Question about Hotpoint  14.9 Cu. Ft. Top-Freezer Refrigerator
Top freezer freezing up may have left door open model number4hth15bbrlww also what should the setting be on?
  • 2,237 Answers
It all depends on how much you have in the freezer. if you have very little, set it to low. a lot, high.
Posted on Nov 13, 2009
Why are my fresh vegetables freezing in my vegetable bend and my sour cream freezing on my top shelf in refrigerator. Got to be something simple. Thanks
send the model number off of the machine,if freezer is on bottom or side by side open the fridge door,look up on the right hand wall up near the ceiling and you should see a tag with the model and serial numbers,if freezer is on top open the fridge door and look at the left side wall up near the ceiling
Jan 01, 2018 | Refrigerators
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
My freezer on the french door model is freezing over. All of my food has what appears to be snow. Why
warm air is somehow leaking into the freezer or a common problem with bottom mount doors is they get left open and that's what happens,check the gasket or the door was left open.
Apr 11, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
Freezer section 26 deg f. refrigerator section 58 deg f with both dials set on 3. refrigerator section not cold even if dial is set to 4 or 5
when you open the freezer door do you hear the fan blowing,also is there any like snow or frost on the freezer wall inside the freezer,touch it and make sure or was the door left open?is there frozen water droplets on the food packages and on the racks,let me know what you find and send the model number,open the fridge door and look on the left side wall near the ceiling
Sep 07, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Can i turn the freezer part of my fridge of so i can defrost the bottom part n leave the top part on , i have a zanussi electrolux
no your model is a single compressor which runs both frdge and freezer.. freezer is supposed to be frost free however freezing elements can be overwhelmed with frost if door has been left open. there is a drain hole behind the back panel of the freezer that can block or freeze up causing water to flow in tp the freezer and turn to ice. complete defrost and check that drain hole is clear to fix it.
Jul 24, 2010 | Zanussi ZEBF250W Bottom Freezer...
Left my upright freezer open a crack and now the
With the door left open moisture would get into the unit behind the walls and into the duct work. The only way to fix this right is to unload it and let it unthaw for a day or so open. Once it is all defrosted and restarted it should be fine again.
May 09, 2010 | AEG 10.35 cu. ft. / 293 liter Upright...
After you open and close the refrigerator on top, the freezer drawer pops open. it is now leaking water.
check to see if the fridge is tilted back a little so the top door closes with just a little shove,also if there isn't any weight on the freezer door it will pop open,put something on the door,a bottle of water that will freeze or whatever you want,it could be leaking from stuff melting from the door being open, is the water dripping from the door?the door does freeze up and will melt out if door is left open, hopefully your air ducts didin't freeze up,make sure you can feel cold air blowing into the fridge section,if not heat up the back wall where the evap fan motor is with a hair dryer the air ducts are near there and check the freezer ceiling for frozen water droplets,hopefully everything will freeze back up with the door closed.
Jan 28, 2010 | Amana ABB1927DE Bottom Freezer...
Dog left open and freezer not starting back to freeze
freezer condenser is frosted over. Open frezzer and defrost manuly. Open door and panel in back comes off with six screws.
Jun 17, 2008 | Samsung RS2630SH Side by Side Refrigerator
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Wow, so you dropped some money into it, eh? I would take a look at the damper door asslb(DIFFUSER). located at the very top left of your refrigerator section in back. It has a motorized door that opens and close's and it may be stuck open. More than likely it is broken and needs to be replaced. GOODLUCK!!!!
FYI: All your cold air in your refrigerator comes from your freezer!
Dec 17, 2007 | GE Profile PFS22 33" Artica French Door...
Hotpoint  14.9 Cu. Ft. Top-Freezer Refrigerator Logo
51 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
