Question about Garden
Need your help
Can,t it it to start
  • 486 Answers
No-start
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled (black and carbon deposits)
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Posted on Nov 12, 2009
I need help getting my Grandaughters tablet started . some one said we need ?a hard start" ?? Or something on that order. No phone here right now so I am on my Apple tablet .Can someone help us
can you please try and tell me what the problem you have with it?
why have you been told it needs a hard start mind you i have never heard of a hard start before.so to help you please try and tell me what is wrong with it.
Dec 09, 2016 | Apple Tablets & eReaders
Ford 550 not starting
Urbon, Could be a lot of things causing your F550 not to start, bad fuel, clogged filters, faulty fuel pump, faulty IDM(injector driver module), low voltage to injectors,etc. Check oil level as a first step and top up to full if needed. If you can have the truck scanned by a good diesel tech., diagnosed and estimate repair. See attached No start diesel engine diagnostic links. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
No Start Diesel Diagnosis KnowYourParts
02 F550 DIED CRANKS BUT WONT START NEED HELP ASAP Ford Truck Enthusiasts...
http://www.powerstroke.org/forum/6-0-motor-problems/14998-6-0-cranks-but-wont-start.html
Aug 16, 2016 | Ford Cars & Trucks
2000 INFINITI QX4 AFTER ENGINE CHANGE CANNOT START ,COMPUTER PROGRAM ?
Ok, first you need to check the basics for the engine to start:
1) Fuel
2)Spark
If no spark, check connections to the Cam Position Sensor.
If both are present and still no start, check compression.
I hope this helps!!
Mar 26, 2013 | Cars & Trucks
I can't start the engine of my car hyundai starex automatic transition.
Have you tried turning the key? :P but we will really need more info before we can help you. For all we know you turn the key and the pistons shoot out the exhaust. We need to know if the car turns over, clicks, lights work, power to the car, anything really will help us help you more
Sep 21, 2012 | 1996 Hyundai Accent
Need to restore my emachine back to factory setting
mcdevito75 here, You"ll need to contact your computers support and help thru start. Right click on start, lower left hand corner, the click on support and help. Or you can use your computers restore feature, this feature is also available thru the start and support / help section. Or you can simply type in restore in search from your home page.
Jul 31, 2010 | Computers & Internet
Car wont start help
try to change the fuel filter first. Then check the fuel pump if it's still good. might need some cleaning since it was not running for several months
Aug 19, 2009 | 2001 Volkswagen Golf
Random starting issue
You will need to Change or Have them Changed, The Fuel Filter and the Fuel Pump. Also Check the Fuel Pump Relay in the Fuse Relay Box under the Hood. Let me know if you need any Further Help! Please Rate my Response, I need all the Help that I can Get!
Jan 26, 2009 | 1998 Ford Taurus
My 96 ford escort wont start
Your vehicle needs 3 things to start Air-Gas-Spark. I need more information to help you. One of these definitely have to missing for your vehicle NOT to start. get back if you need more help. Thanks for using FIX YA
Jan 08, 2009 | Ford Escort Cars & Trucks
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
