Question about Dell M992 Monitor
My Dell M992 monitor screen is blurry and there are squiggly lines running through it. The color is perfect. I even changed the resolution with no luck. Is it time for a new one or can it be fixed? I purchased it in 2003 w/the desktop.
  • 101 Answers
Check the cable going from the pc to the monitor and ensure the connections are secure. You also may want to try moving the cable away from any other power cords if possible.
If this does not help then most likely it is time for a new one.
Posted on Nov 12, 2009
Screen resolution desktop
go to control panel from start menu. change resolution to 1280
May 03, 2013 | Dell E2011H Monitor
I've got a LG flatscreen monitor and a projector as my extended display,when i play my videos i see flyback lines on my screen,my pc is brand new
First check resolution settings make sure PC and monitor are set to same. Also make sure cable(s) are tight.
Mar 15, 2011 | Dell M992 19" CRT Monitor
I get the Monitor is in power save mode and won’t boot normally. It will boot in VGA mode but then goes haywire when you try to change the screen resolution. I’ve also gotten a blue screen saying a problem...
Usually this problem happens when the video card is sending a signal to the monitor that the monitor does not recognize. (Kind of like me telling you how to fix this problem in a language I dreamed up myself.) The monitor will work on a different computer, because that computer has a video card "talking" to the monitor in a language it understands. So the solution is a different monitor that has a resolution setting your computer can talk to. Possibly you can borrow one, change the resolution of the card, and put your own back in. You can plug in and unplug monitors while the computer is on with no problem, to test.
Nov 01, 2017 | Dell M992 Monitor
Blurry resolution and screen smear until it has been running for several minutes
Check the video card first, if you have another vidoe card try it. If that does not shore up the problem the monitor would be a issue, and now a day monitors are dirt cheap even for the LCD monitors so I would look into buying on of those if your inclined to do so.
Rulds2008
Apr 29, 2009 | Dell UltraScan P780 (Black) Monitor
How can I make fonts look good in an LCD monitor ?
The VGA connection should be fine; I have DVI and when I switched from analog, the difference was pretty minimal, to my eyes.
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
If that doesn't work, I'm probably out of ideas, unless you have further information.
Mar 08, 2009 | LG Flatron L1750S 17" LCD Monitor
Westinghouse LVM-37W3SE PC Monitor
1. Genaraly 14" and 15" Monitors supported Up to 800by600 some monitors 1024by768pixels 17"monitors supports 1024by 768 to 1280by960 pixels and Other 19",21" are supported 1280by1024 pixels at the same time change the screen Refreshrate at display properties.
Oct 01, 2008 | Computers & Internet
Power but no display
does the screen show no signal, it could be from thedigital button setting on the monitor try to adjust the setting,
2.check the video card ,you can test it on another system,test the monitor on another systems thats working fine if it continues may be its frm the systems or the monitor tube is bad if your using the correct resolution
May 26, 2008 | Dell M992 19" CRT Monitor
Dell m992 monitor screen width
The link below is a Digitally signed M992 monitor driver. http://support.us.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R44148&formatcnt=1&libid=0&fileid=51992 Also try upgrading to the latest ATI software and drivers. You can also try and change the frequency refresh rate to 75mhz. It in the Control Panel under 'Display' and tab 'Monitor'. It shows a list for frequencies you can try.
Oct 02, 2007 | Dell M992 19" CRT Monitor
Dell M922 monitor problem
To change the resolution back to something more reasonable go to the control panel (start, settings, control panel) and double left click on the Display icon. Click on the settings tab. The color quality should be set a high as possible, usually 32 bit or true color. Then click on the Advanced button in the lower right corner and on the next screen click on the Monitor tab. In the Monitor settings make sure the Screen refresh rate is set between 70 and 75 Hertz (the higher the number the less obvious the screen flicker will be but don?t set any higher). Click on the OK button to go back to the previous screen. Once that is set you want to increase the Screen Resolution using the slider bar to the left. For a 19? screen you would want to set it to a minimum of at least 1024 x 768. The typical setting is 1280 x 1024 depending on monitor / video card capabilities and personal tastes. Once you get the resolution back to the original settings your screen will display as it did before the ?change?. If you find another resolution setting you like better we?ll need to make some adjustments to the monitor itself. Just let us know. Ordinarily screen resolution changes doesn?t just happen, it?s usually the result of a program, user or problem. If that is the case you?ll need to post anther question along with details about what is happening just before the change occurs along with your operating system and any other pertinent information.
Mar 18, 2007 | Dell M992 19" CRT Monitor
Computers & Internet Logo
354 people viewed this question
Alun Cox
