Question about Maytag Washing Machines
Water leaks out the top of the Injector Sleeve Bracket, which does not have a cover. Is this part necessary? Can the 2 water tubes be joined by a standard water tight connector?
  • 464 Answers
If this part is about 2 1/2" long and black rubber and has a white plastic tube inside it, yes it is necessary and do not take it out. the rubber is probably getting thin and causing the leak. they are not expensive parts and should be replaced. can do yourself.
Posted on Nov 13, 2009
Not a solution
my washer has the same problem but coming out of the water injector bracket it fills up and overflows
Posted on Jul 12, 2013
Maytag heavy duty washing machine quiet series 100 leaks water from the top panel
Older maytags were equipped with an "air-gap" that can leak if the rubber sleeve part of it gets too stiff and cannot flex. It is along the left hand side of the machine fastened by a 5/16" screw between the machine cabinet and the upper panel... Maytag Injector Tube 12001677
If you remove the front panel and set the machine to fill, you should see water dripping off of the plastic frame the injector is sitting in.
If it is a newer maytag, check the fill spout for cracks or sediment build-up Maytag Water Supply Tube WP3360977
Jun 06, 2016 | Maytag Washing Machines
Amana SXD23V refrigerator leaks water underneath the side where the refrigerator door is evey time I try to get water out of the dispensor. I found a plastic tube on the floor about an inch long then...
I believe your water line or the union nut just behind the kickplate may have come loose. Lets see if we can find a repair kit and get you going again. Depending on where the line is broken or leaking will depend on just how much you will need to do so if leaking at the union nut please disregard removal of door.
WARNING
To avoid risk of electrical shock, severe personal injury or death; disconnect power to unit before servicing, unless
testing requires power. Discharge capacitor through a 10,000 ohm resistor before handling. Wires removed during
disassembly must be placed on the correct terminals to ensure proper grounding and polarization.
sea_breeze_2.png Here are the instructions from the manual below.
1. Open door and remove all storage buckets.
2. Remove toe grille.
NOTE: Shut off water supply before performing Step 3.
Have a bucket ready to catch spillage from tube.
3. Loosen water-tube clamp screw. Loosen plastic
water-tube union nut. Pull water tube away from
union nut and through tube clamp.
4. Remove screw that mounts door closure to top
surface of bottom hinge.
5. Close door.
6. Remove screw holding top hinge cover in place.
Remove top-hinge cover.
7. Unplug wiring harness connectors. Remove ground
screw and ground wire from top hinge.
8. Remove top hinge and hinge bushing. Pull hinge and
bushing off wiring harness.
NOTE: Hinge shim is glued to top of cabinet and must
be left in place.
9. Lift door about 3 inches to bring lower hinge bushing
up, off hinge pin.
10. Set bottom edge of door on protective pad. Remove
hinge pin (with door-closure tab) from bottom hinge
bracket.
11. Reverse procedure to rehang door.
For plastic tubing click HERE
and for a simple snap on coupling I want you to call to insure you get the correct size and snap on union.
  • 1-800-269-2609, 8 am to midnight ET, 7 days Repair Clinic are very helpful and friendly and will be happy to answer your questions. I also will be here to answer any questions you may have, Thanks, Sea Breeze
  • Jul 25, 2011 | Refrigerators
    How do i change the water pump belt on a 2001 Cadillac Deville .
    2001 Cadillac Deville 4.6L SFI DOHC 8cyl Removal & Installation procedure...
    1. Before servicing the vehicle, refer to the Precautions section.
    2. Drain the coolant.
    3. Remove or disconnect the following:
    Negative battery cable
    Upper fill panel, if equipped
    AIR injection control valve, if equipped
    Air cleaner
    Oil level indicator tube nut, if necessary
    Water pump belt cover
    Water pump drive belt
    Lower radiator hose
    Thermostat bypass hose from the coolant inlet housing
    Water pump cover
    4. Remove the water pump by rotating it clockwise using special Tool J 38816-1A (water pump remover/installer).
    To install:
    1. Install the water pump with a new O-ring, by turning it counterclockwise using the special tool, until it stops. Torque the water pump to 73 ft. lbs. (100 Nm).
    Fig. To ensure proper operation, be sure to install a new O-ring (click for zoom)
    2. Install or connect the following:
    Water pump cover. Torque the bolts to 89 inch lbs. (10 Nm).
    Lower radiator hose
    Thermostat bypass hose to the coolant inlet housing
    Air cleaner
    3. Refill and bleed the cooling system.
    4. Run the engine and check for leaks.
    Hope this helps (remember to rate this comments)
    Mar 10, 2011 | 2001 Cadillac DeVille
    How to reassemble ice dispenser parts od kenmore model 106.5706*602
    Clean out the new ice maker with warm soapy water.
