for PC
1)dell, optiplex GX520 2) SINCE ONE MONTH I TRIED THROUGH ANTI VIRUS I,E WINDOW DEFFENDER BUT NOT REMOVE
Manual Method:
Kill Process
1. Press CTRL+SHIFT+ESC
2. Windows Task Manager should pop up
3. Go to "Processes" tab
4. Kill "WP345d.exe", "eb.exe", "fix.exe", "ppal.exe" by ending the process. (There may only be one of these listed)
5. A warning prompt will come up, Click Yes to End anyway.
6. To confirm the spyware is no longer running, the icon should dissapear when you hover your mouse over the system tray in the lower right. (The icon is a red brick wall)
Remove Registry Keys
1. Press WIN+R (The WIN key is the key between CTRL and ALT that looks like a Windows logo)
2. In the run box, type "regedit"
3. Windows Registry Editor will pop-up. *Be cautious when editing the registry*
4. Navigate to the following folder on the left-hand pane, and delete the listed items below:
HKEY_CLASSES_ROOT\CLSID\{3F2BBC05-40DF-11D2-9455-00104BC936FF}
HKEY_CLASSES_ROOT\WP345d.DocHostUIHandler
HKEY_USERS\.DEFAULT\Software\Microsoft\Internet Explorer\SearchScopes "URL" => "http://search-gala.com/?&uid=201&q={searchTerms}"
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer "PRS" = "http://127.0.0.1:27777/?inj=%ORIGINAL%"
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings "UID" = "201"
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\5.0\User Agent\Post Platform "89770891803"
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run "Windows PC Defender"
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run "Windows PC Defender"
Registry Locations may vary, If you can not locate a certain item, use Edit > Find and type in the name of the key in quotes, For example:
To find...
Search for "Windows PC Defender" without quotes.
4. Delete the Folders
Navigate to the following folders through My Computer, and delete the listed items.
C:\Documents and Settings\All Users\Application Data\
Delete the folder "3ad5ffe"
c:\Documents and Settings\All Users\Application Data\
Delete the folder "345d567" (This is a randomly generated set of numbers/letters)
Delete folder "WPCDSys"
%UserProfile%\Application Data\ (Copy-Paste into Explorer's Address bar)
Delete folder "Windows PC Defender"
5. Reboot the PC and then refer to Step 1 to finish clean-up with MalwareBytes if necessary.
Oct 27, 2010 | Symantec Norton Internet Security 2009
I am using Vista Premier. My Streets & Trips
uninstall. type regedit in run. In the left pane click HKEY Local Machine. Find Software and Click. Find Streets & Trips Delete it 'All". close the box. clean your drive. Restart & reinstall
Jul 30, 2010 | Microsoft Streets & Trips 2009 Full...
Registry settings for this application were not copied correctly
it was 2008-2009 thats why it said it i have a vista computer 2 mine did the same thing the version last up2 2009 2008-2009 thats why
Jun 04, 2009 | Microsoft Streets and Trips 2008 for PC
Microsoft streets and trips 2009 registry issues on vaio p588e/r
Hi, go to the "streets.exe" file in the program folder, right-click it and go to "Properties". Click the "Compatiblity" tab and uncheck "Run this program...". Try it now. It's what I had to do.
May 03, 2009 | Microsoft Streets & Trips 2009 Full...
Your registry settings for this application was not
Hi
My personal openion is , by using just only Registry cleaners will not solve your problem
We need to get rid of every supported file.
so suggest you for
1) Uninstall the application
2) Restart
3) Use Regsitry Cleaners
4) After successfull cleanup of regsitry go into registry for manual removal by clicking Start -> Run --> Regedit
5) Now locate HKEY_LOCAL_USER -> Software ->
Here locate the application matches with the name of MS Streets (actually i have not used this, so i am not sure about the exact name, but i am sure that you will locate it)
And DELETE that key
6) Same is for HKEY_Current_User--> Software
7) Now go into System Drive (usually C drive) and locate the programfiles -> MS Streets
(again i have not used this, so i am not sure about the exact name, but i am sure that you will locate it)
And DELETE It.
8) Now restart the system
9) Now we need to use some JUNK FILE CLEANERS for get rid of other supported files
so i suggest you to go with Tune-Up Utilities 2008 version (its trial ware for 30 Day - Fully Functional)
so from that use your JUNK FILE CLEANER
10) After successfull clean up i incist you to execute the Defragmentation process on system drive (usually C drive) so that we can close the backdoor for support files.
11) So after doing all above MAINTANANCE then try to install the application once again
If problem persists.
Please let me know, then I personally get involved with this topic
Thanks
Sep 17, 2008 | Microsoft Streets and Trips 2008 for PC
Microsoft Streets & Trips 2005
Maybe if enough people come together and post our opinions they'll listen. Lets get everyone with these problems to post their problems. United we stand and devided we fall
Jun 01, 2008 | Microsoft Streets and Trips 2008 for PC
Microsoft Streets & Trips 2009 Full Version for PC  Logo
107 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
