My ddr does not work(p4vmm2)
How to use my ddr slot for my p4vmm2.it doesnt work.
    Novelist:
  • 186 Answers
Have you researched the RAM you are putting into your Motherboard to make sure it is compatible. There are a couple different type of RAM which look the same, but may have ECC ( error correction ) which would make it different. There are also different CAS speeds. Do you get a beep code when you put the ram in? These questions must be answered before proceeding.
Posted on Nov 12, 2009
What is memory card EliteGroup P4VMM2 V8.1 Motherboard
You will need to install either DDR RAM (DDR 200 or DDR 226) or SDRAM (PC133 or PC100) memory. You cannot install both, you need to choose. The motherboard supports a maximum 2GB and there are two DDR and two PCI slots so 1GB +1GB would be the assumed maximum.
More details on your Motherboard here: http://www.motherboard.cz/mb/ecs/P4VMM2%20V1X.htm
Sep 03, 2010 | EliteGroup P4VMM2 V8.1 Motherboard
Parts upgrade
The 333/400 is the speed of the RAM in MHz 333 and 400 MHz. That corresponds with PC2700 and PC3200 that is in your specification.
250 GB hdd will work. Make sure that it is IDE and make sure that you connect the jumpers for master/slave the correct way.
As for the graphic card. If you have this one 'VGA SPARKLE 7300GT 512MB DDR2 128BIT PCI-X' than it will not work because it is a PCI-X card not an AGP card. You will need an older card for this motherboard.
best regards
Mar 23, 2009 | EliteGroup P4VMM2 Motherboard
Can i install 1GB ddr2 on P4VMM2 Motherboard? i want to upgrade my pc; board is: can i P4VMM2 Motherboard; cani i use 1GB ddr2 on this and a 512 MB if vid.card? -jayvee_yao@yahoo.com
Unfortunetly you cannot use ddr2 memory on this motherboard. The motherboard supports only PC2100/PC1600 DDR memory if you have version 8.1 of the motherboard. If you have v5.0 of the motherboard than you can only use sdram or ddr 266Mhz RAM. The same goes for the video card. The p4vmm2 motherboard is a rather old motherboard so I don't think it will payoff to upgrade the computer. It will be probably the best if you buy another computer.
best regards
Ddr not detected
if you want to use ddr ram with p4vmm2 mother bord you must replace the jumper near by the ddr2 slot
then your computer starts to work with ddr ram at 266Mhz also 400 Mhz too.
Feb 09, 2009 | EliteGroup P4VMM2 Motherboard
Memory Upgrade - from 256DDR1 to 1GB DDR1
sysa007,
EliteGroup makes two mother boards, P4VMM2, (No Revisions) & (P4VMM2 revision 8.1). Since your question states your memory is 184 pin DIMM your board must be, v 8.1. What does not make sense is the motherboard has two memory slots total.
(If you have 4 memory slots on the MB than the MB can not be the P4VMM2). Below is the link for the P4VMM2 (v8.1).
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&TypeID=1&DetailID=436&DetailName=Feature&MenuID=45&LanID=9
The P4VMM2 v 8.1 can only use, two Double Data Rate (DDR) SDRAM memory modules. These sockets support up to 1GB system memory using 184-pin unbuffered non-ECC PC2100 or PC1600 DDR DIMMs. The two DIMMS you are using must run at the same speed.
Example PC2100 266MHz. OR PC1600 266MHz.
Continuous beeping means the memory is not seated correctly.
When using only one DIMM it should be inserted in the slot closest to the CPU. Re-check your memory. Remove & reseat. Make sure the latches snap closed on each stick of memory while inserting. Below is all of ECS P4VMM motherboards;
http://www.ecsusa.com/ECSWebSite/SearchResult.aspx?q=P4VMM2&f=Products&MenuID=104&LanID=9
Good luck sysa007!
More question, post here.
Thank you for using fixya.
If you find this helpful, please vote.
Mike
Jan 31, 2009 | EliteGroup P4VMM2 Motherboard
SDR TO DDR JUMPER
you can download the manual of your P4VMM2 through this link http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=46&DetailName=Manual&DetailDesc=P4VMM2%20%20(V1.1A)&CategoryID=1&MenuID=82&LanID=0
after download read the manual, it think in page 11. on your manual you can check the jumper settings.. Hope this would help...
Sep 24, 2008 | EliteGroup P4VMM2 Motherboard
Upgrading VIDEO CARD
If your motherboard's graphics slot is AGP and your graphics card is AGP then it should be fine if your motherboard is PCI-E and graphics is PCI-E it also is fine make sure your motherboard and graphics are compatible.
May 29, 2008 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
Critical after DDR333 upgrade
cadyshack,
I got your latest version (8.1) motherboard on my screen & ECS shows your board does not support PC2700, only PC2100.
Downloaded your manual to verify this.
Notice you started having problems after upgrading RAM.
Link to your manual:
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=436&DetailName=Manual&MenuID=7&LanID=9
This motherboard accommodates two 184-pin DDR DIMM
sockets for up to 1GB memory. Supports PC2100/PC1600
unbuffered non-ECC DDR DIMMs.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=548&Nav=|c:147|&Sort=0&Recs=10
Good Luck!
Mar 18, 2008 | EliteGroup P4VMM2 Motherboard
Ecs mb model p4vmm2
in as much as there is a ddr slot, it could be used, no need to adjust any switch.
uzowuanya
e-mail:uzowuanya@yahoo.ca
Oct 20, 2007 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
P4VMM2 Motherboard problems with RAM Cards changing fron SDRAM to DDR
Depending on your version of motherboard, it may only take ddr when you change the motherboard jumpers, as i assume you have 2 SDRAM and 2 DDR slots, but you will need to refer to your manual
Apr 10, 2007 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