    Ensure that the floor surface under your refrigerator is level. If the floor surface under your refrigerator isn't level, you can place shims under the legs of the refrigerator to fix the uneven surface.
    Turn off the main water supply to your house.
    Clear the water line by running the faucets until the pipe clears.
    Screw the copper supply line's connector to the house's cold water connector valve. Use an adjustable wrench to tighten the connection.
    Slide the compression sleeve and nut onto the other end of the copper supply line. The compression sleeve and nut will wrap around the outside of the copper supply line.
    Bend the copper supply line to fit into the water line inlet casing located on the back of the refrigerator. Leave slack in the line so that the refrigerator can be pulled away from the wall or cabinets. The water line inlet casing is a plastic bracket used to hold the copper supply line in place so that there is no pull on the tubing's connection. It is the larger of the two plastic brackets located on the back of the refrigerator.
    Insert the compression sleeve located around the end of the copper supply line into the ice maker connector. The ice maker connector is already installed on the back of the Maytag refrigerator.
    Tighten the nut over the connection between the compression sleeve on the copper supply line and the ice maker connector with an adjustable wrench.
    Attach the water supply tube clamp to the water supply line by clipping it into place. The water supply tube clamp is a plastic bracket located on the back of the refrigerator that holds the supply tube so that it doesn't rattle and become disconnected. It is the smaller of the two brackets located on the back of the refrigerator.
    Turn on the main water supply.
    Check all connections for leaks.
    Position the drain hose located on the back of the ice maker over your floor drain. Use a PVC pipe if you need to redirect the drain hose flow so that it falls over the floor drain. The PVC pipe should not touch the drain hose and should have no low point where the water can settle.
    Plug the ice maker into a 3-prong grounded outlet.
    Feb 05, 2011 | Kenmore Refrigerators
    I recently changed the alternador belt on a 2001 chevy metro lsi, afterwards whenever i start the car , there is this rattling noise and when i opened the hood to check , to the left of the alternador...
    Water Pump REMOVAL & INSTALLATION Metro
    1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
    2. Drain the cooling system.
      • Negative battery cable
      • Air cleaner
      • A/C compressor suction pipe bracket, if equipped
      • Loosen the water pump pulley bolts. Do not remove them at this time
      • Right side lower splash shield
      • A/C compressor drive belt
      • Lower alternator cover plate
      • Water pump/alternator drive belt
      • Crankshaft pulley
      • Water pump pulley
      • Timing belt
      • Dipstick tube
      • Upper alternator bracket from the water pump
      • Water pump and discard the gasket
      To install: Fig. 1: To ensure a tight seal, be sure gasket surfaces are properly prepared - Metro 7922z704.gif
    4. Clean the gasket mating surfaces thoroughly.
    5. Install or connect the following:
      • Water pump with new gasket. Torque the bolts to 115 inch lbs. (13 Nm).
      • New rubber seals
      • Upper alternator adjusting bracket
      • Oil dipstick tube
      • Timing belt
      • Water pump and crankshaft pulleys. Leave the water pump pulley bolts hand-tight
      • Alternator drive belt
      • Lower alternator cover plate. Torque the bolts to 89 inch lbs. (10 Nm).
      • A/C compressor drive belt, if equipped
      • Right side lower splash shield.
      • Torque the water pump pulley bolts to 18 ft. lbs. (24 Nm).
    6. Adjust the water pump drive belt tension and torque the alternator adjustment bolt to 17 ft. lbs. (23 Nm).
    7. Install or connect the following:
      • Air cleaner
    8. Refill the cooling system.
    9. Start the engine and check for leaks, repair if necessary.
    Prizm 1.6L ENGINE
    2. Drain the engine coolant.
      • Negative battery cable and properly support the engine
      • Right side engine mount and support
      • Upper and middle timing belt covers
    4. If equipped with power steering remove the following components:
      • Front transmission mount
      • Radiator fan motor
      • Coolant reservoir
      • Upper radiator hose
    5. Remove or disconnect the following:
      • Crankshaft Position (CKP) sensor electrical connector from the dipstick tube
      • Dipstick tube
      • Engine Coolant Temperature (ECT) sending unit
      • Coolant inlet pipe
      • Water pump and discard the O-ring Fig. 2: Remove the coolant inlet pipe from the block, then the pump - Prizm 7922z705.gif
      To install:
    6. Install or connect the following:
      • New O-ring and Water pump. Torque the bolts to 10 ft. lbs. (14 Nm).
