Polyview v17e can not get a signal input not sure I have the right cords
  • 49 Answers
Ok i had this issue.. on the monitor u have vga and hdmi ports if ur on vga then it should work unless the cord is plugged in the hdmi..
check this in the bios by pressing DEL or F1 at system start up and check the BIOS for Display and make sure the 1st choice is set to VGA . THEN PLUG THE CABLE IN THE VGA jack in the monitor then restart system and see if u get a signal that way hope i help you here..
Posted on Nov 12, 2009
Polyview V17E monitor looses power at irregular times
Check your power saver settings
Start - Control Panel - Power
May 08, 2010 | Polyview V17E 17" LCD Flat Panel Monitor
Acer aspire 5532 power on but no screen or sound
check the power light, is it stay on with green. If yes, probably inverter or back light tube defective. If not, make sure the VGA/DVI cable connector or power cord is secure with PC. if everything is secure then probably the power board or main board defective.
Mar 21, 2010 | Polyview V17E 17" LCD Flat Panel Monitor
When i start up my computer the screen is blank - its a polyview v17e. we manually must press menu on the monitor then move across to display settings and select analog - the screen then starts up? how do...
You may have to look at the setup menu to see if you can turn on 'AUTO SOURCE SELECT' and set to auto. You may have problem with the logic board that is why it cannot auto detect the DVI or VGA port automatically.
Need the polarity of the adapter for polyview v17e moniter
i'm guessing you don't have the original adaptor to test it... sometimes polarity is printed onto the case where the adaptor plugs in... get out your magnafying glass to see it tho.
Jan 02, 2009 | Polyview V17E 17" LCD Flat Panel Monitor
Polyview v17e - microphone?
G'day Matt,
No microphone. It has a line in socket to drive the stereo speakers.
cheers,
dave.
Jul 03, 2008 | Polyview V17E 17" LCD Flat Panel Monitor
I have problems with my LCD polyview
These monitors are plug and play compliant and should not require any drivers. If you are having video problems it may be the video card.
Apr 06, 2008 | Polyview V17E 17" LCD Flat Panel Monitor
Monitor Display Problem.
The first Polyview has a power supply problem (a short) and locks out the power until it is unplugged. You need to check the voltages inside the Monitor to determine which component/s are faulty. I hope you know electronics if not leave it to the repair shop because you have neither the skills or equipment to repair it. By the way I am not a monitor repair man but I do have 30 plus years in the electronics field.
The second monitor may have a broken wire in the cord that goes to your computer. Other internal components can cause the same simptoms your seeing. Good luck!
Mar 28, 2008 | Polyview V17E 17" LCD Flat Panel Monitor
No singnal input
hi..
well If would first start by checking all the cables and making sure they are connected in the correct color spot and secure...
if it came with an intall disc then i would uninstall then reinstall disc.. or just shutdown pc, unplug lcd connector to pc and to power adapter... then once it sits for about 30 seconds, go ahead and reconnect everything and power up your pc..
is your lcd new, if so, and none of this works, i would definitely contact the manufacturer too and make sure there isn't some sort of warranty..
good luck and let me know if i can help anymore..
thanks,
d
Feb 27, 2008 | Polyview V17E 17" LCD Flat Panel Monitor
Polyview V17E
Same as before this sounds very similar to the problem that I had with my polyview v396 19" . Its a power supply problem unclip the panel withdraw the power supply it plugs in on its own seperate board. Look for capacitors that bulge and replace them in fact replace them all on tha board not that hard. Replace them with the same rating voltage and micro fards. Cheaper than relacing the whole panel, hope this helps. :)
Dec 06, 2007 | Polyview V17E 17" LCD Flat Panel Monitor
Driver for Polyview V17E 17" LCD Flat Pane
if you are using windows and it just won't let you go on the other resolutions try checking the monitor settings in your control panel
Nov 06, 2007 | Polyview V17E 17" LCD Flat Panel Monitor
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
