Question about Adapters.com Serial ATA IDE Converter and IDE to SATA Converter (SSIDEDD1)
Ide to usb connector sata cable attachment
Bought an ide to usb connector and wanted to connect a sata female cable into it pls help with the pinouts. tnx
  • 1 more comment
  • alfredojrgal Nov 13, 2009
    http://i236.photobucket.com/albums/ff134...
    i wanted that sata cable to be attached with that ide to sata converter but i only got this:
    SATA pinout
    Pin Name Function
    1 GND Ground
    2 A+ Transmit+
    3 A- Transmit-
    4 GND Ground
    5 B- Receive-
    6 B+ Receive+
    7 GND Ground
    http://i236.photobucket.com/albums/ff134... i wanted that sata cable to be attached with that ide to sata converter but i only got this: SATA pinout Pin Name Function 1 GND Ground 2 A+ Transmit+ 3 A- Transmit- 4 GND Ground 5 B- Receive- 6 B+ Receive+ 7 GND Ground
  • Bob Kitaji May 11, 2010
    What are you trying to do?
  • 70 Answers
The connection should be simple where you match the connections. The long connection is for the power and the short is for data. You can't really mess up the connection but be carefull when trying to connect and not to force the connections.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Posted on Nov 12, 2009
Should the sata cable be hooked up to the cd drive or the hard drive and where can i find pictures of where the inside cables should be attached to
One end of the Sata Cable is to be attached to the CD/DVD (Optical Drive) or Hard Disk, whereas the other end is to be attached to the motherboard. The Sata connections on the motherboard are located near the CMOS/RTC Battery as indicated below: - (Blue, White, Yellow and Black, at right-hand top corner)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 04, 2011 | HP Pavilion a1540n PC Desktop
Hard disk not getting detected.Seagate 80 GB
One bad lead can cause a computer to fail to detect a hard drive continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
problems
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 11, 2010 | Seagate Computers & Internet
Psu
Hmmm.... mainly you have:
-20 or 24-pins connector, that is unique and goes directly to motherboard (powers motherboard and its components)
-4 or 8-pins connector that powers CPU
-the rest would be connectors for ROM (CD/DVD/BlueRay) and HDD devices (there are: molex and sata power conectors)
If you totaly unshure, there is manual:
Illustrated How to Replace an ATX Power Supply
Sep 05, 2009 | Computers & Internet
What is this system ide or ?? looking to purchase a hard drive (500gb) and a new CD & DVD burner.. Just don't want to buy the wrong item.
What mother board is it? you have sata and ide drives.. new technology is sata which is connected with sata cable to *********** board and appropriate pover coard, the older teconlogy is ide, which is connected with ide (master slave) cable frm you motehr board to you drive... just post what mother board and i could be more specific...
Jun 28, 2009 | HP Pavilion a705w PC Desktop
Installing a IDE to SATA converter adapter
I have successfully connected a older. 20 GB drive to a computer with a 2. sata connection on the mother board.
Buy trial and error I found that connecting a power cable to the converter and the hard drive was the only way to get the Bios To recognize the drive.
Done sucessfuly with a 40GB drive as well, Set drive to master.
Feb 21, 2009 | Generic Memory (RXD639) Serial ATA...
Connecting new hard drive
If the old one is still conected you can connect it the same way if not here is how to::
Well firstly they are 2 types IDE (large connector) and SATA (small connector)
IDE
of an ide cable has 3 jacks 1 for the main board and 2 for IDE drives
2 drive must be set to master and the other to slave
Set the drives by using the jumper on the back the instructions are written on the drives
Connect the Ide Cable and then the power and turn you system on
IF ITS SATA
connect the sata cable to both hard drive and main board
connect the power cable and your done!!
NB:: sata ports are labeled SATA 1 SATA 2 etc
IDE are LABELED IDE 1 IDE 2
Ide is a large grey cable black connector SATA is usually orange or red and small
Oct 26, 2008 | Gateway (M520HD80G) Hard Drive
I have 3in1 USB 2.0 to IDE & SATA Cable but nothing to show me how to use this kit
SATA 3.5" 2.5" IDE 3 IN 1 TO USB 2.0 CABLE ADAPTOR KIT
1 external connection kit
1 internal connection kit
The internal connect kit consists of 1 red USB connector cable
and 1 internal white male molex connector to SATA female power connector
( 1 yellow wire , 2 black wires , 1 red wire )
the external connect kit
consists of a 3 pin power adaptor (with a tiny plug to save space) feeding a power supply which powers either IDE thru a Molex connector or SATA through a supplied adaptor. Supplied also are data connectors to link the IDE or SATA hard drive with a USB port. Use this adaptor set to retrieve data from a hard drive when it is not mounted in a computer.
Selah :-)
Sep 14, 2008 | Computers & Internet
Mitsumi FA4o4M Combo Floppy Card and Data card reader/writer
black cable to be connected on a free usb outlet on the motherboard
Feb 02, 2008 | Mitsumi (FA404MBLACK) (fa404m/black)...
I need to add a hard drive to my HP a1220n Pavilion for Photoshop and other Graphic programs. How can I do it if there is no available slot? Please help.
A desktop PC would normally have capacity for 4 IDE devices such as 1 CD/DVD, 3 HDs or any combination limited to a total of 4. Additionally, most current PCs have 2 SATA connection points. If for some reason all are occupied and hence your post "no available slot", you may want to consider using an external storage device attached via any USB port of your PC.
Hope this be of some help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Nov 07, 2007 | HP Pavilion a1220n (A1220NED904AA) PC...
Computers & Internet Logo
119 people viewed this question
Top Adapters.com Computers & Internet Experts
T-Comtech Repairs
T-Comtech Repairs
Are you an Adapters.com Computer and Internet Expert? Answer questions, earn points and help others