      • Coolant hose to the pump
      • Coolant inlet pipe. Torque the fastener to 11 ft. lbs. (15 Nm).
      • Dipstick tube. Torque the bolt to 89 inch lbs. (10 Nm).
      • ECT sending unit to the dipstick tube
      • Engine wire harness. Torque the bolt to 89 inch lbs. (10 Nm).
      • Radiator fan. Torque the bolts to 52 inch lbs. (6 Nm).
      • Coolant reservoir
      • Front transmission mount. Torque the bolt to 47 ft. lbs. (64 Nm).
      • Upper and middle timing belt covers. Torque the bolts to 62 inch lbs. (7 Nm).
      • Right side transmission mount and insulator. Torque the bolt to 47 ft. lbs. (64 Nm).
    7. Fill the cooling system.
    8. Start the vehicle and check for leaks, repair if necessary.
    1.8L ENGINE
      • Drive belt
      To install:
    4. Install or connect the following:
      • New O-ring and water pump. Torque the bolts to 8 ft. lbs. (11 Nm).
      • Drive belt
    5. Fill the cooling system.
    6. Start the vehicle and check for leaks, repair if necessary.
    Jan 02, 2011 | Chevrolet Metro Cars & Trucks
    How to remove intake manifold on 2005 Buick Lesabre
    You didn't post the size of your engine so please pick the appropriate one:
    3.8L
    1. Relieve the fuel system pressure.
    1. Remove or disconnect the following:
    2. Negative battery cable
    • Supercharger
    • Thermostat housing
    • Exhaust Gas Recirculation (EGR) tube at the intake manifold
    • Engine Control Temperature (ECT) sensor
    • Intake manifold
  • To install:
    1. Install or connect the following:
      • Intake manifold with new gaskets. Torque the bolts, working from the center out, to 11 ft. lbs. (15 Nm).
      • ECT sensor connector
      • EGR tube to the intake manifold
      • Supercharger
    2. Refill and bleed the cooling system.
    3. Run the engine and check for leaks and proper engine operation.
    4.6L
    4.6L Engine
    1. Remove the brake booster hose from the throttle body.
    2. Remove the fuel pressure regulator vacuum tube from the fuel pressure regulator and the water crossover.
    3. Remove the PCV fresh air feed tube from the camshaft cover and the throttle body.
    4. Remove the PCV dirty air tube from the PCV orifice in the right camshaft cover and from the intake manifold.
    5. Disconnect the fuel injector electrical connectors from the fuel injectors.
    6. Remove the fuel injector wiring harness.
    7. Remove the fuel rail bracket nut from the engine lift bracket.
    8. Remove the fuel rail studs.
    9. Lift and remove the fuel rail with injectors.
    10. Loosen the plenum duct clamp in order to remove the intake manifold.
    11. Remove the intake manifold bolts.
    12. Remove the intake manifold.
    To install:
    1. Install the intake manifold, fitting the plenum duct over the intake manifold duct.
    2. Loosely install the intake manifold bolts.
    // // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 45; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos'; c17hydro_21.gif
    Intake manifold torque sequence-4.6L engine
    1. Tighten the intake manifold bolts in sequence. Tighten the intake manifold bolts to 89 inch lbs. (10 Nm).
    2. Tighten the plenum duct clamp to the intake manifold. Tighten the plenum duct clamp to 24 inch lbs. (2.75 Nm).
    3. Inspect the fuel injector O-rings. Ensure the fuel injector O-rings are not missing, misaligned or damaged. Replace the O-rings if necessary.
    4. Lubricate the intake manifold fuel injector bores with light mineral oil (GM P/N 9981704), clean engine oil, or equivalent.
    5. Install the fuel rail with fuel injectors as an assembly.
    6. Install the fuel rail studs. Tighten the fuel rail studs to 80 inch lbs. (9 Nm).
    7. Install the fuel rail bracket nut to the engine lift bracket. Tighten the fuel rail bracket nut to 89 inch lbs. (10 Nm).
    8. Install the fuel injector wiring harness.
    9. Connect the fuel injector electrical connectors to the fuel injectors.
    10. Install the PCV dirty air tube to the PCV orifice in the right camshaft cover and to the intake manifold.
    11. Install the PCV fresh air feed tube to the camshaft cover and the water crossover.
    12. Install the fuel pressure regulator vacuum tube to the fuel pressure regulator and the throttle body.
    13. Install the brake booster hose to the throttle body.
    Nov 13, 2010 | Buick LeSabre Cars & Trucks
    Leak from just at the bottom of the water heater (where the tube joins the heater).
