Question about JBL S120PII Subwoofer
Wiwing question HELLO...INSIDE THE SUB ...WHAT IS THE SMALL WHITE AND BLACK WIRE FOR?...I HAVE AN AMP OUT OF A S120PII THAT I WANT TO USE ...I THOUHT THAT THOSE TWO SMALL WIRES MIGHT BE FOR A THERMAL SWITCH...I CHECKED THE MANUAL NOTHING THERE...THANKS
Its for the led light red and green red means in standby position and green means its on
Posted on Jan 23, 2010
Wantneed diagram for G.E. TL412CP sub panel
Do you have any wiring in the panel already? The green or bare copper wires will go the ground bar which will be screwed directly on to the inside of the box. The ground bar will be in contact with the box. If the mains are wired into the main lugs the main ground will have a green stripe or it may be bare multi strand aluminum. All ground wires go under screws individually on the ground bar. The white wires go onto the neutral bar. The neutral bar will be affixed to the inside of the box on plastic isolators that do not allow contact with the metal panel. The main neutral will have a white stripe or it may be solid white. The neutrals will go under individual screws. The hot wires will now go under the screws of the breakers. All screws must be tightned firmly but not as tight as you possibly can. The hots will be black or red. The wires should alternate black, red, black, red. Begin with black on the top two breakers the one left and the one on the right. The hot wires will be either black or red.
Feb 27, 2012 | General Electric GE 125 Amp Indoor Main...
The sub woofer wire inside came off my Simmons DA200S. where do i plug it back in?
If you look on the circuit board that the big black heat sink is attached to, there are two output amp chips (integrated circuits) attached to it. IC7 is the sub output amp. Next to that is a white jack with two pins sticking out, labeled J9. J9 is where you plug your sub into.
Jul 28, 2011 | Simmons DA200S Electronic Drum Set Monitor
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
I need to know the color codes for the radio rear sub.
2000 Ford Expedition Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White/Purple
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Blue/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Blue
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6′ x 8′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): White/Red
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): White/Orange
Car Audio Rear Speakers Size: 6′ x 8′
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Light Blue/Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Purple/White
Right Rear Speaker Negative Wire (-): Light Blue
Dec 24, 2009 | 2000 Ford Expedition
I am trying to hook up an ancient Kenwood KAC-801 amplifier. The original input cable has 1 red, 1 black, then another smaller awg white (1) sharing a common with another small awg yellow. Applying power...
Yes, keep in mind that the amps have a constant power (the large red wire) and need a remote signal to tell them when to turn on/off. This wire connect to a switched 12v from the ignition or radio blue wire (if aftermarket)
Nov 01, 2009 | Kenwood KAC-9102D Car Audio Amplifier
How do i wire two kicker l7 dual 2 ohm subs to play on a mtx 7801 class d amplifier
Hello moore_broder,
Your MTX 7801 is stable at 1 ohm, but you cannot wire a pair of DVC 2 ohm subs to that impedance. They can only be wired to 1/2 ohm which is too low or to 2 ohms.
Series the voice coils and parallel the subs. On each sub, jumper Black to Red/White Dot, then run both red's (positive) and both black/white dot's (negative) to your amp terminals.
The diagram is here.
Hope this helps.
Sep 24, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have a fusion sub and amp and have no instructions on how to wire this can somone please help ive got green wires red wire and a small thin blue wire
Hello nicole_murra,
The green wires are for signal input to the included amp and should be connected to a pair of RCA preamp outputs on your head unit. The thin blue wire connects from "remote" on the amp to a switched 12V output on the head unit (usually blue or blue/white). The red wire is for power and goes through the fuse to positive battery. You also need to connect the amp terminal marked "ground" to the metallic chassis of your vehicle, within a distance of about 1/2 meter or less. There's usually a short piece of wire with black insulation included in most amp wiring kits. If your Fusion sub did not come with such a wire, you can use any wire that is the same gauge (or bigger) than the red power wire.
Hope this helps.
Sep 08, 2009 | Fusion FEW12PK Car Subwoofer
The power switch came off of my subwoofer.
Same thing happened with me. Did you ever find a solution?
Nov 28, 2008 | JBL S120PII Subwoofer
Wiring
1st--on 1 sub put a wire connecting one red with white dot to the blk with white dot
2nd--do the same thing to the other sub !!do not wire a red/white to an all black
3rd--wire the full blk negetives to the amp, then same thing to the positive
Sep 21, 2008 | Kicker Car Audio & Video
JBL S120PII Subwoofer Logo
138 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