    The tube probably has a crack and is leaking.
    As you may know by now cuisinart does not sell internal parts for thier coffee makers. I found mcmaster.com has the high temp tubing. try part number 5236k73
    cost is about 2.50 per foot.
    Note that in the coffee maker, there are two tubes, one is the cold water going down to the heater and the other tube is the hot water going back up to the top. The cold water tube has a flow regulator in it and this should be cut out of the old tube and placed into the new replacement tube (going the same direction).
    Jul 06, 2010 | Coffee Makers & Espresso Machines
    How to replace head gasket on 1999 2.5 cyl ford ranger
    Cylinder Head Removal
    1. Disconnect the battery ground cable
    2. Relieve the fuel pressure.
    3. Drain the cooling system. Disconnect the three way catalytic converter Loosen the water pump pulley bolts.
    4. Remove the drive belt.
    5. Remove the water pump pulley, fan and clutch assembly.
    6. Remove the intake manifolds
    7. Remove the ignition wires from the spark plugs .
    8. Remove the spark plugs; .
    9. Remove the oil level indicator tube
      • Remove the bolt.
      • Remove the oil level indicator tube.
      • Remove the EGR valve to exhaust manifold tube
      1. Remove the valve cover
      1. Remove the drive belt .
      1. Recover the A/C refrigerant; refer to Disconnect the engine control wiring from the A/C compressor
      2. Remove the A/C compressor mounting bracket (2882) with the power steering pump (3A674) attached and position out of the way.
      3. Disconnect the engine control sensor wiring connector from the generator
      4. Disconnect the (1) lower radiator hose and the (2) water pump inlet tube
      5. Remove the upper radiator hose
      6. Remove the water pump inlet tube.
        • Remove the bolts.
        • Remove the water pump inlet tube.
      7. Remove the generator.
        • Remove the bolts.
        • Remove the generator.
      8. Remove the generator mounting bracket.
        • Remove the bolts.
        • Remove the bracket.
        1. Remove the ignition wire and bracket; refer to Section 303-07A .
        1. Remove the outer timing belt cover; refer to the procedure in this section.
        1. Remove the timing chain/belt (6268); refer to Timing Drive Components—Timing Belt in this section.
        1. Remove the exhaust manifold (9430); refer to Exhaust Manifold in this section.
        1. Remove the cylinder head .
          • Remove the bolts and discard. (should get new ones)
          • Remove the cylinder head.
          • Remove the head gasket and discard.
    Installation
    1. Clean all gasket mating surfaces.
    1. Install new gaskets as necessary.
      • Use new cylinder head bolts.
    1. Follow the removal procedure in reverse order.
    1. Tighten the bolts in sequence, in three stages, to 70 Nm (51 lb/ft).
      • Stage 1: Tighten all bolts to 70 Nm.
      • Stage 2: Retighten all bolts to 70 Nm.
      • Stage 3: Tighten all bolts an additional 90-100 degrees.
    2. Install generator bracket. Install bolts in four stages.
      • Stage 1: Hand-start bolt 1.
      • Stage 2: Install and tighten bolt 2.
      • Stage 3: Install and tighten bolt 3.
      • Stage 4: Tighten bolt 1.
    3. Install the A/C compressor mounting bracket. Install the bolts and the stud.
      • Tighten the M10 bolts and stud to 48 Nm (35 lb/ft).
      • Tighten the M8 bolt to 25 Nm (18 lb/ft).
    Mar 10, 2010 | 1999 Ford Ranger SuperCab
    Water Supply Line for Ice maker and Water dispenser is leaking.
    Hi, The fitting either needs tightened or changed. Is this a brass or plastic fitting?
    If the supply line is still ok and not brittle, you can go to your local hardware store and get the new fitting parts. If it is brass, be sure and get the brass insert that goes inside the tubing as well as the compression ring.
    Please let me know if I can assist you further.
    Vic
    May 28, 2009 | GE Profile PSS26NGS Side by Side...
    Water Leak Top Load Maytag Washing Machine
    you have a leaking "injector sleeve". you need to remove the 2 screws that hold on the front panel ( they are at the bottom) once you remove them, pull the panel outwards, towards your knees. it will release. on both sides in the top you have 2 bolts, remove them, it think they are 3/8ths. on the left if you have a bleach dispenser, remove that hose before you lift the lid. Once the lid is up you will see the injector area on the top left at the side. Hope that helps
    Mar 02, 2009 | Washing Machines
    Washing Machines Logo
    145 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
